    MMM-PC-Stats
    41 Posts 3 Posters 21.5k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @Mykle1
      @mykle1
      Comment out console.log(this.Stats) so you only get the sensors output
      justjim1220J 1 Reply Last reply Reply Quote 0
      • justjim1220J Offline
        justjim1220 Module Developer @Mykle1
        @mykle1 ok
        Jim Hallock - 1995
          Mykle1 Project Sponsor Module Developer @justjim1220
          @justjim1220
          Take a screenshot of just the output, not the whole screen. I might be able to see it then
            pop@HPEu:~/MagicMirror$ sensors
            nouveau-pci-0100
            Adapter: PCI adapter
            fan1:        1110 RPM
            temp1:        +39.0°C  (high = +95.0°C, hyst =  +3.0°C)
                                   (crit = +105.0°C, hyst =  +5.0°C)
                                   (emerg = +135.0°C, hyst =  +5.0°C)
            coretemp-isa-0000
            Adapter: ISA adapter
            Core 0:       +29.0°C  (high = +83.0°C, crit = +99.0°C)
            Core 1:       +30.0°C  (high = +83.0°C, crit = +99.0°C)
            Core 2:       +29.0°C  (high = +83.0°C, crit = +99.0°C)
            Core 3:       +28.0°C  (high = +83.0°C, crit = +99.0°C)
            f71858fg-isa-0a00
            +3.3V:        +3.31 V
            3VSB:         +3.31 V
            Vbat:         +3.20 V
            fan1:        1910 RPM
            fan2:         998 RPM
            fan3:           0 RPM  ALARM
            temp1:        +29.2°C  (high = +70.0°C, hyst = +60.0°C)
            temp2:        +15.4°C  (high = +100.0°C, hyst = +85.0°C)
            temp3:        +32.5°C  (high = +100.0°C, hyst = +85.0°C)
            pop@HPEu:~/MagicMirror$ ^C
            justjim1220J 2 Replies Last reply Reply Quote 0
              @mykle1
              Objectacpitz-virtual-0: {Virtual device: {…}}k8temp-pci-00c3: {PCI adapter: {…}}nouveau-pci-0090: {PCI adapter: {…}}__proto__: Object
              moment-timezone-with-data.js:481 Moment Timezone has no data for American/Chicago. See http://momentjs.com/timezone/docs/#/data-loading/.
              logError @ moment-timezone-with-data.js:481
              MMM-PC-Stats.js:126 Uncaught (in promise) TypeError: Cannot read property 'ISA adapter' of undefined
                  at Class.getDom (MMM-PC-Stats.js:126)
                  at main.js:110
                  at new Promise (<anonymous>)
                  at updateDom (main.js:109)
                  at Object.updateDom (main.js:514)
                  at Class.updateDom (module.js:358)
                  at Class.socketNotificationReceived (MMM-PC-Stats.js:262)
                  at module.js:246
                  at r.<anonymous> (socketclient.js:25)
                  at r.emit (index.js:83)
                  at main.js:110
                  at Class.socketNotificationReceived (MMM-PC-Stats.js:268)
                  at module.js:246
              Jim Hallock - 1995
                @mykle1
                jim@jim-Aspire-4520:~/MagicMirror$ sensors
                k8temp-pci-00c3
                Core0 Temp:   +69.0°C
                Core0 Temp:   +67.0°C
                Core1 Temp:   +69.0°C
                Core1 Temp:   +68.0°C
                acpitz-virtual-0
                Adapter: Virtual device
                temp1:        +71.0°C  (crit = +100.0°C)
                nouveau-pci-0090
                GPU core:     +1.20 V  (min =  +1.00 V, max =  +1.20 V)
                temp1:        +64.0°C  (high = +95.0°C, hyst =  +3.0°C)
                                       (crit = +105.0°C, hyst =  +2.0°C)
                Jim Hallock - 1995
                  @justjim1220
                  Ok, I see it. In dev tools you can expand the output to see the tree
                    @mykle1
                    there is a lot of things to expand, how much do you need?
                    Objectacpitz-virtual-0: Virtual device: temp1: name: "temp1"type: "temperature"value: 80__proto__: Objectconstructor: ƒ Object()arguments: (...)assign: ƒ assign()caller: (...)create: ƒ create()defineProperties: ƒ defineProperties()defineProperty: ƒ defineProperty()entries: ƒ entries()freeze: ƒ freeze()getOwnPropertyDescriptor: ƒ getOwnPropertyDescriptor()getOwnPropertyDescriptors: ƒ getOwnPropertyDescriptors()getOwnPropertyNames: ƒ getOwnPropertyNames()getOwnPropertySymbols: ƒ getOwnPropertySymbols()getPrototypeOf: ƒ getPrototypeOf()is: ƒ is()isExtensible: ƒ isExtensible()isFrozen: ƒ isFrozen()isSealed: ƒ isSealed()keys: ƒ keys()length: 1name: "Object"preventExtensions: ƒ preventExtensions()prototype: {constructor: ƒ, __defineGetter__: ƒ, __defineSetter__: ƒ, hasOwnProperty: ƒ, __lookupGetter__: ƒ, …}seal: ƒ seal()setPrototypeOf: ƒ setPrototypeOf()values: ƒ values()__proto__: ƒ ()[[FunctionLocation]]: <unknown>hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectk8temp-pci-00c3: PCI adapter: __proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()nouveau-pci-0090: PCI adapter: {GPU core: {…}, temp1: {…}}__proto__: Object__proto__: constructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()
                    Jim Hallock - 1995
                      @mykle1
                      It looks like this is the line it is having a problem with…
                          var core0TempCheck = Sensors["coretemp-isa-0000"]['ISA adapter']['Core 0'];
                      particularly with: [‘ISA adapter’]
                      Jim Hallock - 1995
                        @justjim1220
                        I know the line that is the problem. Listen, I’m tired. If you’ll let me TeamViewer into your machine tomorrow I’ll fix it. Doing it this way is very tedious
                          @mykle1
                          Absolutely.
