    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 415.5k Views 51 Watching
      anatius @Guest
      @wjdw87
      this.forecastText = this.forecastText.replace(/(.*\d+)(C)(.*)/gi, "$1°C$3");
      around line 937 in MMM-WunderGround.js should do the trick
        Steff
        two questions:
        Yesterday I updated via git pull the Weatherunderground module to its latest version, after that the icon for moonphases is not displayed (not sure if this is a new feature), it shows me a “broken” link picture. I did run after the git pull, npm install. From the readme I understood that the module is using weathericons.io. I tried to understand how the icons are used in the module, but I have to admit that I could not understand it. Are the icons “fetched” online or are they somewhere locally stored.
        The only thing I can state, after commenting in MMM-WunderGround.js the lines relating to the icon
        //var moonPhaseIcon = document.createElement(“span”);
        certainly my problem disappeared.
        Any hint what might be wrong with “my” moon icon, I would highly appreciate it.
        Second question: On the screenshots above I saw that the sunrise icon is colored. In my configuration everything is always black/white. Is there a config option I have missed up to now ?
        Stefan
        • N Offline
          nobita
          This MMM-WunderGround Module,in Configuration Options in psw I don’t understand what does its mean. and How to get it
            dialdn
            This looks great!
            However, we have a mix of snow and rain at this time. It seems all precipitation is being rendered as mm when it should be cm. For example, we are expecting ~10 cm on Tuesday but it is displaying as 9 mm. Haven’t looked at the API to see how the precipitation type is sent.
            Mike
              dialdn @dialdn
              @dialdn
              I see that you are pulling the qpf_allday but in these conditions, I would want to see snow_allday. I would think if snow_allday is >0 it should trump qpf_allday and also display using the units (cm). Not sure how the API looks when we have freezing rain in the forecast. I would assume it shows as rain.
              	"pop":80,
              	"qpf_allday": {
              	"in": 0.37,
              	"mm": 9
              	"qpf_day": {
              	"in": 0.22,
              	"mm": 6
              	"qpf_night": {
              	"in": 0.15,
              	"mm": 4
              	"snow_allday": {
              	"in": 3.7,
              	"cm": 9.4
              	"snow_day": {
              	"in": 2.4,
              	"cm": 6.1
              	"snow_night": {
              	"in": 1.3,
              	"cm": 3.3
                PointPubMedia
                Also, any way to disable the alert popup completely ?
                  RedNax Module Developer @dialdn
                  @dialdn This is now implemented… just pull the latest master :)
                    RedNax Module Developer @PointPubMedia
                    @PointPubMedia You can now disable the popup by adding show_popup: 0 to your config.
                      PointPubMedia
                      I’m stilling seeing mm instead of cm when we are having snow… normal ?
                        @PointPubMedia Not really… typo in the code. Fixed now… (hopefully)
                          PointPubMedia
                          Working now ;)
                          • O Offline
                            ostfilinchen @anatius
                            @RedNax:
                            @anatius said in Weatherunderground - currently - hourly - daily - configurable:
                            @wjdw87
                            do you have change this also?
                              RedNax Module Developer @ostfilinchen
                              @ostfilinchen Now i have, and thanks to @anatius for this!
                                Renfield
                                @RedNax
                                Thanks for the great module!
                                I’ve fairly heavily modified it to my own preferences and soI don’t want to roll to the latest versions. I’m getting alerts that there’s a new version available and would like to not have those alerts displayed as I don’t wish to update and lose my changes. Is there a way to not have the version update alerts but still get the weather-related alerts? I’m not familiar enough with the MM infrastructure to figure this one out.
                                Thanks again for the great work!
                                Ren
                                • L Offline
                                  lolobyte
                                  Hello developer @RedNax
                                  Your module update is nice but please don’t waste so many place with the new layout.
                                  Please shrink the space between the lines.
                                    RedNax Module Developer @lolobyte
                                    @lolobyte I’m sorry to hear you’re not happy with the layout. Could you be a bit more precide on the nature of your issue? Are the icons too large, too much information… A screenshot with arrows would be nice.
                                    Thanks!
                                    O L 3 Replies Last reply Reply Quote 0
                                    • O Offline
                                      ostfilinchen @RedNax
                                      @RedNax the space between the lines in the forecasttable is too big an the Currentweather icon is also to big. My Set was 30% size of the Currentweather icon. With this size it looks good
                                      • L Offline
                                        lolobyte @RedNax
                                        @RedNax
                                        here a sample of the module from my Browser.
                                        It looks on the real mirror same.
                                        • O Offline
                                          @RedNax can you please make the color Icons smaller? The Currentweather icon is too big with 100% size. With this icon size, the Module Uses too many space on the mirror.
                                          A other way, is to make it scalable by custom.css.
                                          What Do you think about this?
                                            @ostfilinchen Better now?
                                            O L 2 Replies Last reply Reply Quote 1
                                            • 10
                                            • 3 / 10
