    MMM-Multimonth
    calendarmagicmirror2module
    78 Posts 19 Posters 54.8k Views 17 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      new product released!
      Added:
      Language and calendar modification unlinked. The module now has startWeek variable to set the start of the week
      You now can shorten the day names to the shortest available for your language. (for english, instead of “Sun Mon Tue Wed Thu Fri Sat” it will be “S M T W T F S”
      Removed:
      All references and use of Moment. It’s now native code completely.
      Other:
      There’s a bug - Week numbers are in the system, but it will generate an additional line. I am going to re-do the module more (enough to create a MultiMonth2), so in that process I’ll sure I’ll find the cause.
      As a reminder, internationalization is based on the mirror as a whole, so if you have your mirror set to French, it will have French month and day names.
      Read the Readme for instructions.
      Thanks to MMRize for the inspiration to do this!
      E 1 Reply Last reply Reply Quote 2
        pugsly
        I only want to display a single month, how do I remove the beginning and ending dates from the current month calendar? Also seems like the alignment is off.
        • BKeyportB Offline
          BKeyport Module Developer @pugsly
          @pugsly
          add this to your custom.css file. It will clear it out. As for the malformed space, I’ll have to look into that, it appears something’s minorly wrong with the CSS, which I didn’t touch from previous version.
          .MMM-Multimonth .daydim {
          color: var(–color-background);
          • E Offline
            Egnos @BKeyport
            @BKeyport great work!
            Thanks.
              p1lspeda
              Great Module, but I think I found a small issue/bug.
              The October I live in has 31 days, any idea what’s wrong ?
                sdetweil @p1lspeda
                @p1lspeda I had a similar problem in code I am porting.
                month takes 4 or 5 weeks to show all the days… oops or 6 occasionally!
                • BKeyportB Offline
                  BKeyport Module Developer @p1lspeda
                  @p1lspeda Yep. Bug confirmed. Something to do with the start of week being specifically on monday (I suspect start of week and end of month being the same day). I’ll look into it when I’m able. We’re busy at work at the moment. Short term fix: set start of week to any day but Monday. 😉
                  • BKeyportB Offline
                    @p1lspeda Bug Squashed (99% sure). Thanks for reporting.
                      p1lspeda
                      Confirmed,
                      Bug fixed.
                      Thanks for (very) quick fix.
                      • BKeyportB Offline
                        @p1lspeda No worries, was using a routine wrong and didn’t catch that it was reporting the last day of the week as the first day of the week. Surprised it got through most of the month without an issue. 🤣
                          marchvet
                          Just installed this module and have it positioned as
                          bottom_bar
                          but it actually is about a half inch above the bottom.
                          Anyway to get it to sit flush with the bottom of the screen?
                          (I am a noob with coding)
                          • BKeyportB Offline
                            BKeyport Module Developer @marchvet
                            @marchvet Yes, it’s actually not the module that’s the error though it’s the overall system.
                            in css/custom.css:
                            :root {
                            	--gap-body-top: ??px;
                            	--gap-body-right: ??px;
                            	--gap-body-bottom: ??px;
                            	--gap-body-left: ??px;
                            	--gap-modules: ??px;
                            replace ?? with whatever value you find useful. the defaults are 60 for body and 30 for modules. I use 15 and 1 respectively.
                            – Brendan
                              marchvet @BKeyport
                              @BKeyport Thank you but I am not even sure how to get to the css/custom.css file?
                                marchvet @BKeyport
                                  sdetweil @marchvet
                                  @marchvet ~/MagicMirror/css/custom.css
                                  is a file. if it doesn’t exist, create it
                                  touch ~/MagicMirror/css/custom.css
                                  • BKeyportB Offline
                                    @sdetweil Thanks, Sam - I tend to think multiple platform so I leave the main directories off when I write…
                                      sdetweil @BKeyport
                                      @BKeyport many new users don’t connect the names we talk about to the folders. many have not looked at the folders at all!
                                      my install script is a blessing and a curse. gets u up and running fast , but doesn’t teach you much.
                                        marchvet
                                        Thanks I appreciate it. Works like a charm!
                                        • E Offline
                                          Egnos
                                          Thanks @BKeyport great module!
                                          • BKeyportB Offline
                                            MAJOR Update -
                                            29 Oct 2022 - Start Implementing streamlined CSS, add feature to move weekend around, documentation improvements.
                                            This update will not break old CSS or code. I’ve made sure any changed CSS includes reference to old CSS for compatibility. Some CSS names are changing to make more sense. Un-needed duplicates are being eliminated.
                                            New:
                                            If all you’re doing is changing the appearance, the README.md file has new instructions on how to do this… You can actually delete your old long changes and simply have changes in one css element.
                                            Now you can move the weekend. See the config table in README.
                                            Now you can turn on or off the previous/next month display in the month grid regardless of number of months!
                                            Let me know if you have any bugs or oddities.
                                            Thanks!
                                            BKeyportB 1 Reply Last reply Reply Quote 2
                                            • 3 / 4
