    Magic Mirror on Windows 8.1 tablet?
    windows8.1tablettouchscreen
    24 Posts 5 Posters 16.3k Views 4 Watching
      roxx
      Hi friends, i am getting a windows tablet for small price, its its Dell Venue 8 Pro. Should i buy it?🤔 It is just like new & unused but now the product is old in the market. Tablet details are here https://www.91mobiles.com/dell-venue-8-pro-price-in-india?ty=specs
      I have two doubts:
      1. it has 8" touchscreen… will it sense the touches on the screen after i build MM using this tablet? The mirrored acrylic sheet isnt available in my area… i will need to buy online… if possible please provide me amazon link to buy one.
      2. i will be installing MM as per this walkthrough… https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10 … i hope this goes well…
      Thanks friends…
      Only a biker knows why dogs stick their head outside the window of a moving vehicle!!
      B justjim1220J 2 Replies Last reply Reply Quote 0
        bhepler Module Developer @roxx
        @roxx - This probably will not work. The touchscreen will be unlikely to register any touches through the mirror surface.
        You can still use it as a source for a Magic Mirror, but you will be losing the touch interface unless you rig up an additional system. That said, most mirrors do not have touch capability and they’re still a lot of fun.
        • justjim1220J Offline
          justjim1220 Module Developer @roxx
          @roxx
          I tried to install MM2 on an older Windows Surface which was also Windows 8.1. But the OS would not let me install it as per the @ Mykle1’s walkthrough.
          If by some chance you do figure it out, I would be very interested in how you did it.
          Jim Hallock - 1995
            roxx @justjim1220
            I got the tablet for 2days to verify MM works… And it does… but i am still stuck with config and modules…
            @bhepler said in Magic Mirror on Windows 8.1 tablet?:
            Hi bhepler… what do you mean by rig an additional system, i didn’t understand what you mean… I really want my MM to be touchscreen…
            Check this pic
            https://imgur.com/a/FBJuD8z
            my tablet has a thin layer of glass on the screen, about 1mm thick… here in india mostly everyone gets this tempered glass for their mobiles & tablets, it keeps the display/screen safe, an additional protection if the device falls… the touch does work still after the layer of this glass, i guess could i use 2mm 2way acrylic or glass or film?? This tempered glass is easy to stick and remove… . what do you think??
            @justjim1220 said in Magic Mirror on Windows 8.1 tablet?:
            @roxx
            @justjim1220 … yep, i installed MM on my tablet as per the @ Mykle1s walkthrough.
            While i typed npm install in terminal, i tried installing npm install, but it gave an error… without doing anything further, i searched the net and then installed node & npm together from https://www.npmjs.com/get-npm
            Then MagicMirror worked… also check the version of node and npm as it says on that webpage…
            Here are few images
            http://imgur.com/a/SdaIhfj
            now i am working with config file and modules… another problem i came across is that fonts and everything looks big on my 8 inch tablet… clock weather and news, it all touches eachother… i need to make it smaller… theres no space between the modules… it happened before, reinstalled windows & everything and its fine but i guess adding modules will again create this problem…
            Yet another problem is the screen goes off after few minutes and comes up with windows user screen… need to disable it somehow…
            Moreover, once MM is started by npm start, i cant access anything, i have to bring up the charms bar, search for task manager and kill electron app…
            Try it, hope you could too install MM on your windows… And ya, the screen rotates as i rotate the tablet… i mean MM rotates, the orientation… I don’t need to add extra lines in config file for portrait or landscape as i read somewhere on the forum…
            Thanks…
            Mykle1M B cowboysdudeC 3 Replies Last reply Reply Quote 2
              Mykle1 Project Sponsor Module Developer @roxx
              @roxx said in Magic Mirror on Windows 8.1 tablet?:
              @justjim1220 But the OS would not let me install it as per the @ Mykle1’s walkthrough.
              Booyah! :thumbsup:
                Well, if you have experience with the capacitance working through the extra layer of glass then I’m certainly not going to insist otherwise. Worst case scenario, you’ll have a magic mirror without touch capability. Which is still pretty awesome.
                There are touch films you can put on top of glass to give you touch capability. You might have to go this route. But you might not. It’s worth trying the mirror with your tablet finding out. Let us know how it goes.
                • cowboysdudeC Offline
                  cowboysdude Module Developer
                  Well what I’ve found to be true 100% of the time is just following basic instructions which @Mykle1 has clearly laid out… listening to people that have no clue…yeahhhhh not such a great idea.
                  Being new what I would do is take some time and look around…you’ll see the answers people give and you’ll figure out those who know and those who are guessing :) It’s what I did and in the end I just went to the people that actually knew so I didn’t have to spend needless hours trying things that didn’t work :)
                    cowboysdude Module Developer @roxx
                    @roxx Great job!! The problem is that really no one is doing the exact same thing and sometimes you have to tinker to get it. Nice job going out on the net to find your answer … installing it as a package clears it up most of the time :)
                    When I first started out in MM I had a HUGE problem installing it sooooooo I would get as far as I could and then take my error out on the internet and find out how to fix it…well yeah it took me an entire day to get it working but it did finally. So cudos to you and great job!! Can’t wait to see it!
                      I was working with an original Surface RT which had Windows 8.1 on it.
