    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 918.3k Views 74 Watching
      sdetweil @j.e.f.f
      @j-e-f-f this looks like a null character before some translation…
      I think it is caused by this line of code in MMM-DarkSkyForecast.js
              animatedIconId: this.config.useAnimatedIcons ? this.getAnimatedIconId() : null,
      and I think the template check has failed
                {% if forecast.currently.animatedIconId %}
        pugsly
        Trying to find out how to remove this spacing circled in RED.
        lavolp3L J 2 Replies Last reply Reply Quote 0
          mydiva
          Hi all, why my day forecast jambs to the hourly forecast? This happens not always just rendemly?0_1553890445243_49a02d18-cc4e-40b9-85f4-336acfe0f773.jpg image url)
          • lavolp3L Offline
            lavolp3 Module Developer @pugsly
            @pugsly You can check out the css of the part using the developer’s tools of your browser.
            The css properties can then be switched on and off and with that you can find out what is responsible for the space.
            I would guess your module has become broader due to another module. The forecast part, however, seems to have a fixed width and is aligned left. Then you get an empty space on the right.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • lavolp3L Offline
              lavolp3 Module Developer @mydiva
              @mydiva The width of your module seems to have become so big that the daily forecast slips into hourly line. I would suggest to set a fixed width for this part or control the width of the other module influencing this.
                j.e.f.f Project Sponsor Module Developer @mydiva
                @mydiva said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                By default, my module does not force a size for the tiles in this view, as I can’t guess how many columns you’ll have if you’ve adjusted the size of your main layout columns. It should be three columns on a default magic mirror installation, but the actual forecast information might cause the tiles to grow or shrink.
                You can fix this in your custom.css file. Try this:
                .MMM-DarkSkyForecast .forecast-item {
                  width: 33%; /* for a three column layout */
                Adjust as desired. For a four-column layout, specify 25% (You may need to also increase the size of the main container (e.g.: top_left) to get it all to fit. For a two-column layout, use 50%.
                I might add a specific configuration to handle this in the future so that you don’t need to write CSS to address this.
                  j.e.f.f Project Sponsor Module Developer @pugsly
                  @pugsly said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                  By default my module forces a fixed width of 300px. It looks like your parent column (i.e.: top_right) is either explicitly set to be larger or is being forced larger by another module (maybe the “Devices Online” module underneath the forecast in your screenshot).
                  You can address either of the above situations in your custom.css file. If you’ve set an explicit width for the parent column, then this should fix the issue:
                  .MMM-DarkSkyForecast .module-content {
                    width: 100%;
                  Otherwise, if another module is forcing the width of the column to be larger than normal, then you can either try to tame the width of that module, or you can set an explicit pixel width for your forecast to use the extra space. Try something like this:
                    width: 450px; /* adjust this as desired */
                    chris1971 @onkelbobby
                    @onkelbobby
                    Done… after several trails I got the right setup … 0_1554403496449_04.04.2019.jpg
                    • T Offline
                      trividar
                      Is there a way to hide or delete the „power by …“ signet? Thx… by the way thanks for answering my previous question, I just resized 20px and it works now 👌 thx🤘
                        Smotx
                        I have test to modify every lines on original CSS and i can’t found how to reduce space top and under ‘day’
                        alt text
                        Thx for help
                        sorry, I knew stupid, I had already asked this question and already had the answer ^^
                        For help others who wants to redure space :
                        .MMM-DarkSkyForecast .module-header {
                          margin-bottom: 20px; /* adjust to taste */
                        .MMM-DarkSkyForecast .module-header.forecast-header {
                        .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .time,
                        .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .day-name {
                        line-height: 20px; /* adjust to taste */
                        Thx to module designer
                        • O Offline
                          Ore77
                          can someone help me out?
                          I dont know how to resolve this issue.
                          My console says : " …MIME type is not executable…".
                            go to the MM/modules folder and do
                            ls MMM-Dark*
                            then
                            cd MMM-DarkSkyForecast
                            then
                            ls
                            the error says that MMM-DarkSkyForecast.js is not present in the MMM-DarkSkyForecast folder (error 404)
                            • O Offline
                              Ore77
                              thanks for you reply.
                              The file is definitely in that directory.
                                sdetweil @Ore77
                                @Ore77 is it spelled exactly like that… can u edit that file (nano MMM-DarkSkyForecast.js , ctrl-x to exit editor)
                                • O Offline
                                  Ore77
                                  yea its exactly this file. And i´m able to edit and save without issues.
                                    is this s new install?
                                    • O Offline
                                      Ore77
                                      yes its a fresh install. Its the first 3rd party module i´ve installed.
                                        sdetweil @Ore77
                                        @Ore77 and the path is
                                        /home/pi/MagicMirror/modules/MMM-DarkSkyForecast
                                        right? u need to be in /home/pi/MagicMirror/modules before you do the git clone
                                          sdetweil @Ore77
                                          @Ore77 did u get it solved?
                                          • O Offline
                                            Ore77 @sdetweil
                                            @sdetweil i considered the path´s in my configuration. Nevertheless after a second install of raspbian it suddenly worked.
                                            I installed all updates of raspbian before i got over to MagicMirror this time.
                                            Maybe it has something to do with that.
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
