    remoteFile in compliments module
    71 Posts 14 Posters 109.9k Views 15 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @Guest
      @skr the remotefile is currently only supported in the develop branch
        A Former User
        perfect thanks, still finding my way around this world… will give the dev brach a try then. thanks!!
        • strawberry 3.141S
          @skr
          git fetch
          git checkout develop
          npm install
          Reply Quote 2
            A Former User
            hey,
            on the development branch it doesnt work either (git confirms i’m really on the dev branch and files also look like the ones on github). it defaults to the standard values in the module and seems to ignore the remote file argument – but I really dont know javascript (and lack the time atm to get into it), so cannot really debug it. does anyone have it up and running, just to make sure that I’m doing something wrong?
            thanks!
            Steffen
            bheplerB 1 Reply Last reply
            • bheplerB
              bhepler Module Developer @Guest
              @skr I have it running, but then again I developed the remote file capability. So “it works on my machine” is accurate, but not exactly helpful. :)
              One thing I was not able to get working properly was making the array names work the same way between the config.js and the external file. You must surround the array names (morning, evening, afternoon) with quotes in the external file. This is different then how work in the config.js. This catches a few people. Check out the compliments module documentation for examples.
              If that’s not your issue, post the compliments config from your config.js and your external file here and I’ll take a look at it.
              schlachtkreuzer6S 1 Reply Last reply
              • schlachtkreuzer6S
                schlachtkreuzer6 @bhepler
                @bhepler HOW???
                @schlachtkreuzer6 said in Compliments - remoteFile - How to?!:
                Hey guys, i need some help with the remoteFile for the compliments. I tried this:
                module: 'compliments',
                                  position: 'lower_third',
                                      updateInterval: 15000,
                                      compliments: {
                                      remoteFile: '~/MagicMirror/modules/default/compliments/remote_compliments.json',
                                      morning: [
                                                         'Guten Morgen!',
                                                         'Wie hast du geschlafen?',
                                                         'Ich wünsche dir einen schönen Tag!'
                but it´s not working.
                Content of remote_compliments.json:
                            "morning" : [
                                  "Du siehst aber gut aus heute !",
                                  "Gut geschlafen ?",
                                  "Moin, Moin...."
                             "afternoon" : [
                                 "Ab Fussball spielen !",
                                 "Lass uns auf den Abend vorbereiten....",
                                  "Musik hören ?"
                             "evening" : [
                                  "Einen Cocktail ?",
                                  "Wow, Du bist aber heiss heute...",
                                  "Wollen wir heute abend weggehen ?"
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @schlachtkreuzer6
                  @schlachtkreuzer6 your json file looks good to me, but i would try to change your config
                      remoteFile: 'remote_compliments.json'
                  1. the remoteFile has to be in the config object and not nested in the compliments object
                  2. it makes no sense to have another compliments in the config, because those will be completely overwritten by using a remoteFile
                  3. after a look in the code, it uses this.file(this.config.remoteFile) which will generate the correct path, so if you place the remotefile in the compliments directory you should only have to put the name with the extension in there.
                  • schlachtkreuzer6S
                    schlachtkreuzer6 @strawberry 3.141
                    @strawberry-3.141 thanks for your advice, i tried it but nope ^^
                    If i only use the remote file, MM stuck loading the other modules down blow. so first, alert, cock, clalendar, compliments but the modules later on are not showing up.
                      "module": "compliments",
                      "position": "lower_third",
                      "config": {
                        "compliments": {
                          "remoteFile": "remote_compliments.json",
                          "morning": [
                            "Guten Morgen!",
                            "Wie hast du geschlafen?",
                            "Ich wünsche dir einen schönen Tag!"
                          "afternoon": [
                            "Guten Tag!",
                            "Du schaust gut aus!",
                            "Wie war dein Tag!"
                          "evening": [
                            "Guten Abend!",
                            "Na wie war dein Tag?",
                            "Du warst heute fleßig!"
                        "updateInterval": 15000
                          "morning": [
                              "Test1!",
                              "Test2?",
                              "Test3!"
                         "afternoon": [
                              "Test4!",
                              "Test5!",
                              "Test6!"
                         "evening": [
                               "Test7!",
                               "Test8?",
                               "Test9!"
