    remoteFile in compliments module
    71 Posts 14 Posters 100.1k Views 15 Watching
    • schlachtkreuzer6S Offline
      schlachtkreuzer6 @bhepler
      @bhepler HOW???
      @schlachtkreuzer6 said in Compliments - remoteFile - How to?!:
      Hey guys, i need some help with the remoteFile for the compliments. I tried this:
      module: 'compliments',
                        position: 'lower_third',
                            updateInterval: 15000,
                            compliments: {
                            remoteFile: '~/MagicMirror/modules/default/compliments/remote_compliments.json',
                            morning: [
                                               'Guten Morgen!',
                                               'Wie hast du geschlafen?',
                                               'Ich wünsche dir einen schönen Tag!'
      but it´s not working.
      Content of remote_compliments.json:
                  "morning" : [
                        "Du siehst aber gut aus heute !",
                        "Gut geschlafen ?",
                        "Moin, Moin...."
                   "afternoon" : [
                       "Ab Fussball spielen !",
                       "Lass uns auf den Abend vorbereiten....",
                        "Musik hören ?"
                   "evening" : [
                        "Einen Cocktail ?",
                        "Wow, Du bist aber heiss heute...",
                        "Wollen wir heute abend weggehen ?"
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @schlachtkreuzer6
        @schlachtkreuzer6 your json file looks good to me, but i would try to change your config
            remoteFile: 'remote_compliments.json'
        1. the remoteFile has to be in the config object and not nested in the compliments object
        2. it makes no sense to have another compliments in the config, because those will be completely overwritten by using a remoteFile
        3. after a look in the code, it uses this.file(this.config.remoteFile) which will generate the correct path, so if you place the remotefile in the compliments directory you should only have to put the name with the extension in there.
        schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
          schlachtkreuzer6 @strawberry 3.141
          @strawberry-3.141 thanks for your advice, i tried it but nope ^^
          If i only use the remote file, MM stuck loading the other modules down blow. so first, alert, cock, clalendar, compliments but the modules later on are not showing up.
            "module": "compliments",
            "position": "lower_third",
            "config": {
              "compliments": {
                "remoteFile": "remote_compliments.json",
                "morning": [
                  "Guten Morgen!",
                  "Wie hast du geschlafen?",
                  "Ich wünsche dir einen schönen Tag!"
                "afternoon": [
                  "Guten Tag!",
                  "Du schaust gut aus!",
                  "Wie war dein Tag!"
                "evening": [
                  "Guten Abend!",
                  "Na wie war dein Tag?",
                  "Du warst heute fleßig!"
              "updateInterval": 15000
                "morning": [
                    "Test1!",
                    "Test2?",
                    "Test3!"
               "afternoon": [
                    "Test4!",
                    "Test5!",
                    "Test6!"
               "evening": [
                     "Test7!",
                     "Test8?",
                     "Test9!"
            @schlachtkreuzer6 do you get any errors in the electron console?
              @strawberry-3.141 how to open the electron console to see those errors? I’m not an expert, sry
                @schlachtkreuzer6 either start with npm start dev or press cmd+shift+i during runtime
                  jcorraliza
                  Hi there, just want to add that I am also unable to get the remoteFile to work. I have it configured as specified above using the currentweather items, but my mirror still shows the default phrases.
                    strawberry 3.141 Project Sponsor Module Developer @jcorraliza
                    @jcorraliza can you show your config for compliments module and the path where you placed the file?
                      jcorraliza @strawberry 3.141
                      @strawberry-3.141 Sure, I placed the compliments.json file in ~/MagicMirror/modules/default/compliments directory.
                      My config.js is as follows:
                                                      remoteFile: 'compliments.json'
                      My compliments.json file is set up with currentweather arrays:
                      	"day_sunny" : [
                      	        "The sun is shining today!",
                              	"It\'s such a beautiful day",
                      		"It\'s gorgeous outside, go play!"
                          	"day_cloudy" : [
                      		"It\'s cloudy out there, but no meatballs",
                      		"It may be cloudy, but it\'s still nice out!",
                      		"The sun is hiding right now"
                      	"cloudy" : [
                              	"Good morning, sunshine!",
                              	"Who needs coffee when you have your smile?",
                              	"Go get 'em, Tiger!"
                      	"cloudy_windy" : [
                      	"showers" : [
                      	"rain" : [
                              	"Take your umbrella with you.",
                              	"It's wet out there, drive safe!",
                      	        "It's rainy outside, but you brighten my day."
