    MMM-Multimonth
    calendarmagicmirror2module
    78 Posts 19 Posters 59.8k Views 17 Watching
      p1lspeda
      Great Module, but I think I found a small issue/bug.
      The October I live in has 31 days, any idea what’s wrong ?
        sdetweil @p1lspeda
        @p1lspeda I had a similar problem in code I am porting.
        month takes 4 or 5 weeks to show all the days… oops or 6 occasionally!
        • BKeyportB Offline
          BKeyport Module Developer @p1lspeda
          @p1lspeda Yep. Bug confirmed. Something to do with the start of week being specifically on monday (I suspect start of week and end of month being the same day). I’ll look into it when I’m able. We’re busy at work at the moment. Short term fix: set start of week to any day but Monday. 😉
          • BKeyportB Offline
            @p1lspeda Bug Squashed (99% sure). Thanks for reporting.
              p1lspeda
              Confirmed,
              Bug fixed.
              Thanks for (very) quick fix.
              • BKeyportB Offline
                @p1lspeda No worries, was using a routine wrong and didn’t catch that it was reporting the last day of the week as the first day of the week. Surprised it got through most of the month without an issue. 🤣
                  marchvet
                  Just installed this module and have it positioned as
                  bottom_bar
                  but it actually is about a half inch above the bottom.
                  Anyway to get it to sit flush with the bottom of the screen?
                  (I am a noob with coding)
                  • BKeyportB Offline
                    BKeyport Module Developer @marchvet
                    @marchvet Yes, it’s actually not the module that’s the error though it’s the overall system.
                    in css/custom.css:
                    :root {
                    	--gap-body-top: ??px;
                    	--gap-body-right: ??px;
                    	--gap-body-bottom: ??px;
                    	--gap-body-left: ??px;
                    	--gap-modules: ??px;
                    replace ?? with whatever value you find useful. the defaults are 60 for body and 30 for modules. I use 15 and 1 respectively.
                    – Brendan
                      marchvet @BKeyport
                      @BKeyport Thank you but I am not even sure how to get to the css/custom.css file?
                        marchvet @BKeyport
                          sdetweil @marchvet
                          @marchvet ~/MagicMirror/css/custom.css
                          is a file. if it doesn’t exist, create it
                          touch ~/MagicMirror/css/custom.css
                          • BKeyportB Offline
                            @sdetweil Thanks, Sam - I tend to think multiple platform so I leave the main directories off when I write…
                              sdetweil @BKeyport
                              @BKeyport many new users don’t connect the names we talk about to the folders. many have not looked at the folders at all!
                              my install script is a blessing and a curse. gets u up and running fast , but doesn’t teach you much.
                                marchvet
                                Thanks I appreciate it. Works like a charm!
                                • E Offline
                                  Egnos
                                  Thanks @BKeyport great module!
                                  • BKeyportB Offline
                                    MAJOR Update -
                                    29 Oct 2022 - Start Implementing streamlined CSS, add feature to move weekend around, documentation improvements.
                                    This update will not break old CSS or code. I’ve made sure any changed CSS includes reference to old CSS for compatibility. Some CSS names are changing to make more sense. Un-needed duplicates are being eliminated.
                                    New:
                                    If all you’re doing is changing the appearance, the README.md file has new instructions on how to do this… You can actually delete your old long changes and simply have changes in one css element.
                                    Now you can move the weekend. See the config table in README.
                                    Now you can turn on or off the previous/next month display in the month grid regardless of number of months!
                                    Let me know if you have any bugs or oddities.
                                    Thanks!
                                    BKeyportB 1 Reply Last reply Reply Quote 2
                                    • BKeyportB Offline
                                      Another big update.
                                      Event visualization is now working. Module will underline in a color of your choice (see css in README.md) for any event pulled from MagicMirror’s default calendar module.
                                      Other tweaks have occurred. Please read the readme completely to upgrade.
                                      Thanks!
                                      MZ-BERM P 2 Replies Last reply Reply Quote 1
                                      • MZ-BERM Offline
                                        MZ-BER @BKeyport
                                        Thank you! Is there also an option to disable it or can I only hide that via css?
                                        • BKeyportB Offline
                                          BKeyport Module Developer @MZ-BER
                                          @MZ-BER To be honest, I forgot to add the code to turn it off. Was gonna fix something else and re-release in a couple of days.
                                          • BKeyportB Offline
                                            New update to this module: Event visualization is now controllable by calendar.
                                            Please see github for adjustments - Pay attention to “calNames” .
                                            As always, module requires default calendar for functionality, but does not require display of said calendar.
                                            Enjoy!
                                            – B
                                            • 3 / 4