                    • strawberry 3.141S
                      @schlachtkreuzer6 do you get any errors in the electron console?
                      • schlachtkreuzer6S
                        @strawberry-3.141 how to open the electron console to see those errors? I’m not an expert, sry
                        • strawberry 3.141S
                          @schlachtkreuzer6 either start with npm start dev or press cmd+shift+i during runtime
                            jcorraliza
                            Hi there, just want to add that I am also unable to get the remoteFile to work. I have it configured as specified above using the currentweather items, but my mirror still shows the default phrases.
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @jcorraliza
                              @jcorraliza can you show your config for compliments module and the path where you placed the file?
                              J 1 Reply Last reply
                                jcorraliza @strawberry 3.141
                                @strawberry-3.141 Sure, I placed the compliments.json file in ~/MagicMirror/modules/default/compliments directory.
                                My config.js is as follows:
        remoteFile: 'compliments.json'
                                My compliments.json file is set up with currentweather arrays:
                                	"day_sunny" : [
                                	        "The sun is shining today!",
                                        	"It\'s such a beautiful day",
                                		"It\'s gorgeous outside, go play!"
                                    	"day_cloudy" : [
                                		"It\'s cloudy out there, but no meatballs",
                                		"It may be cloudy, but it\'s still nice out!",
                                		"The sun is hiding right now"
                                	"cloudy" : [
                                        	"Good morning, sunshine!",
                                        	"Who needs coffee when you have your smile?",
                                        	"Go get 'em, Tiger!"
                                	"cloudy_windy" : [
                                	"showers" : [
                                	"rain" : [
                                        	"Take your umbrella with you.",
                                        	"It's wet out there, drive safe!",
                                	        "It's rainy outside, but you brighten my day."
                                	"thunderstorm" : [
                                	"fog" : [
                                    	"night_clear" : [
                                  		"You made someone smile today, I know it.",
                                       		"You are making a difference.",
                                        	"The day was better for your efforts."
                                	"night_cloudy" : [
                                	"night_showers" : [
                                	"night_rain" : [
                                	"night_thunderstorm" : [
                                        	"It\'s a stormy night, don\'t be scared",
                                        	"Thunderstorms tonight, Oliver\'s covering his ears"
                                	"night_alt_cloudy_windy" : [
                                I started filling in custom messages, then decided to copy/paste them all just in case it didn’t work. See anything I’m doing wrong? Thanks!
                                yawnsY 1 Reply Last reply
                                • schlachtkreuzer6S
                                  @strawberry-3.141 Hey, hm i think something is wrong^^
                                  pi@MagicMirror:~ $ npm start dev
                                  npm ERR! Linux 4.4.37-v7+
                                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                                  npm ERR! node v6.9.2
                                  npm ERR! npm  v3.10.9
                                  npm ERR! code ENOENT
                                  npm ERR! errno -2
                                  npm ERR! syscall open
                                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                  npm ERR! enoent This is most likely not a problem with npm itself
                                  npm ERR! enoent and is related to npm not being able to find a file.
                                  npm ERR! enoent
                                  npm ERR!     /home/pi/npm-debug.log
                                  • yawnsY
                                    yawns Moderator @jcorraliza
                                    @jcorraliza
                                    Hi, I just tried on my computer …
                                    snippit from my config.js
                                    my compliments.json
                                        "morning" : [
                                            "heyho"
                                        "afternoon" : [
                                            "home early?"
                                        "evening" : [
                                            "finally home"
                                    	"fog" : [
                                    		"fog, oh no :("
                                    The compliments.json file is located in ~/MagicMirror/modules/default/compliments
                                    Three things to mention:
                                    1. Of course you need to use the default “currentweather” module
                                    2. You need to run the new updated MagicMirror version. Otherwise compliments and currentweather are not interacting
                                    3. There is a delay loading the compliments file. I added some debug output to track that and as you see MagicMirror starts with default values and takes 30 seconds to load and verify your remote file.0_1483870239034_compliments.PNG
                                    • yawnsY
                                      yawns Moderator @schlachtkreuzer6
                                      @schlachtkreuzer6
                                      you are in your home directory, not in your MagicMirror folder.