                      	"thunderstorm" : [
                      	"fog" : [
                          	"night_clear" : [
                        		"You made someone smile today, I know it.",
                             		"You are making a difference.",
                              	"The day was better for your efforts."
                      	"night_cloudy" : [
                      	"night_showers" : [
                      	"night_rain" : [
                      	"night_thunderstorm" : [
                              	"It\'s a stormy night, don\'t be scared",
                              	"Thunderstorms tonight, Oliver\'s covering his ears"
                      	"night_alt_cloudy_windy" : [
                      I started filling in custom messages, then decided to copy/paste them all just in case it didn’t work. See anything I’m doing wrong? Thanks!
                        @strawberry-3.141 Hey, hm i think something is wrong^^
                        pi@MagicMirror:~ $ npm start dev
                        npm ERR! Linux 4.4.37-v7+
                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                        npm ERR! node v6.9.2
                        npm ERR! npm  v3.10.9
                        npm ERR! code ENOENT
                        npm ERR! errno -2
                        npm ERR! syscall open
                        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                        npm ERR! enoent This is most likely not a problem with npm itself
                        npm ERR! enoent and is related to npm not being able to find a file.
                        npm ERR! enoent
                        npm ERR!     /home/pi/npm-debug.log
                        • yawnsY Offline
                          yawns Moderator @jcorraliza
                          @jcorraliza
                          Hi, I just tried on my computer …
                          snippit from my config.js
                          my compliments.json
                              "morning" : [
                                  "heyho"
                              "afternoon" : [
                                  "home early?"
                              "evening" : [
                                  "finally home"
                          	"fog" : [
                          		"fog, oh no :("
                          The compliments.json file is located in ~/MagicMirror/modules/default/compliments
                          Three things to mention:
                          1. Of course you need to use the default “currentweather” module
                          2. You need to run the new updated MagicMirror version. Otherwise compliments and currentweather are not interacting
                          3. There is a delay loading the compliments file. I added some debug output to track that and as you see MagicMirror starts with default values and takes 30 seconds to load and verify your remote file.0_1483870239034_compliments.PNG
                          • yawnsY Offline
                            yawns Moderator @schlachtkreuzer6
                            @schlachtkreuzer6
                            you are in your home directory, not in your MagicMirror folder.
                            Run cd MagicMirror first
                            schlachtkreuzer6S 1 Reply Last reply Reply Quote 1
                              schlachtkreuzer6 @yawns
                              @yawns oh, okay then i get this:
                              pi@MagicMirror:~/MagicMirror $ npm start dev
                              > magicmirror@2.1.0 start /home/pi/MagicMirror
                              > electron js/electron.js "dev"
                              npm ERR! code ELIFECYCLE
                              npm ERR! magicmirror@2.1.0 start: `electron js/electron.js "dev"`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js "dev"'.
                              npm ERR! If you do, this is most likely a problem with the magicmirror package,
                              npm ERR! not with npm itself.
                              npm ERR!     electron js/electron.js "dev"
                              npm ERR!     npm bugs magicmirror
                              npm ERR! Or if that isn't available, you can get their info via:
                              npm ERR!     npm owner ls magicmirror
                              npm ERR!     /home/pi/MagicMirror/npm-debug.log
                              npm-debug.log
                                GNU nano 2.2.6        File: npm-debug.log
                              1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start', 'dev' ]
                              2 info using npm@3.10.9
                              3 info using node@v6.9.2
                              5 info lifecycle magicmirror@2.1.0~prestart: magicmirror@2.1.0
                              6 silly lifecycle magicmirror@2.1.0~prestart: no script for prestart, continuing
                              7 info lifecycle magicmirror@2.1.0~start: magicmirror@2.1.0
                              8 verbose lifecycle magicmirror@2.1.0~start: unsafe-perm in lifecycle true
                              9 verbose lifecycle magicmirror@2.1.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                              10 verbose lifecycle magicmirror@2.1.0~start: CWD: /home/pi/MagicMirror
                              11 silly lifecycle magicmirror@2.1.0~start: Args: [ '-c', 'electron js/electron.js "dev"' ]
                              12 silly lifecycle magicmirror@2.1.0~start: Returned: code: 1  signal: null
                              13 info lifecycle magicmirror@2.1.0~start: Failed to exec start script
                              14 verbose stack Error: magicmirror@2.1.0 start: `electron js/electron.js "dev"`
                              14 verbose stack Exit status 1
                              14 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                              14 verbose stack     at emitTwo (events.js:106:13)
                              14 verbose stack     at EventEmitter.emit (events.js:191:7)
                              14 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                              14 verbose stack     at ChildProcess.emit (events.js:191:7)
                              14 verbose stack     at maybeClose (internal/child_process.js:877:16)
                              14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                              15 verbose pkgid magicmirror@2.1.0
                              16 verbose cwd /home/pi/MagicMirror
                              17 error Linux 4.4.37-v7+
                              18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                              19 error node v6.9.2
                              20 error npm  v3.10.9
                              21 error code ELIFECYCLE
                              22 error magicmirror@2.1.0 start: `electron js/electron.js "dev"`
                              22 error Exit status 1
                              23 error Failed at the magicmirror@2.1.0 start script 'electron js/electron.js "dev"'.
