    MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
    66 Posts 19 Posters 57.3k Views 21 Watching
    • SnilleS Offline
      Snille Module Developer @Ivanov_d
      @ivanov_d Interesting, I’m not using SSL in HA (I have a Reverse-proxy) that SSL:s everything… So, internally I can get to HA via http (or https) but externally I’ll always go through the reverse-proxy (and SSL). However, the development MM works both with and without SSL. But my real MM now don’t work with either… Darn! :)
      What I CAN do, is use curl from ssh on the real MM and get the “status” from all sensors with this…
      curl -X GET -H "Authorization: Bearer VeRy-LoNg-API-ToKen" -H "Content-Type: application/json" http://ha-IP:8123/api/states
      And it lists everything… Hm…
      I 2 Replies Last reply Reply Quote 0
      • I Offline
        Ivanov_d @Snille
        @snille I think you struck the same obstacle as me, mate :D My setup is a bit different as I am not using reverse proxy - it is either SSL or no SSL within the local network and outside of it.
        I am looking at the JS code right now … it might have something to do with how the URL is structured as it might not cover both cases, but I have to confirm that.
        • I Offline
          Ivanov_d @Ivanov_d
          @Snille I think that I found out what the issue might be (at least for my case). I turned on debugging and here is what popped-up:
          0|MagicMirror  | [19.02.2022 12:34.16.715] [ERROR]
          0|MagicMirror  | MMM-homeassistant-sensors ERROR: Error: certificate has expired
          0|MagicMirror  |     at TLSSocket.onConnectSecure (_tls_wrap.js:1501:34)
          0|MagicMirror  |     at TLSSocket.emit (events.js:315:20)
          0|MagicMirror  |     at TLSSocket._finishInit (_tls_wrap.js:936:8)
          0|MagicMirror  |     at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:710:12) {
          0|MagicMirror  |   code: 'CERT_HAS_EXPIRED'
          0|MagicMirror  | }
          0|MagicMirror  | [19.02.2022 12:34.16.721] [ERROR]
          0|MagicMirror  | Whoops! There was an uncaught exception...
          0|MagicMirror  | [19.02.2022 12:34.16.727] [ERROR]
          0|MagicMirror  | TypeError: Cannot read property 'statusCode' of undefined
          0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_helper.js:22:77)
          0|MagicMirror  |     at self.callback (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/request/request.js:185:22)
          0|MagicMirror  |     at Request.emit (events.js:315:20)
          0|MagicMirror  |     at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/request/request.js:877:8)
          0|MagicMirror  |     at ClientRequest.emit (events.js:315:20)
          0|MagicMirror  |     at TLSSocket.socketErrorListener (_http_client.js:426:9)
          0|MagicMirror  |     at emitErrorNT (internal/streams/destroy.js:92:8)
          0|MagicMirror  |     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
          0|MagicMirror  |     at processTicksAndRejections (internal/process/task_queues.js:84:21)
          The certificate is valid though:
          • I Offline
            Ivanov_d @Snille
            @snille said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
            curl -X GET -H “Authorization: Bearer VeRy-LoNg-API-ToKen” -H “Content-Type: application/json” http://ha-IP:8123/api/states
            Same here … I get all states with the following URLs:
            https://myhome.org:443/api/states
            https://myhome/api/states
            However, when I try to use the local IP I can’t and that is normal as the certificate is not for that domain:
            pi@raspberrypi:~ $ curl -X GET -H "Authorization: Bearer long-token" -H "Content-Type: application/json" https://192.168.1.19:443/api/states
            curl: (7) Failed to connect to 192.168.1.19 port 443: Connection refused
            pi@raspberrypi:~ $ curl -X GET -H "Authorization: Bearer long-token" -H "Content-Type: application/json" https://192.168.1.19:8123/api/states
            curl: (60) SSL: no alternative certificate subject name matches target host name '192.168.1.19'
            More details here: https://curl.haxx.se/docs/sslcerts.html
            curl failed to verify the legitimacy of the server and therefore could not
            establish a secure connection to it. To learn more about this situation and
            how to fix it, please visit the web page mentioned above.
