    I am stuck need help
    25 Posts 11 Posters 15.2k Views 10 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      in his case, it was simply horrible config.js layout. Missing syntax all over the place.
      cd ~/MagicMirror
      npm run config:check
      cd ~
      Best script ever right there. I can’t express how important that is.
        dcarls91 @sdetweil
        the issues honestly are having little to no coding experience, and not knowing where commas and brackets go. Luckily, someone helped fixed my config file.
        I also ran into an issue with installing the modules. I did not realize at first that after you git clone the module you have to go into the module directory and run npm install command. After reading into it, it was a very simple fix.
        Most of my issues were from inexperience and being overwhelmed.
          Mykle1 Project Sponsor Module Developer @dcarls91
          @dcarls91 said in I am stuck need help:
          Dude, do your victory dance now! :clap:
          • lavolp3L Offline
            lavolp3 Module Developer @yawns
            @yawns said in I am stuck need help:
            https://www.diffchecker.com/QQhBPpNO
            You’re full of valuable links!!! :-)
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • evroomE Offline
              evroom
              I posted this in another thread too.
              For beginners, the catchphrase is “JSON syntax”.
              There are many articles to be found, both short and lengthy.
              A small article would be:
              https://restfulapi.net/json-syntax/
              The main things to look for in your config.js file are:
              • does every [ have a matching ]
              • are all arrays separated by a , (the last array does not need a ,)
              • does every { have a matching }
              • are all objects separated by a , (the last object does not need a ,)
              • is every name value pair separated by a ,
              The syntax checker will try to find out if this syntax is correct and tries to predict where the error could be.
              So, when it says it saw a [ and it cannot find a matching ] it tells you what was expected and what it saw.
              Try to format you config.js to make it more visible.
              For example this:
              is better written like this:
              Pairs of [ ]and { } are better visible like this.
              Good luck :-)
              MagicMirror version: 2.37.0
