    MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
    66 Posts 19 Posters 59.8k Views 21 Watching
    • SnilleS
      Snille Module Developer @Ivanov_d
      @ivanov_d Strange… I’m running HA on it’s own machine and MM on it’s own machine as well, don’t know if that matters… The HA module works on both my “Development” build and the “Real” mirror…
      Oh, I’m NOT using a password for the API, that has in deed been deprecated…
      This is my “top” part of the Module:
      	disabled: false,
      	module: 'MMM-homeassistant-sensors',
      	hiddenOnStartup: true,
      	position: 'top_center',
      	classes: "Me Work Weather",
      		host: "X.X.X.X",
      		port: "8123",
      		https: false,
      		title: "Information",
      		updateInterval: 60000,
      		fade: 0,
      		token: "Very-Long-MM-Token...",
      		values:
      When did it stop working?
      I 1 Reply Last reply
      • I
        Ivanov_d @Snille
        @snille it stopped working after HA version 2021.10 when the API discovery feature was deprecated. I am running HA Supervised on one raspberry pi and MM on another raspberry pi in the same network.
        Here is the config of the MM module:
          position: 'top_right',
            title:  'Сензори',
            rowClass: 'normal',
            host: "192.168.1.19",
            port: "8123",
            https: true, //I have SSL enables since my instance is exposed to the Internet
            token: "here_goes_my_token",
            values: [
                sensor: "sensor.bathroom_temp_temperature",
                icons: [{
                  "default": "thermometer"
                sensor: "sensor.bathroom_temp_humidity",
                icons: [{
                  "default": "water-percent"
                sensor: "switch.bathroom_fan_1",
                icons: [{
                  "on": "fan",
                  "off": "fan-off"
                replace: [{
                  "on": "вкл.",
                  "off": "изкл."
                sensor: "switch.bathroom_fan_2",
                icons: [{
                  "on": "fan",
                  "off": "fan-off"
                replace: [{
                  "on": "вкл.",
                  "off": "изкл."
        Here is the changelog of HA 2021.10:
        The API endpoint /api/discovery_info now only return blank values. This endpoint is scheduled to be removed in Home Assistant Core 2022.1.
        As a regular user of Home Assistant, this change should not affect you.
        (@ludeeus - #56097) (api docs)
        In the past I was having issues with https and the local IP address and then I changed it to the DNS hostname blabla.duckdsn.org and the external port for https (443) and it was working fine until the /api/discovery_info endpoint was deprecated.
        SnilleS 1 Reply Last reply
        • cowboysdudeC
          cowboysdude Module Developer @Snille
          @snille Well that’s really not a deal breaker. It works and gaps the bridge. It’s a great module!
          • SnilleS
            @ivanov_d It’s still working for me, when using https. It got to be something else…
            I changed my conf to this and it works…
            	disabled: false,
            	hiddenOnStartup: false,
            		host: "my.ha.url.com",
            		port: "443",
            		https: true,
            		fade: 0,
            		noaddress: "Away",
            		token: "token...",
            		values: [
            				sensor: "sensor.living_room_temperature",
            				name: "Temp i Vardagsrummet %t%",
            				icons: [{
            I’m on Hass.IO (from start), maybe the api is still active there? I don’t get it…
            It does not work for me on port 8123, but that’s to be expected when using ssl.
            • I
              Ivanov_d @Snille
              @snille what is the most up-to-date code repo? The one that I pulled from is https://github.com/theskyisthelimit/MMM-homeassistant-sensors.git
              Could it be that I have an old code base? I tried with different ports, URL/IP, still the same and still no errors in both logs HA or MM …
              EDIT: I tried with another HA instance that I have which doesn’t have SSL enabled and it worked, so now I need to figure out what the difference between the two are :)
              Will keep you posted.
              • SnilleS
                @ivanov_d Hmm… In my own adventures to find what’s going on, I managed to “break” my real mirror connection to HA (now getting the fetch-error) but my development mirror is still working (against the same HA instance).
                I don’t understand what’s going on. :)
                As for codebase I’m using my own fork: https://github.com/Snille/MMM-homeassistant-sensors.git
                Let me know if you get it to work again… :)
                • I
                  Ivanov_d @Snille
                  @snille lol sorry to hear that. I managed to get it to work on my main HA instance by removing SSL from my HA configuration.yaml file:
                  However, that doesn’t suit my needs as I control my house through my phone over the Internet and I want SSL to be enabled. I am continuing testing. Will keep you posted.
                  • SnilleS
                    @ivanov_d Interesting, I’m not using SSL in HA (I have a Reverse-proxy) that SSL:s everything… So, internally I can get to HA via http (or https) but externally I’ll always go through the reverse-proxy (and SSL). However, the development MM works both with and without SSL. But my real MM now don’t work with either… Darn! :)
                    What I CAN do, is use curl from ssh on the real MM and get the “status” from all sensors with this…
                    curl -X GET -H "Authorization: Bearer VeRy-LoNg-API-ToKen" -H "Content-Type: application/json" http://ha-IP:8123/api/states
                    And it lists everything… Hm…
                    I 2 Replies Last reply
                    • I
                      Ivanov_d @Snille
                      @snille I think you struck the same obstacle as me, mate :D My setup is a bit different as I am not using reverse proxy - it is either SSL or no SSL within the local network and outside of it.
