    MMM-NewsFeedTicker
    94 Posts 15 Posters 88.5k Views 14 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @Cr4z33
      @cr4z33
      To stop the marquee (scroll) put the following in your config file:
      showMarquee: false,
      “Life’s Too Short To Dance With Ugly People”
      Jim Hallock - 1995
      Cr4z33C 1 Reply Last reply Reply Quote 1
      • Cr4z33C Offline
        Cr4z33 @justjim1220
        @justjim1220 maybe you were referring to @cyberphox ? :grinning_face_with_smiling_eyes:
        • Cr4z33C Offline
          Cr4z33
          Hi @justjim1220 any news about your next update? :)
          justjim1220J 1 Reply Last reply Reply Quote 0
            @cr4z33
            Nothing just yet, been a bit under the weather with the flu. Keep falling asleep or losing concentration.
            I will keep trudging through. :winking_face:
            Jim Hallock - 1995
              If anyone is interested…
              Adding the following will scroll the image with the article, but it will stop at the left while the rest of the article finishes scrolling:
              @Keyframes marqueeImage {
              0% {left: 100%;}
              100% {left: 0;}
              .MMM-NewsFeedTicker .image {
              position: absolute;
              display: inline-block;
              vertical-align: middle;
              margin-left: 0;
              height: 100px;
              z-index: 1;
              background-color: rgb(175, 175, 175);
              animation: marqueeImage 20s linear;
              Jim Hallock - 1995
                New Update —> please run a git pull && npm install within the NewsFeedTicker directory
                Jim Hallock - 1995
                • Cr4z33C Offline
                  Cr4z33 @justjim1220
                  @justjim1220 said in MMM-NewsFeedTicker:
                  @cr4z33
                  Have a good recovery and thanks for the update. ;)
                  • Cr4z33C Offline
                    Cr4z33 @justjim1220
                    Got an error:
                    ~/MagicMirror/modules/MMM-NewsFeedTicker $ git pull && npm install
                    remote: Enumerating objects: 7, done.
                    remote: Counting objects: 100% (7/7), done.
                    remote: Compressing objects: 100% (4/4), done.
                    remote: Total 4 (delta 2), reused 0 (delta 0), pack-reused 0
                    Unpacking objects: 100% (4/4), done.
                    Da https://github.com/justjim1220/MMM-NewsFeedTicker
                       5895a96..eed535d  master     -> origin/master
                    Aggiornamento di 5895a96..eed535d
                    error: Your local changes to the following files would be overwritten by merge:
                    	MMM-NewsFeedTicker.css
                    Please commit your changes or stash them before you merge.
                    Aborting
                    • Cr4z33C Offline
                      Cr4z33 @justjim1220
                      @justjim1220 althought I know ZERO about developing, JSON, CSS & Co. I was doing a quick search on Google about scrolling text stuttering in Electron on slow devices and I found out a suggestion at Stackoverflow.com that actually improved A LOT the overall perfomance of the newsfeed scrolling!
                      Go open /home/pi/MagicMirror/modules/MMM-NewsFeedTicker/MMM-NewsFeedTicker and replace
                      .MMM-NewsFeedTicker .tickerbody {
                        position: relative;
                      with
                        position: relative;
                        transform: translateZ(0);
                        backface-visibility: hidden;
                      You should notice now an improvement. :upside-down_face:
                        @cr4z33
                        This error you got is just letting you know it can’t overwrite file within the module that you made any changes to
                        You have to rename the file or delete it or just remove it from the directory
                        Jim Hallock - 1995
                        • Cr4z33C Offline
                          Cr4z33 @justjim1220
                          @justjim1220 OK I ran the update succesfully by deleting the CSS.
                          However I would like to revert to how it was looking before the update (static image on the left and smaller scrolling text). :grimacing_face:
                          How do I do that please?
                            @cr4z33
                            If you did not make any changes to the original files, run git pull && npm install
                            If you made changes to any of the original files that you want to keep, rename those files, then run git pull && npm install
                            if there isn’t anything you need saved, delete the MMM-NewsFeedTicker directory and run the git clone '. . .'
                            Jim Hallock - 1995
                            • Cr4z33C Offline
                              Cr4z33 @justjim1220
                              @justjim1220 that’s what I already did, but I see you now fixed that. :)
                              Thanks.
                              • BKeyportB Offline
                                BKeyport Module Developer
                                Looking good, other than the logo now appearing centered on final position - I have deleted all custom css…
                                • Cr4z33C Offline
                                  Cr4z33 @BKeyport
                                  @bkeyport so that’s not only me?
                                  I thought I messed up something in the CSS.
                                  • BKeyportB Offline
                                    @Cr4z33 Nope, not just you.
                                    Fixed it, actually. added the line “left: 0px;” in my custom css in the “.MMM-NewsFeedTicker .image” section… it’ll force the image to the left.
                                    • Cr4z33C Offline
                                      Cr4z33 @BKeyport
                                      @bkeyport oh great doing it now thanks.
                                      • BKeyportB Offline
                                        BKeyport Module Developer @Cr4z33
                                        fwiw, it could have happened as adjustments made to the code for a feature I asked for… :innocent look:
                                        • KimzerK Offline
                                          Kimzer
                                          Any way to make the logo smaller? It got huge with using the keyframes bit
                                          • BKeyportB Offline
                                            yes, as a matter of fact. Fixes the centering too if you have that problem:
                                            custom.css in css subdirectory:
                                            position: absolute;
                                            margin-left: 0;
                                            height: 40px; /* set to your image size */
                                            z-index: 1;
                                            background-color: #FFF;
                                            bottom: 0;
                                            left: 0px;
                                            • 3 / 5
