    MMM-Multimonth
    calendarmagicmirror2module
    78 Posts 19 Posters 61.6k Views 17 Watching
      p1lspeda
      Confirmed,
      Bug fixed.
      Thanks for (very) quick fix.
      BKeyportB 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer @p1lspeda
        @p1lspeda No worries, was using a routine wrong and didn’t catch that it was reporting the last day of the week as the first day of the week. Surprised it got through most of the month without an issue. 🤣
          marchvet
          Just installed this module and have it positioned as
          bottom_bar
          but it actually is about a half inch above the bottom.
          Anyway to get it to sit flush with the bottom of the screen?
          (I am a noob with coding)
          • BKeyportB
            BKeyport Module Developer @marchvet
            @marchvet Yes, it’s actually not the module that’s the error though it’s the overall system.
            in css/custom.css:
            :root {
            	--gap-body-top: ??px;
            	--gap-body-right: ??px;
            	--gap-body-bottom: ??px;
            	--gap-body-left: ??px;
            	--gap-modules: ??px;
            replace ?? with whatever value you find useful. the defaults are 60 for body and 30 for modules. I use 15 and 1 respectively.
            – Brendan
            M 2 Replies Last reply
              marchvet @BKeyport
              @BKeyport Thank you but I am not even sure how to get to the css/custom.css file?
                marchvet @BKeyport
                  sdetweil @marchvet
                  @marchvet ~/MagicMirror/css/custom.css
                  is a file. if it doesn’t exist, create it
                  touch ~/MagicMirror/css/custom.css
                  • BKeyportB
                    @sdetweil Thanks, Sam - I tend to think multiple platform so I leave the main directories off when I write…
                    Reply Quote 2
                      sdetweil @BKeyport
                      @BKeyport many new users don’t connect the names we talk about to the folders. many have not looked at the folders at all!
                      my install script is a blessing and a curse. gets u up and running fast , but doesn’t teach you much.
                        marchvet
                        Thanks I appreciate it. Works like a charm!
                        • E
                          Egnos
                          Thanks @BKeyport great module!
                          • BKeyportB
                            MAJOR Update -
                            29 Oct 2022 - Start Implementing streamlined CSS, add feature to move weekend around, documentation improvements.
                            This update will not break old CSS or code. I’ve made sure any changed CSS includes reference to old CSS for compatibility. Some CSS names are changing to make more sense. Un-needed duplicates are being eliminated.
                            New:
                            If all you’re doing is changing the appearance, the README.md file has new instructions on how to do this… You can actually delete your old long changes and simply have changes in one css element.
                            Now you can move the weekend. See the config table in README.
                            Now you can turn on or off the previous/next month display in the month grid regardless of number of months!
                            Let me know if you have any bugs or oddities.
                            Thanks!
                            Reply Quote 2
                            • BKeyportB
                              Another big update.
                              Event visualization is now working. Module will underline in a color of your choice (see css in README.md) for any event pulled from MagicMirror’s default calendar module.
                              Other tweaks have occurred. Please read the readme completely to upgrade.
                              Thanks!
                              MZ-BERM P 2 Replies Last reply
                              • MZ-BERM
                                MZ-BER @BKeyport
                                Thank you! Is there also an option to disable it or can I only hide that via css?
                                • BKeyportB
                                  BKeyport Module Developer @MZ-BER
                                  @MZ-BER To be honest, I forgot to add the code to turn it off. Was gonna fix something else and re-release in a couple of days.
                                  • BKeyportB
                                    New update to this module: Event visualization is now controllable by calendar.
                                    Please see github for adjustments - Pay attention to “calNames” .
                                    As always, module requires default calendar for functionality, but does not require display of said calendar.
                                    Enjoy!
                                    – B
                                      pugsly @BKeyport
                                      @BKeyport
                                      How do you change the font and size now?
                                      • BKeyportB
                                        BKeyport Module Developer @pugsly
                                        @pugsly in your custom.css file, change as desired, everything is based off the MagicMirror fonts:
                                        .MMM-Multimonth .settings {
                                          --background-dimmed: var(--color-background);
                                          --background-weekday: var(--color-background);
                                          --background-weekend: cornflowerblue;
                                          --background-current: Yellow;
                                          --background-header: Green;
                                          --background-weekno: grey;
                                          --background-dow: var(--color-background);
                                          --color-weekday: var(--color-text);
                                          --color-weekend: var(--color-background);
                                          --color-current: var(--color-background);
                                          --color-dimmed: var(--color-text-dimmed);
                                          --color-header: var(--color-text-bright);
                                          --color-weekno: var(--color-text-bright);
                                          --color-dow: var(--color-text);
                                          --color-event: Red;
                                          --back-rounding: 8px;
                                          --alignment: center;
                                          --fontsize: --var(--font-size-xsmall);
                                        If you’re talking about the undocumented feature, It’s not ready yet, I just had some critical updates caught in the crossfire of forgetting to build on a dev branch. :)
                                        Also, you may want to scrub any previous custom.css for the module out and start over, a lot of the module’s css changed when I did the “one entry to rule them all” functionality above, and it may be confused a bit. This was mentioned in an older release.
                                          Spinster
                                          @BKeyport
                                          I find it even after setting the config for monthsVertical: true it is still not showing vertical,
                                          Whay could be the problem. Please advice.
                                          • BKeyportB
                                            BKeyport Module Developer @Spinster
                                            @Spinster Indeed. Something seems to have broken. I’ll fix it today.
                                            Edit:
                                            It appears I deleted it’s CSS. Backed off to fix - Repull the files, in the module folder do
                                            git pull
                                            and relaunch your mirror, it’ll work now.
                                            Starting to recode the project to incorporate the “Undocumented feature” I mentioned in previous git pushes - as well as make it easier to read and do in the future, and I guess I missed that when I redid the CSS.
                                            • 3 / 4