                              23 error Make sure you have the latest version of node.js and npm installed.
                              23 error If you do, this is most likely a problem with the magicmirror package,
                              23 error not with npm itself.
                              23 error Tell the author that this fails on your system:
                              23 error     electron js/electron.js "dev"
                              23 error You can get information on how to open an issue for this project with:
                              23 error     npm bugs magicmirror
                              23 error Or if that isn't available, you can get their info via:
                              23 error     npm owner ls magicmirror
                              23 error There is likely additional logging output above.
                              24 verbose exit [ 1, true ]
                                DvdEnde
                                Friends,
                                using version 2.1.0 you must have the remoteFile within the configuration of the compliments.js.
                                the file should start like this:
                                defaults: {
                                	updateInterval: 30000,
                                	remoteFile: 'put your file here',
                                	fadeSpeed: 4000
                                it is only working with a local file.
                                in my config/config.js i did not change anything for compliments module.
                                • yawnsY Offline
                                  yawns Moderator @DvdEnde
                                  @DvdEnde
                                  no, this information is wrong. And you should avoid modifying module files.
                                  Try what I have written above, it is working fine
                                    DvdEnde @yawns
                                    @yawns Sorry but your option did not work for me.
                                    Also please check the original compliment.js file:
                                    https://github.com/MichMich/MagicMirror/blob/develop/modules/default/compliments/compliments.js
                                    it is standard prepared there.
                                    Please also check line 50:
                                    if (this.config.remoteFile != null) {
                                    At first I also thought this would be the major config file, but it is not. Its the module.
                                    If you console.log(this.config) it will give you an object like this. All information from the compliment.js
                                        remoteFile: null,
                                        fadeSpeed: 4000
                                    That is why i think @schlachtkreuzer6 should give this a try.
                                    You have also the latest version?
                                    I understand that modules should not be changed.
                                    Just trying to help.
                                    Please do correct me if I am wrong!
                                    strawberry 3.141S schlachtkreuzer6S 2 Replies Last reply Reply Quote 0
                                      strawberry 3.141 Project Sponsor Module Developer @DvdEnde
                                      @DvdEnde the part from the config in the config.js overwrites the values in default with Object.assign()
                                      so when you define remoteFile in the config.js the null value is overwritten
                                      • yawnsY Offline
                                        yawns Moderator
                                        @DvdEnde Please don’t get me wrong, but this is basic javascript.
                                        this.config.remoteFile != null checks if the variable “remoteFile” is set in your config file. Afterwards you only have two scenarios:
                                        1. the variable is not set -> this if clause fails and no remote file is loaded.
                                        2. the variable is set to any value -> this if clause is true and the function complimentFile() is called, which tries to load the file defined in your config file, in my case “compliments.json”.
                                        If loading the remote file fails you see an error message in console output of your browser. Otherwise it does not produce any log.
                                          DvdEnde @yawns
                                          @yawns
                                          Don’t worry, i know it is basic javascript.
                                          @strawberry-3-141
                                          i thought so too, but it is NOT
                                          I just now changed the compliment.js (and deleted the remoteFile completly from here) and added this within the config.
                                          My object is simple
                                              fadeSpeed: 4000
                                          On line 33 console.log(this.config.remoteFile) = undefined
                                            jcorraliza @yawns
                                            @yawns OK I created a compliments_test.json file and pasted your example into it and it worked. It looks like it just doesn’t work with the currentweather objects in my compliments.json file for some reason. Do I need to nest the currentweather objects within the morning, afternoon, and evening arrays perhaps?
                                            • 1 / 4