                      The Surface itself would not allow the programs such as node, npm, electron, git bash, or MM be downloaded OR installed in any way. The RT was a joke for this kind of situation as it would only allow certain proprietary programs be downloaded and installed.
                      I was only commenting that was what I experienced with it alone. It had nothing to do with Mykle1’s walkthrough instructions, and I have not had any other Windows Tablets to try it with, But, I can say, that with any other Windows PC’s I have used his (Mykle1’s) walkthrough with has been done so without fail.
                      I’m sorry you all feel like I have no clue. But, I guess I’m just not meant to try to comment or help out with any of my experiences with all that I have tried and either met with failure or success.
                      I’m pretty sure the posts here have told me that I am nothing more than a dimbass to everyone. So, I guess this has opened my eyes that I am not welcome here anymore. :pensive_face:
                      Jim Hallock - 1995
                        bhepler Module Developer @justjim1220
                        This seems to be a strong reaction to the thread. I wouldn’t let it bother you that much. And I would hate to see a module developer leave.
                        That Surface RT sounds like it was locked down to within and inch of its life. Did you ever get anything interesting to work on it?
                          roxx
                          Hello everyone!!
                          Friends, i am able to pinch and zoom in and zoom out in MM… is this normal??🤔🤔 … on my touchscreen windows tablet, while MM is running, i could zoom in & out, like we do with our pictures on our android mobile, gallery app, same thing…
                          Havent read anywhere about zooming in/out so i feel its not normal…
                          Video:https://drive.google.com/file/d/1KuSX0BZgdn48rbHTTupZ3Bmt-ZI7YZTc/view?usp=drivesdk
                            @roxx - Well… the Magic Mirror framework is a web application at heart. Whether you’re viewing it via Chromium or Electron, it’s still just hosting a web page. So I think it’s normal. But I do think you’re the first person to try pinch zooming on a mirror.
                              roxx @bhepler
                              @bhepler
                              Thanks!! I guess it good that i could zoom so we could read if something comes up too small!! 😃
                                roxx
                                Hello…!!
                                Is it possible to run MM and also edit the config.js?? So that we could see the changes instantly… or atleast something like that…
                                i cant access any thing on my touchscreen tablet once MM is started… i have to kill its process then i could come back to open windows, explorer, IE, notepad, etc… Because i have to start and kill MM hundred times after each time i edit the config.js file… Many times i make mistakes in the code, modules, typing and it doesn’t work…
                                  @roxx - Try installing the MMM-RemoteControl module and the associated mobile phone app. It should let you change/install all sorts of things from your phone.
                                  I don’t think Win8.1 enables RDP, so I think you would have to install either a VNC or SSH host on your tablet. That would let you have access to the file system from your regular computer to change your config.js. You can just hit your tablet from the web browser on your desktop/laptop in order to evaluate the config. Once you make a change, just refresh your browser.
                                    roxx @bhepler
                                    … oh okay. Thanks, will try it…
                                      @roxx - Oh wait! I just had a thought. You can share the MagicMirror/config folder on your tablet, so long as you turn on network discovery (which I believe was still a feature in 8.1). You can then access the config.js file from any other windows machine by opening a file explorer window and typing \\[tablet name]\. The config folder should be visible as a shared folder.
                                      Edit the config.js file, save it and then refresh your web browser. That will give you most of what you’re looking for. The more complicated modules that require the node_helper will require a process restart.
                                        roxx @bhepler
                                        @bhepler
                                        Thanks, but i dont have my laptop currently… well so i will need to do it just with the tablet for now…
                                        I have still lot to do & learn with modules and config.js… Still need to merge my google Calendar with my events and default google Calendar with public holidays…
                                        Now, 8" screen is small to fit all these modules: clock, weather current, weather forecast, calendar, news.
                                        Thats it… and ya, Magic Mirror loads, runs only when wifi is connected… else i get an error when i input npm start command without wifi connection… that doesn’t seem a big problem anyway…
                                        I added google news feed but does anyone know how to make the fonts bigger?? The news lines looks small to read…
                                          roxx
                                          A new problem now, with Email module!!
                                          it always says loading and MM shuts down after few mins…
                                          I installed email module:https://github.com/ronny3050/email-mirror
                                          I want MM to show my Gmail… please tell me whats wrong…
                                          Here is my config…
                                          		module: 'email',
                                                          position: 'bottom_left',
                                                          header: 'Email',
                                                              accounts: [
        user: 'roxx.kkkkk@gmail.com',
        password: 'qwertyzzz',
        host: 'imap.gmail.com',
        port: 993,
        tls: true,
        authTimeout: 10000,
        numberOfEmails: 8,
                                                              fade: true,
                                                              maxCharacters: 30
                                          The first time I did, I received email about sign in blocked… so I clicked (it was me) in that email… but still my emails doesn’t load and MM shuts down after about 3-5mins…
                                            roxx
                                            Final Update!!
                                            I had borrowed the tablet for few days and wished to buy if everything with MM went well… but i returned it back as i had problems with email module… and after adding all the modules i wanted, 8" screen felt much smaller and it didnt seemed that good, bigger screen is good i think… so i gave up… now i am working with Rpi 3B+ to set up MM… thanks friends for helping me out…!
                                            justjim1220J 1 Reply Last reply Reply Quote 0
