    MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
    66 Posts 19 Posters 49.5k Views 21 Watching
    • I Offline
      Ivanov_d @Ivanov_d
      @Snille I think that I found out what the issue might be (at least for my case). I turned on debugging and here is what popped-up:
      0|MagicMirror  | [19.02.2022 12:34.16.715] [ERROR]
      0|MagicMirror  | MMM-homeassistant-sensors ERROR: Error: certificate has expired
      0|MagicMirror  |     at TLSSocket.onConnectSecure (_tls_wrap.js:1501:34)
      0|MagicMirror  |     at TLSSocket.emit (events.js:315:20)
      0|MagicMirror  |     at TLSSocket._finishInit (_tls_wrap.js:936:8)
      0|MagicMirror  |     at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:710:12) {
      0|MagicMirror  |   code: 'CERT_HAS_EXPIRED'
      0|MagicMirror  | }
      0|MagicMirror  | [19.02.2022 12:34.16.721] [ERROR]
      0|MagicMirror  | Whoops! There was an uncaught exception...
      0|MagicMirror  | [19.02.2022 12:34.16.727] [ERROR]
      0|MagicMirror  | TypeError: Cannot read property 'statusCode' of undefined
      0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_helper.js:22:77)
      0|MagicMirror  |     at self.callback (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/request/request.js:185:22)
      0|MagicMirror  |     at Request.emit (events.js:315:20)
      0|MagicMirror  |     at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/request/request.js:877:8)
      0|MagicMirror  |     at ClientRequest.emit (events.js:315:20)
      0|MagicMirror  |     at TLSSocket.socketErrorListener (_http_client.js:426:9)
      0|MagicMirror  |     at emitErrorNT (internal/streams/destroy.js:92:8)
      0|MagicMirror  |     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
      0|MagicMirror  |     at processTicksAndRejections (internal/process/task_queues.js:84:21)
      The certificate is valid though:
      • I Offline
        Ivanov_d @Snille
        @snille said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
        curl -X GET -H “Authorization: Bearer VeRy-LoNg-API-ToKen” -H “Content-Type: application/json” http://ha-IP:8123/api/states
        Same here … I get all states with the following URLs:
        https://myhome.org:443/api/states
        https://myhome/api/states
        However, when I try to use the local IP I can’t and that is normal as the certificate is not for that domain:
        pi@raspberrypi:~ $ curl -X GET -H "Authorization: Bearer long-token" -H "Content-Type: application/json" https://192.168.1.19:443/api/states
        curl: (7) Failed to connect to 192.168.1.19 port 443: Connection refused
        pi@raspberrypi:~ $ curl -X GET -H "Authorization: Bearer long-token" -H "Content-Type: application/json" https://192.168.1.19:8123/api/states
        curl: (60) SSL: no alternative certificate subject name matches target host name '192.168.1.19'
        More details here: https://curl.haxx.se/docs/sslcerts.html
        curl failed to verify the legitimacy of the server and therefore could not
        establish a secure connection to it. To learn more about this situation and
        how to fix it, please visit the web page mentioned above.
        What is wierd though is that although using SSL, the default port is still 8123, however, the connection is secured
        SnilleS 1 Reply Last reply Reply Quote 0
        • SnilleS Offline
          Snille Module Developer @Ivanov_d
          @ivanov_d Interesting… Maybe it’s a package missing, but that would not explain why the non SSL connections would fail…
          I found another ting, if you don’t have the “clock” module enabled, the “moment.js” is not loaded, and therefore errors out my module (that uses the moment function)… So I have to fix that somehow as well… :)
          If you cant find it, make it and share it!
          Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
          • I Offline
            Ivanov_d @Snille
            @snille in my case non-SSL connections don’t fail, only SSL ones. Any idea how to find which package might be missing or outdated? My coding skills are a bit rusty :D
            • SnilleS Offline
              @ivanov_d Nah… Not really, never been down the SSL rabbit hole… :) I have just forked this module and “fixed” the things I needed… I hope someone else can give some tips (PR:s)… My javascript skills are not that great ether… :)
              • SnilleS Offline
                Snille Module Developer @Snille
                Now it’s working again… On both mu mirrors… I don’t understand why… I fixed the “moment” problem at least, I hope… Pushed that… But I guess it’s still the SSL problems left. But I can’t replicate it. @Ivanov_d Where did you set the debug flag to get the errors?
                • I Offline
                  Ivanov_d @Snille
                  @snille in the config.js:
                  • I Offline
                    Ivanov_d
                    I finally found out what the issue is. It was an electron bug that is fixed in MM v. 2.18 (I was using an older version). Now everything works.
                      proxxym
                      is posible to increase the size of fonts?
                      something like …small , medium, large…
                      Thanks,
                      • I Offline
                        Ivanov_d @proxxym
                        @proxxym
                        • 5 / 7
