    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 411.8k Views 51 Watching
    • T Offline
      tcarson
      @RedNax
      where in the module are the horizontal lines controlled I would like to change the line weight to 1 px. this is in horizontal format
      • O Offline
        ostfilinchen
        i have a question about the size of the actual weather Icon.
        Can i Change the size in the custom.css and if yes, how can i do this?
        strawberry 3.141S 1 Reply Last reply Reply Quote 1
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
          @ostfilinchen I would try a selector like this
          .MMM-WunderGround div.large span.wi {
              /*change the size here*/
          • O Offline
            ostfilinchen
            @strawberry-3-141 That doesn’t work. I mean the Icon size left of the temperature Display on the top. In the Picture the sunbeams Project into the wind speed
              [[global:former-user]]
              How to Change “C” to “°C” ?, - has any one done this?
                [[global:former-user]] @yo-less
                @yo-less said in Weatherunderground - currently - hourly - daily - configurable:
                @RedNax I managed to parse my way through it with some crazy regex stuff a few days ago (As this is the first time I have done this, it took me an insane amount of time to add the degree symbol only where it should be added), I know I keep saying this, but I will eventually push it to my MMM-WunderGround fork and then you can decide which of my features you would like to implement.
                @yo-less please can you detail how this was accomplished?
                  anatius @Guest
                  @wjdw87
                  this.forecastText = this.forecastText.replace(/(.*\d+)(C)(.*)/gi, "$1°C$3");
                  around line 937 in MMM-WunderGround.js should do the trick
                    Steff
                    two questions:
                    Yesterday I updated via git pull the Weatherunderground module to its latest version, after that the icon for moonphases is not displayed (not sure if this is a new feature), it shows me a “broken” link picture. I did run after the git pull, npm install. From the readme I understood that the module is using weathericons.io. I tried to understand how the icons are used in the module, but I have to admit that I could not understand it. Are the icons “fetched” online or are they somewhere locally stored.
                    The only thing I can state, after commenting in MMM-WunderGround.js the lines relating to the icon
                    //var moonPhaseIcon = document.createElement(“span”);
                    certainly my problem disappeared.
                    Any hint what might be wrong with “my” moon icon, I would highly appreciate it.
                    Second question: On the screenshots above I saw that the sunrise icon is colored. In my configuration everything is always black/white. Is there a config option I have missed up to now ?
                    Stefan
                    • N Offline
                      nobita
                      This MMM-WunderGround Module,in Configuration Options in psw I don’t understand what does its mean. and How to get it
                        dialdn
                        This looks great!
                        However, we have a mix of snow and rain at this time. It seems all precipitation is being rendered as mm when it should be cm. For example, we are expecting ~10 cm on Tuesday but it is displaying as 9 mm. Haven’t looked at the API to see how the precipitation type is sent.
                        Mike
                          dialdn @dialdn
                          @dialdn
                          I see that you are pulling the qpf_allday but in these conditions, I would want to see snow_allday. I would think if snow_allday is >0 it should trump qpf_allday and also display using the units (cm). Not sure how the API looks when we have freezing rain in the forecast. I would assume it shows as rain.
                          	"pop":80,
                          	"qpf_allday": {
                          	"in": 0.37,
                          	"mm": 9
                          	"qpf_day": {
                          	"in": 0.22,
                          	"mm": 6
                          	"qpf_night": {
                          	"in": 0.15,
                          	"mm": 4
                          	"snow_allday": {
                          	"in": 3.7,
                          	"cm": 9.4
                          	"snow_day": {
                          	"in": 2.4,
                          	"cm": 6.1
                          	"snow_night": {
                          	"in": 1.3,
                          	"cm": 3.3
                            PointPubMedia
                            Also, any way to disable the alert popup completely ?
                              RedNax Module Developer @dialdn
                              @dialdn This is now implemented… just pull the latest master :)
                                RedNax Module Developer @PointPubMedia
                                @PointPubMedia You can now disable the popup by adding show_popup: 0 to your config.
                                  PointPubMedia
                                  I’m stilling seeing mm instead of cm when we are having snow… normal ?
                                    @PointPubMedia Not really… typo in the code. Fixed now… (hopefully)
                                      PointPubMedia
                                      Working now ;)
                                      • O Offline
                                        ostfilinchen @anatius
                                        @RedNax:
                                        @anatius said in Weatherunderground - currently - hourly - daily - configurable:
                                        @wjdw87
                                        do you have change this also?
                                          RedNax Module Developer @ostfilinchen
                                          @ostfilinchen Now i have, and thanks to @anatius for this!
                                            Renfield
                                            @RedNax
                                            Thanks for the great module!
                                            I’ve fairly heavily modified it to my own preferences and soI don’t want to roll to the latest versions. I’m getting alerts that there’s a new version available and would like to not have those alerts displayed as I don’t wish to update and lose my changes. Is there a way to not have the version update alerts but still get the weather-related alerts? I’m not familiar enough with the MM infrastructure to figure this one out.
                                            Thanks again for the great work!
                                            Ren
                                            • 10
                                            • 3 / 10