                                      Run cd MagicMirror first
                                      • schlachtkreuzer6S
                                        schlachtkreuzer6 @yawns
                                        @yawns oh, okay then i get this:
                                        pi@MagicMirror:~/MagicMirror $ npm start dev
                                        > magicmirror@2.1.0 start /home/pi/MagicMirror
                                        > electron js/electron.js "dev"
                                        npm ERR! code ELIFECYCLE
                                        npm ERR! magicmirror@2.1.0 start: `electron js/electron.js "dev"`
                                        npm ERR! Exit status 1
                                        npm ERR!
                                        npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js "dev"'.
                                        npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                        npm ERR! not with npm itself.
                                        npm ERR!     electron js/electron.js "dev"
                                        npm ERR!     npm bugs magicmirror
                                        npm ERR! Or if that isn't available, you can get their info via:
                                        npm ERR!     npm owner ls magicmirror
                                        npm ERR!     /home/pi/MagicMirror/npm-debug.log
                                        npm-debug.log
                                          GNU nano 2.2.6        File: npm-debug.log
                                        1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start', 'dev' ]
                                        2 info using npm@3.10.9
                                        3 info using node@v6.9.2
                                        5 info lifecycle magicmirror@2.1.0~prestart: magicmirror@2.1.0
                                        6 silly lifecycle magicmirror@2.1.0~prestart: no script for prestart, continuing
                                        7 info lifecycle magicmirror@2.1.0~start: magicmirror@2.1.0
                                        8 verbose lifecycle magicmirror@2.1.0~start: unsafe-perm in lifecycle true
                                        9 verbose lifecycle magicmirror@2.1.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                        10 verbose lifecycle magicmirror@2.1.0~start: CWD: /home/pi/MagicMirror
                                        11 silly lifecycle magicmirror@2.1.0~start: Args: [ '-c', 'electron js/electron.js "dev"' ]
                                        12 silly lifecycle magicmirror@2.1.0~start: Returned: code: 1  signal: null
                                        13 info lifecycle magicmirror@2.1.0~start: Failed to exec start script
                                        14 verbose stack Error: magicmirror@2.1.0 start: `electron js/electron.js "dev"`
                                        14 verbose stack Exit status 1
                                        14 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                                        14 verbose stack     at emitTwo (events.js:106:13)
                                        14 verbose stack     at EventEmitter.emit (events.js:191:7)
                                        14 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                                        14 verbose stack     at ChildProcess.emit (events.js:191:7)
                                        14 verbose stack     at maybeClose (internal/child_process.js:877:16)
                                        14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                                        15 verbose pkgid magicmirror@2.1.0
                                        16 verbose cwd /home/pi/MagicMirror
                                        17 error Linux 4.4.37-v7+
                                        18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                                        19 error node v6.9.2
                                        20 error npm  v3.10.9
                                        21 error code ELIFECYCLE
                                        22 error magicmirror@2.1.0 start: `electron js/electron.js "dev"`
                                        22 error Exit status 1
                                        23 error Failed at the magicmirror@2.1.0 start script 'electron js/electron.js "dev"'.
                                        23 error Make sure you have the latest version of node.js and npm installed.
                                        23 error If you do, this is most likely a problem with the magicmirror package,
                                        23 error not with npm itself.
                                        23 error Tell the author that this fails on your system:
                                        23 error     electron js/electron.js "dev"
                                        23 error You can get information on how to open an issue for this project with:
                                        23 error     npm bugs magicmirror
                                        23 error Or if that isn't available, you can get their info via:
                                        23 error     npm owner ls magicmirror
                                        23 error There is likely additional logging output above.
                                        24 verbose exit [ 1, true ]
                                          DvdEnde
                                          Friends,
                                          using version 2.1.0 you must have the remoteFile within the configuration of the compliments.js.
                                          the file should start like this:
                                          defaults: {
                                          	updateInterval: 30000,
                                          	remoteFile: 'put your file here',
                                          	fadeSpeed: 4000
                                          it is only working with a local file.
                                          in my config/config.js i did not change anything for compliments module.
                                          • yawnsY
                                            yawns Moderator @DvdEnde
                                            @DvdEnde
                                            no, this information is wrong. And you should avoid modifying module files.
                                            Try what I have written above, it is working fine
                                            D 1 Reply Last reply
                                            • 1 / 4
