    remoteFile in compliments module
    71 Posts 14 Posters 95.2k Views 15 Watching
    • bheplerB Offline
      bhepler Module Developer @Guest
      @skr I have it running, but then again I developed the remote file capability. So “it works on my machine” is accurate, but not exactly helpful. :)
      One thing I was not able to get working properly was making the array names work the same way between the config.js and the external file. You must surround the array names (morning, evening, afternoon) with quotes in the external file. This is different then how work in the config.js. This catches a few people. Check out the compliments module documentation for examples.
      If that’s not your issue, post the compliments config from your config.js and your external file here and I’ll take a look at it.
      schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
      • schlachtkreuzer6S Offline
        schlachtkreuzer6 @bhepler
        @bhepler HOW???
        @schlachtkreuzer6 said in Compliments - remoteFile - How to?!:
        Hey guys, i need some help with the remoteFile for the compliments. I tried this:
        module: 'compliments',
                          position: 'lower_third',
                              updateInterval: 15000,
                              compliments: {
                              remoteFile: '~/MagicMirror/modules/default/compliments/remote_compliments.json',
                              morning: [
                                                 'Guten Morgen!',
                                                 'Wie hast du geschlafen?',
                                                 'Ich wünsche dir einen schönen Tag!'
        but it´s not working.
        Content of remote_compliments.json:
                    "morning" : [
                          "Du siehst aber gut aus heute !",
                          "Gut geschlafen ?",
                          "Moin, Moin...."
                     "afternoon" : [
                         "Ab Fussball spielen !",
                         "Lass uns auf den Abend vorbereiten....",
                          "Musik hören ?"
                     "evening" : [
                          "Einen Cocktail ?",
                          "Wow, Du bist aber heiss heute...",
                          "Wollen wir heute abend weggehen ?"
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @schlachtkreuzer6
          @schlachtkreuzer6 your json file looks good to me, but i would try to change your config
              remoteFile: 'remote_compliments.json'
          1. the remoteFile has to be in the config object and not nested in the compliments object
          2. it makes no sense to have another compliments in the config, because those will be completely overwritten by using a remoteFile
          3. after a look in the code, it uses this.file(this.config.remoteFile) which will generate the correct path, so if you place the remotefile in the compliments directory you should only have to put the name with the extension in there.
            schlachtkreuzer6 @strawberry 3.141
            @strawberry-3.141 thanks for your advice, i tried it but nope ^^
            If i only use the remote file, MM stuck loading the other modules down blow. so first, alert, cock, clalendar, compliments but the modules later on are not showing up.
              "module": "compliments",
              "position": "lower_third",
              "config": {
                "compliments": {
                  "remoteFile": "remote_compliments.json",
                  "morning": [
                    "Guten Morgen!",
                    "Wie hast du geschlafen?",
                    "Ich wünsche dir einen schönen Tag!"
                  "afternoon": [
                    "Guten Tag!",
                    "Du schaust gut aus!",
                    "Wie war dein Tag!"
                  "evening": [
                    "Guten Abend!",
                    "Na wie war dein Tag?",
                    "Du warst heute fleßig!"
                "updateInterval": 15000
                  "morning": [
                      "Test1!",
                      "Test2?",
                      "Test3!"
                 "afternoon": [
                      "Test4!",
                      "Test5!",
                      "Test6!"
                 "evening": [
                       "Test7!",
                       "Test8?",
                       "Test9!"
              @schlachtkreuzer6 do you get any errors in the electron console?
                @strawberry-3.141 how to open the electron console to see those errors? I’m not an expert, sry
                  @schlachtkreuzer6 either start with npm start dev or press cmd+shift+i during runtime
                    jcorraliza
                    Hi there, just want to add that I am also unable to get the remoteFile to work. I have it configured as specified above using the currentweather items, but my mirror still shows the default phrases.
                      strawberry 3.141 Project Sponsor Module Developer @jcorraliza
                      @jcorraliza can you show your config for compliments module and the path where you placed the file?
                        jcorraliza @strawberry 3.141
                        @strawberry-3.141 Sure, I placed the compliments.json file in ~/MagicMirror/modules/default/compliments directory.
                        My config.js is as follows:
                                                        remoteFile: 'compliments.json'
                        My compliments.json file is set up with currentweather arrays:
                        	"day_sunny" : [
                        	        "The sun is shining today!",
                                	"It\'s such a beautiful day",
                        		"It\'s gorgeous outside, go play!"
                            	"day_cloudy" : [
                        		"It\'s cloudy out there, but no meatballs",
                        		"It may be cloudy, but it\'s still nice out!",
                        		"The sun is hiding right now"
                        	"cloudy" : [
                                	"Good morning, sunshine!",
                                	"Who needs coffee when you have your smile?",
                                	"Go get 'em, Tiger!"
                        	"cloudy_windy" : [
                        	"showers" : [
                        	"rain" : [
                                	"Take your umbrella with you.",
                                	"It's wet out there, drive safe!",
                        	        "It's rainy outside, but you brighten my day."
                        	"thunderstorm" : [
                        	"fog" : [
                            	"night_clear" : [
                          		"You made someone smile today, I know it.",
                               		"You are making a difference.",
                                	"The day was better for your efforts."
                        	"night_cloudy" : [
                        	"night_showers" : [
                        	"night_rain" : [
                        	"night_thunderstorm" : [
                                	"It\'s a stormy night, don\'t be scared",
                                	"Thunderstorms tonight, Oliver\'s covering his ears"
                        	"night_alt_cloudy_windy" : [
                        I started filling in custom messages, then decided to copy/paste them all just in case it didn’t work. See anything I’m doing wrong? Thanks!
                        • 1 / 8
