    Dealing with 404 url error in module.
    10 Posts 4 Posters 3.3k Views 4 Watching
      Here is my problem. My data for images ALWAYS has a url. Example:
      eolMediaURL:"http://media.eol.org/content/2012/06/13/04/74287_orig.jpg"
      I can display these easily via img.src = EOL.eolMediaURL;
      The problem is that some of the url’s are broken. I can’t use
      if (EOL.eolMediaURL === 404)) {
          img.src = "modules/MMM-EOL/images/darwin.jpg";
      because the url is ALWAYS there in the data. I’ve made several attempts to set a replacement image for the broken links but I have failed miserably. I humbly defer to, and thank, anyone that can lead to a solution.
      Just to be clear, eolMediaURL: is in every object and in an object loop.
      Thank you, my friends. :-)
      justjim1220J S 2 Replies Last reply Reply Quote 0
        sdetweil @Mykle1
        @mykle1 sorry, you are using some words that don’t describe well what the problem is…
        i THINK you said
        when I try to load image files (local to the MM system), I use a URL string.
        that URL string is 'relative' to the base of my server, defined by '??????' (you didn't supply that)
        when a URL fails to load, I get error 404. (not found).
        but how do I handle this?
        you would add an onerror() handler for the img object
        this will get called ONLY when there is an error
        img.onerror = funtion(event_object){
        var img_with_error = event_object.currentTarget
        img_with_error.src=??? the url of the failing image
        see https://www.w3schools.com/jsref/obj_event.asp
        for more info in decoding the event object
        • justjim1220J Offline
          justjim1220 Module Developer @Mykle1
          @mykle1
          I found this, seems to be what you are looking for…
          The new window.fetch API is a cleaner replacement for XMLHttpRequest that makes use of ES6 promises. There’s a nice explanation here, but it boils down to (from the article):
          fetch(url).then(function(response) {
            return response.json();
          }).then(function(data) {
            console.log(data);
          }).catch(function() {
            console.log("Booo");
          Browser support is now good in the latest releases (works in Chrome, Firefox, Edge (v14), Safari (v10.1), Opera, Safari iOS (v10.3), Android browser, and Chrome for Android), however IE will likely not get official support. GitHub has a polyfill available which is recommended to support older browsers still largely in use (esp versions of Safari pre March 2017 and mobile browsers from the same period).
          I guess whether this is more convenient than jQuery or XMLHttpRequest or not depends on the nature of the project.
          Here’s a link to the spec https://fetch.spec.whatwg.org/
          Jim Hallock - 1995
            this is an example of the XMLHttpRequest mentioned in the previous post…
            var xmlHttp = null;
            function GetCustomerInfo()
                var CustomerNumber = document.getElementById( "TextBoxCustomerNumber" ).value;
                var Url = "GetCustomerInfoAsJson.aspx?number=" + CustomerNumber;
                xmlHttp = new XMLHttpRequest();
                xmlHttp.onreadystatechange = ProcessRequest;
                xmlHttp.open( "GET", Url, true );
                xmlHttp.send( null );
            function ProcessRequest()
                if ( xmlHttp.readyState == 4 && xmlHttp.status == 200 )
                    if ( xmlHttp.responseText == "Not found" )
                        document.getElementById( "TextBoxCustomerName"    ).value = "Not found";
                        document.getElementById( "TextBoxCustomerAddress" ).value = "";
                    else
                        var info = eval ( "(" + xmlHttp.responseText + ")" );
                        // No parsing necessary with JSON!
                        document.getElementById( "TextBoxCustomerName"    ).value = info.jsonData[ 0 ].cmname;
                        document.getElementById( "TextBoxCustomerAddress" ).value = info.jsonData[ 0 ].cmaddr1;
            Jim Hallock - 1995
              and this example uses jQuery…
              < script>
              $(document).ready(function(){
                  $("button").click(function(){
                      $.get("demo_test.asp", function(data, status){
                          alert("Data: " + data + "\nStatus: " + status);
              < /script>
              you would have to download or call jquery…
              downloaded and added to your module directory…
              getScripts: function() {
                  return ["jquery.min.js'];
              to call for it…
              < script src="https://ajax.googleapis.com/ajax/libs/jquery/3.3.1/jquery.min.js">< /script>
              Jim Hallock - 1995
                Mykle1 Project Sponsor Module Developer @justjim1220
                @justjim1220
                I appreciate you trying to help but I could have kept googling myself. I’m looking for an explanation, too, and not just a random “try this!”. Thanks
                  sdetweil @Mykle1
                    @sdetweil said in Dealing with 404 url error in module.:
                    Yes, I’m sorry about the description but you understood my meaning, so thank you for that. :thumbsup:
                    Your onerror() handler suggestion is/was exactly what I needed/wanted and works beautifully. Again, thank you. I do appreciate that you took the time to give me advice/assistance. Here is the finished, working tag:
                      // picture
                                var img = document.createElement("img");
                                img.classList.add("photo");
                                img.onerror = function(event_object) { //  This function replaces broken image
                                var img_with_error = event_object.currentTarget //  This function replaces broken image
                                img_with_error.src= "modules/MMM-EOL/images/darwin.jpg" // This is the path to the replacement image
                                wrapper.appendChild(img);
                    I would be remiss if I did not thank @cowboysdude, as well, for his help on this module.
                    S cowboysdudeC 2 Replies Last reply Reply Quote 1
                      sdetweil @Mykle1
                      @mykle1 note that your onerror handler could get stuck in a loop IF the forced replacement url also fails
                        That’s good to know. Thanks to you again. If you were in NYC I would buy you a beer (or many). :-)
                        • cowboysdudeC Offline
                          cowboysdude Module Developer @Mykle1
                          @mykle1 @sdetweil came up with a beautiful answer…I didn’t do a thing LOL