                      I am looking at the JS code right now … it might have something to do with how the URL is structured as it might not cover both cases, but I have to confirm that.
                      • I
                        Ivanov_d @Ivanov_d
                        @Snille I think that I found out what the issue might be (at least for my case). I turned on debugging and here is what popped-up:
                        0|MagicMirror  | [19.02.2022 12:34.16.715] [ERROR]
                        0|MagicMirror  | MMM-homeassistant-sensors ERROR: Error: certificate has expired
                        0|MagicMirror  |     at TLSSocket.onConnectSecure (_tls_wrap.js:1501:34)
                        0|MagicMirror  |     at TLSSocket.emit (events.js:315:20)
                        0|MagicMirror  |     at TLSSocket._finishInit (_tls_wrap.js:936:8)
                        0|MagicMirror  |     at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:710:12) {
                        0|MagicMirror  |   code: 'CERT_HAS_EXPIRED'
                        0|MagicMirror  | }
                        0|MagicMirror  | [19.02.2022 12:34.16.721] [ERROR]
                        0|MagicMirror  | Whoops! There was an uncaught exception...
                        0|MagicMirror  | [19.02.2022 12:34.16.727] [ERROR]
                        0|MagicMirror  | TypeError: Cannot read property 'statusCode' of undefined
                        0|MagicMirror  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_helper.js:22:77)
                        0|MagicMirror  |     at self.callback (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/request/request.js:185:22)
                        0|MagicMirror  |     at Request.emit (events.js:315:20)
                        0|MagicMirror  |     at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_modules/request/request.js:877:8)
                        0|MagicMirror  |     at ClientRequest.emit (events.js:315:20)
                        0|MagicMirror  |     at TLSSocket.socketErrorListener (_http_client.js:426:9)
                        0|MagicMirror  |     at emitErrorNT (internal/streams/destroy.js:92:8)
                        0|MagicMirror  |     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
                        0|MagicMirror  |     at processTicksAndRejections (internal/process/task_queues.js:84:21)
                        The certificate is valid though:
                        • I
                          Ivanov_d @Snille
                          @snille said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
                          curl -X GET -H “Authorization: Bearer VeRy-LoNg-API-ToKen” -H “Content-Type: application/json” http://ha-IP:8123/api/states
                          Same here … I get all states with the following URLs:
                          https://myhome.org:443/api/states
                          https://myhome/api/states
                          However, when I try to use the local IP I can’t and that is normal as the certificate is not for that domain:
                          pi@raspberrypi:~ $ curl -X GET -H "Authorization: Bearer long-token" -H "Content-Type: application/json" https://192.168.1.19:443/api/states
                          curl: (7) Failed to connect to 192.168.1.19 port 443: Connection refused
                          pi@raspberrypi:~ $ curl -X GET -H "Authorization: Bearer long-token" -H "Content-Type: application/json" https://192.168.1.19:8123/api/states
                          curl: (60) SSL: no alternative certificate subject name matches target host name '192.168.1.19'
                          More details here: https://curl.haxx.se/docs/sslcerts.html
                          curl failed to verify the legitimacy of the server and therefore could not
                          establish a secure connection to it. To learn more about this situation and
                          how to fix it, please visit the web page mentioned above.
                          What is wierd though is that although using SSL, the default port is still 8123, however, the connection is secured
                          • SnilleS
                            @ivanov_d Interesting… Maybe it’s a package missing, but that would not explain why the non SSL connections would fail…
                            I found another ting, if you don’t have the “clock” module enabled, the “moment.js” is not loaded, and therefore errors out my module (that uses the moment function)… So I have to fix that somehow as well… :)
                            • I
                              Ivanov_d @Snille
                              @snille in my case non-SSL connections don’t fail, only SSL ones. Any idea how to find which package might be missing or outdated? My coding skills are a bit rusty :D
                              • SnilleS
                                @ivanov_d Nah… Not really, never been down the SSL rabbit hole… :) I have just forked this module and “fixed” the things I needed… I hope someone else can give some tips (PR:s)… My javascript skills are not that great ether… :)
                                • SnilleS
                                  Snille Module Developer @Snille
                                  Now it’s working again… On both mu mirrors… I don’t understand why… I fixed the “moment” problem at least, I hope… Pushed that… But I guess it’s still the SSL problems left. But I can’t replicate it. @Ivanov_d Where did you set the debug flag to get the errors?
                                  • I
                                    Ivanov_d @Snille
                                    @snille in the config.js:
                                    • I
                                      Ivanov_d
                                      I finally found out what the issue is. It was an electron bug that is fixed in MM v. 2.18 (I was using an older version). Now everything works.
                                        proxxym
                                        is posible to increase the size of fonts?
                                        something like …small , medium, large…
                                        Thanks,
                                        • I
                                          Ivanov_d @proxxym
                                          @proxxym
                                          P 1 Reply Last reply
                                          • cowboysdudeC
                                            Been working great for me! I had to change some entities today and it’s still chuggin along :)
                                            • 3 / 4
