    NOAA v3 using too many requests?
    28 Posts 4 Posters 14.8k Views 4 Watching
    • M
      motdog
      Re: MMM-NOAA V3.0 doesn't see anything
      The past 2 days I have lost weather access because I am using over 1000 requests via dark sky api. Nothing has changed in my config so I am wondering if other folks are having issues with this api or module
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @motdog
        @motdog
        Not me, sir. This picture represents the usage of 2 weather modules, MMM-NOAA3 and MMM-BMW-DS.
          sdetweil @Mykle1
          @Mykle1 are some people sharing keys?
          • Mykle1M
            I don’t know. That is certainly possible and it would definitely account for issue in this topic. I use my key in both modules and as you can see I don’t have such a problem.
            • M
              motdog
              I’m not sharing a key as far as I know. My usage just skyrocketed which was surprising. I switched from dark sky to another provider & all is well. Tomorrow I’ll get a new key from darksky and see what happens. Just seemed weird to me
              • Mykle1M
                @motdog
                Yeah, that’s a good idea. Let us know the result with the new key.
                • M
                  motdog @Mykle1
                  So the weather with weather underground hasn’t updated since yesterday. I looked at my stats and they were super high for yesterday. Seems the same as what happened before. Weird that random days trigger high requests.0_1552586737919_weather.PNG
                  Any thoughts? I’m going to switch back to darksky api to see what happens.
                  S Mykle1M 2 Replies Last reply Reply Quote 0
                    sdetweil @motdog
                    @motdog weather underground has been shutting down keys for over a year now. No new free keys are available. Time to switch to another weather solution.
                    • M
                      motdog @sdetweil
                      @sdetweil Thanks for the heads up. Still curious about the spike in requests. Had that with darksky too which is why I switched to weather underground.
                      • D
                        dazza120 @motdog
                        @motdog I had the same! Have you got a raspberry Pi? And is it locking up? I had this on mine it just kept dailing every second it was mad! Took off my Overclock that I had on the Pi and it’s working V well at the mo.
                        • Mykle1M
                          @motdog
                          I’m just curious (and I may have missed this) but have you changed the updateInterval: 30 * 60 * 1000, This is designed to constrain the module to 48 calls per day. Also, as a long shot, are you running more than one weather module using the same API key? I do.
                          • M
                            motdog @Mykle1
                            @Mykle1 I have not changed the update interval Is that in the css? I only have the one module running. What seems weird is that it runs fine then all of the sudden spikes.
                            • M
                              motdog @dazza120
                              @dazza120 I am running a Pi 3B the Pi doesn’t lock up. Occasionally if I try to do something a bit funky with a gif in the eye candy module it has but as soon as I use a different gif I am ok.
                              • D
                                dazza120 @motdog
                                @motdog not overclocked? My Pi would still work just ment that it was working overtime doing the weather connection every second.
                                • Mykle1M
                                  @motdog said in NOAA v3 using too many requests?:
                                  It is in the MMM-NOAA3.js file. Please verify the value. It can also be placed in the config entry which would override the module.js value.
                                  Have you gotten a new API key?
                                  Have your deleted you NOAA install and re-installed?
                                  Have you tried NOAA by itself? No other modules running, or at most just the defaults of MM?
                                  • M
                                    motdog @dazza120
                                    @dazza120 no clue.
                                    • M
                                      motdog @Mykle1
                                      @Mykle1 I haven’t modified the js file. I did get a new key. One thing I changed at darksky was to limit the number of requests. The default had me at 1000. I lowered it to 750 so I shouldn’t hit the maximum. I’ll give it a few days to monitor. The number of requests stays low most of the time but occasionally spikes up
                                      • Mykle1M
                                        Well, something is causing the module to fetch the data. I do not believe it’s the module itself based on your answers
                                        • M
                                          motdog @Mykle1
                                          @Mykle1 what should I look for? I had 475 requests today.
                                          • Mykle1M
                                            @motdog
                                            Are you absolutely sure that this is your setting in the config entry?
                                            Mykle1M M 2 Replies Last reply Reply Quote 0