                          No Problem.
                          Just let me know when.
                          Jim Hallock - 1995
                            is there something I need to set up on this end for TeamViewer?
                            Jim Hallock - 1995
                              @mykle1
                              And, your gonna have to let me know how to do a screen shot of just a certain part of the screen, or how to crop the image. A lot different than Windows.
                              Jim Hallock - 1995
                                @justjim1220
                                This is what you need to change in the main js
                                		// Check if core0 has temp sensor
                                        var core0TempCheck = Sensors["acpitz-virtual-0"]; // ['ISA adapter']['Core 0'];
                                		if (typeof core0TempCheck !== 'undefined'){
                                        var core0Temp = document.createElement("div");
                                        core0Temp.classList.add("small", "bright", "core0Temp");
                                        core0Temp.innerHTML = Sensors["acpitz-virtual-0"]["Virtual device"].temp1.value + " &nbsp  @  &nbsp "
                                						    + Sensors["acpitz-virtual-0"]["Virtual device"].temp1.value + "&deg;C";
                                        wrapper.appendChild(core0Temp);
                                        // ["acpitz-virtual-0"]["Virtual device"].temp1.value
                                		// Check if core1 has temp sensor
                                        var core1TempCheck = Sensors["acpitz-virtual-0"]; // ['ISA adapter']['Core 1'];
                                		if (typeof core1TempCheck !== 'undefined'){
                                        var core1Temp = document.createElement("div");
                                        core1Temp.classList.add("small", "bright", "core1Temp");
                                        core1Temp.innerHTML = Sensors["acpitz-virtual-0"]["Virtual device"].temp2.value + " &nbsp  @  &nbsp "
                                						    + Sensors["acpitz-virtual-0"]["Virtual device"].temp2.value + "&deg;C";
                                        wrapper.appendChild(core1Temp);
                                  Now leave me alone. I’m going to bed. :-)
                                  justjim1220J 4 Replies Last reply Reply Quote 0
                                    @mykle1 ok
                                    Jim Hallock - 1995
                                      @mykle1 YES SIR!!!
                                      Jim Hallock - 1995
                                        @mykle1
                                        This is what I ended up with:
                                        for (var i = 0, len = Stats.cpu.threads.length; i < len; i++) {
                                        		var Element = document.createElement("div");
                                        		Element.classList.add("large", "bright", "usage");
                                        		Element.innerHTML = Stats.cpu.threads[i].name + " &nbsp  @  &nbsp " + Number(Math.round(Stats.cpu.threads[i].usage+"e2")+"e-2") + "%";
                                        		wrapper.appendChild(Element);
                                        		var core0TempCheck = Sensors["acpitz-virtual-0"]["Virtual device"];
                                        			// core0Temp
                                        			core0Temp.classList.add("large", "bright", "core0Temp");
                                        			core0Temp.innerHTML = Stats.cpu.threads[i].name + " &nbsp  @  &nbsp " + Sensors["acpitz-virtual-0"]["Virtual device"].temp1.value + "°C";
                                        this is the output:
                                        Jim Hallock - 1995
                                          @mykle1
                                          So, when I use the code you sent last night, It gives error regarding .temp2.value
                                          being that the ‘Virtual device’ only has 1 output value.
                                          My changes will always show the ‘temp value’ as the same for all CPU’s
                                          When I run ‘sensors’ in MM, it showed a ‘Core0 Temp’ and a ‘Core1 Temp’, It actually showed 2 temps for each one.
                                          k8temp-pci-00c3
                                          Core0 Temp:   +69.0°C
                                          Core0 Temp:   +67.0°C
                                          Core1 Temp:   +69.0°C
                                          Core1 Temp:   +68.0°C
                                          acpitz-virtual-0
                                          nouveau-pci-0090
                                          With this being a Dual Core CPU, why can’t I get it to use the ‘PCI adapter’ to give the output?
                                          Jim Hallock - 1995
                                            @mykle1
                                            Another question…
                                            How can be changed to show F°?
                                            Not really a big deal, mostly just curious… :upside-down_face:
                                            Jim Hallock - 1995
                                            yawnsY 1 Reply Last reply Reply Quote 0
                                            • 2 / 3