            What is wierd though is that although using SSL, the default port is still 8123, however, the connection is secured
            SnilleS 1 Reply Last reply Reply Quote 0
            • SnilleS Offline
              @ivanov_d Interesting… Maybe it’s a package missing, but that would not explain why the non SSL connections would fail…
              I found another ting, if you don’t have the “clock” module enabled, the “moment.js” is not loaded, and therefore errors out my module (that uses the moment function)… So I have to fix that somehow as well… :)
              • I Offline
                Ivanov_d @Snille
                @snille in my case non-SSL connections don’t fail, only SSL ones. Any idea how to find which package might be missing or outdated? My coding skills are a bit rusty :D
                • SnilleS Offline
                  @ivanov_d Nah… Not really, never been down the SSL rabbit hole… :) I have just forked this module and “fixed” the things I needed… I hope someone else can give some tips (PR:s)… My javascript skills are not that great ether… :)
                  • SnilleS Offline
                    Snille Module Developer @Snille
                    Now it’s working again… On both mu mirrors… I don’t understand why… I fixed the “moment” problem at least, I hope… Pushed that… But I guess it’s still the SSL problems left. But I can’t replicate it. @Ivanov_d Where did you set the debug flag to get the errors?
                    • I Offline
                      Ivanov_d @Snille
                      @snille in the config.js:
                      • I Offline
                        Ivanov_d
                        I finally found out what the issue is. It was an electron bug that is fixed in MM v. 2.18 (I was using an older version). Now everything works.
                          proxxym
                          is posible to increase the size of fonts?
                          something like …small , medium, large…
                          Thanks,
                          • I Offline
                            Ivanov_d @proxxym
                            @proxxym
                            • cowboysdudeC Offline
                              Been working great for me! I had to change some entities today and it’s still chuggin along :)
                                proxxym @Ivanov_d
                                @Ivanov_d Thanks,
                                for me big font is to smal :).
                                an extra large font or something similar was needed
                                S I 2 Replies Last reply Reply Quote 0
                                  sdetweil @proxxym
                                  @proxxym I don’t know, but you can use the developers window to learn what needs to be changed, and test it out
                                  see
                                  https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1650634458947
                                  • I Offline
                                    Ivanov_d @proxxym
                                    @proxxym open the following file:
                                    ~/MagicMirror/modules/MMM-homeassistant-sensors/MMM-homeassistant-sensors.css
                                    find the following lines:
                                    .ha-small {
                                      font-size: 15px;
                                      line-height: 18px;
                                      font-weight: bold;
                                      color: #999
                                    .ha-normal {
                                      font-size: 20px;
                                      line-height: 25px;
                                      color: #999
                                    .ha-big {
                                      font-size: 22px;
                                      line-height: 26px;
                                      color: #999
                                    and either change the .ha-big font-size from 22px to something bigger (e.g. 30px, 36px, etc.)
                                    or add a completely separate style:
                                    .ha-extra-big {
                                      font-size: 36px;
                                      line-height: 30px;
                                      color: #999
                                    and change this in your config
                                    rowClass = 'extra-big'
                                      sdetweil @Ivanov_d
                                      @Ivanov_d OR the better way, never change files supplied by mm or a module(as this breaks upgrades or fix distribution). the system is designed to support your local changes
                                      edit ~/MagicMirror/css/custom.css
                                      (if it doesn’t exist, create it)
                                      add all those definitions but add the module name (and a space) in front of each
                                      .MMM-HomeAssistant-Sensors
                                      notice the leading dot
                                      I 1 Reply Last reply Reply Quote 2
                                      • I Offline
                                        Ivanov_d @sdetweil
                                        @sdetweil duly noted and agreed. That approach is the right one.
                                          This goes into your custom.css file in the css directory.
                                          You can change size, color, font weight and line height. You may need to make changes to these depending on how you want it to look.
                                          Remember when you change the font size you’ll need to change line-height size as well… Line height should be bigger then font size ;)
                                          .MMM-HomeAssistant-Sensors .ha-small {
                                            font-size: 22px;
                                            line-height: 18px;
                                            font-weight: bold;
                                            color: #fff
                                          .MMM-HomeAssistant-Sensors .ha-normal {
                                            font-size: 30px;
                                            line-height: 25px;
                                            color: #fff
                                          .MMM-HomeAssistant-Sensors .ha-big {
                                            font-size: 42px;
                                            line-height: 26px;
                                            color: #fff
                                          • luisestradaL Offline
                                            luisestrada
                                            Hi, this is not an issue but a question. I have a bunch of lights and I’d like to hide them when they are off, just to show them when they are on.
                                            Is this possible?
                                            • 3 / 4
