    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 891.4k Views 74 Watching
    • C Offline
      chris1971
      The crazy situation is, that I have done it before… after a crash I had to config the system again, but I do not know how I have done this in the past. My backup didn’t work and the file was corrupt… :-(
      This is the design I would like to have again.
        surger13 Project Sponsor
        I hope so, too. Just like on your picture I would configure it for myself.
        • O Offline
          onkelbobby
          @chris1971
          if you just wanna remove the wind in the forecast tile try to add that line in MMM_DarkSkyForecast.css
          .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .wind-container{
            display: none;
          of course it makes sense to remove the existing line before
          hope this helps
          • E Offline
            evil_gusgus @j.e.f.f
            @j-e-f-f
            Hey there, I’ve also run into this issue. Not sure if anyone has made any progress on it?
              sdetweil @j.e.f.f
              @j-e-f-f this looks like a null character before some translation…
              I think it is caused by this line of code in MMM-DarkSkyForecast.js
                      animatedIconId: this.config.useAnimatedIcons ? this.getAnimatedIconId() : null,
              and I think the template check has failed
                        {% if forecast.currently.animatedIconId %}
              • P Offline
                pugsly
                Trying to find out how to remove this spacing circled in RED.
                lavolp3L J 2 Replies Last reply Reply Quote 0
                  mydiva
                  Hi all, why my day forecast jambs to the hourly forecast? This happens not always just rendemly?0_1553890445243_49a02d18-cc4e-40b9-85f4-336acfe0f773.jpg image url)
                  • lavolp3L Offline
                    lavolp3 Module Developer @pugsly
                    @pugsly You can check out the css of the part using the developer’s tools of your browser.
                    The css properties can then be switched on and off and with that you can find out what is responsible for the space.
                    I would guess your module has become broader due to another module. The forecast part, however, seems to have a fixed width and is aligned left. Then you get an empty space on the right.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    • lavolp3L Offline
                      lavolp3 Module Developer @mydiva
                      @mydiva The width of your module seems to have become so big that the daily forecast slips into hourly line. I would suggest to set a fixed width for this part or control the width of the other module influencing this.
                        j.e.f.f Project Sponsor Module Developer @mydiva
                        @mydiva said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                        By default, my module does not force a size for the tiles in this view, as I can’t guess how many columns you’ll have if you’ve adjusted the size of your main layout columns. It should be three columns on a default magic mirror installation, but the actual forecast information might cause the tiles to grow or shrink.
                        You can fix this in your custom.css file. Try this:
                        .MMM-DarkSkyForecast .forecast-item {
                          width: 33%; /* for a three column layout */
                        Adjust as desired. For a four-column layout, specify 25% (You may need to also increase the size of the main container (e.g.: top_left) to get it all to fit. For a two-column layout, use 50%.
                        I might add a specific configuration to handle this in the future so that you don’t need to write CSS to address this.
                          j.e.f.f Project Sponsor Module Developer @pugsly
                          @pugsly said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                          By default my module forces a fixed width of 300px. It looks like your parent column (i.e.: top_right) is either explicitly set to be larger or is being forced larger by another module (maybe the “Devices Online” module underneath the forecast in your screenshot).
                          You can address either of the above situations in your custom.css file. If you’ve set an explicit width for the parent column, then this should fix the issue:
                          .MMM-DarkSkyForecast .module-content {
                            width: 100%;
                          Otherwise, if another module is forcing the width of the column to be larger than normal, then you can either try to tame the width of that module, or you can set an explicit pixel width for your forecast to use the extra space. Try something like this:
                            width: 450px; /* adjust this as desired */
                          • C Offline
                            chris1971 @onkelbobby
                            @onkelbobby
                            Done… after several trails I got the right setup … 0_1554403496449_04.04.2019.jpg
                            • T Offline
                              trividar
                              Is there a way to hide or delete the „power by …“ signet? Thx… by the way thanks for answering my previous question, I just resized 20px and it works now 👌 thx🤘
                                Smotx
                                I have test to modify every lines on original CSS and i can’t found how to reduce space top and under ‘day’
                                alt text
                                Thx for help
                                sorry, I knew stupid, I had already asked this question and already had the answer ^^
                                For help others who wants to redure space :
                                .MMM-DarkSkyForecast .module-header {
                                  margin-bottom: 20px; /* adjust to taste */
                                .MMM-DarkSkyForecast .module-header.forecast-header {
                                .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .time,
                                .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .day-name {
                                line-height: 20px; /* adjust to taste */
                                Thx to module designer
                                • O Offline
                                  Ore77
                                  Hello,
                                  can someone help me out?
                                  I dont know how to resolve this issue.
                                  My console says : " …MIME type is not executable…".
                                    sdetweil
                                    go to the MM/modules folder and do
                                    ls MMM-Dark*
                                    then
                                    cd MMM-DarkSkyForecast
                                    then
                                    ls
                                    the error says that MMM-DarkSkyForecast.js is not present in the MMM-DarkSkyForecast folder (error 404)
                                    • O Offline
                                      Ore77
                                      thanks for you reply.
                                      The file is definitely in that directory.
                                        sdetweil @Ore77
                                        @Ore77 is it spelled exactly like that… can u edit that file (nano MMM-DarkSkyForecast.js , ctrl-x to exit editor)
                                        • O Offline
                                          Ore77
                                          yea its exactly this file. And i´m able to edit and save without issues.
                                            sdetweil
                                            is this s new install?
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
