    MMM-CalendarExt2
    486 Posts 83 Posters 949.3k Views 83 Watching
      sdetweil @ccr41981
      @ccr41981 said in MMM-CalendarExt2:
      I’ve been through those posts about the display error,
      note that on node 16 the format of the correction has changed from prior posts
      C 1 Reply Last reply Reply Quote 1
      • C Offline
        ccr41981 @sdetweil
        @sdetweil Gotcha! Thanks again
        • C Offline
          ccr41981 @sdetweil
          @sdetweil said in MMM-CalendarExt2:
          @ccr41981 you’ve read the config doc?
          https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Configuration.md
          use the example, and your url .
          also, this module suffers from a missing library ( that was removed from the base a couple releases back )
          in the module folder (MagicMirror/modules/MMM-CalendarExt2) do
          npm install request --save
          Works great now! Thanks for your help
          • C Offline
            ccr41981 @ccr41981
            @sdetweil One last question; would you know why CalendarExt2 doesn’t show up on the remote module? Not that I’d ever turn it off, just curious.
              sdetweil @ccr41981
              @ccr41981 on the remote?
              • C Offline
                ccr41981 @sdetweil
                @sdetweil MMM-Remote-Control, that allows you to display or hide modules?
                S BKeyportB 2 Replies Last reply Reply Quote 0
                  sdetweil @ccr41981
                  @ccr41981 sorry, no idea
                  • C Offline
                    ccr41981 @sdetweil
                    @sdetweil Ok, thanks. Just curious.
                    • BKeyportB Offline
                      BKeyport Module Developer @ccr41981
                      @ccr41981 it’s likely because how CX2 generates it’s positions. In short, it’s working AROUND the built in position system and kinda builds it own.
                      • N Offline
                        noone
                        after installing this modular i get the following error.
                        pi@raspberrypi:~ $ npm run start
                        npm ERR! code ENOENT
                        npm ERR! syscall open
                        npm ERR! path /home/pi/package.json
                        npm ERR! errno -2
                        npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                        npm ERR! enoent This is related to npm not being able to find a file.
                        anyone know why?
                          sdetweil @noone
                          @noone need to be in the MagicMirror folder
                            sdetweil @noone
                            @noone next error
                            • N Offline
                              noone @sdetweil
                              @sdetweil thx its working now
                                MMPenguin
                                Hello,
                                I am having difficulties understanding how the deduplicateEventsOn works. I can get the configuration to make duplicated events not show; but how do I combine the entries under calendarName so the events show up “Bob/Jane/Sue/John” ? Or just “Everyone” ??
                                This is what I have that removes the duplication. Its at the very top of the module. Does it need to be somewhere else?
                                		{module: 'MMM-CalendarExt2',
                                					rotateInterval: 45*1000,
                                					deduplicateEventsOn:["startDate","endDate","duration","title","location"],
                                • F Offline
                                  fedale
                                  How to get quicker update of the google calendar in Magic mirror?
                                    sdetweil @fedale
                                    @fedale u can change the updateInterval… but note that too fast might get you denied for a while…
                                    • F Offline
                                      fedale @sdetweil
                                      @sdetweil I tried that earlier without any result. And seemed like the only thing updating was the screen flickering
                                      I put it under the module config in the config.js was that the correct postion?
                                        sdetweil @fedale
                                        @fedale ok, in the calendar its
                                        fetchInterval
                                        sorry,
                                        doc always wins!
                                        https://docs.magicmirror.builders/modules/calendar.html#configuration-options
                                        • F Offline
                                          fedale @sdetweil
                                          @sdetweil I tried the fetchInterval. But have not been sucessfull with that one.
                                          But everytime i save my config file it update at once.
                                          Is there somewhere else than in the config.js file i need to change the fetchInterval?
                                            sdetweil @fedale
                                            @fedale that is inside the config:{} section of the calendar module, yes,
                                            and NOT in the place where url: is
                                            BKeyportB F 2 Replies Last reply Reply Quote 0
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 23 / 25
