    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 427.7k Views 51 Watching
    • O
      ostfilinchen
      i have a question about the size of the actual weather Icon.
      Can i Change the size in the custom.css and if yes, how can i do this?
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
        @ostfilinchen I would try a selector like this
        .MMM-WunderGround div.large span.wi {
            /*change the size here*/
        • O
          ostfilinchen
          @strawberry-3-141 That doesn’t work. I mean the Icon size left of the temperature Display on the top. In the Picture the sunbeams Project into the wind speed
            A Former User
            How to Change “C” to “°C” ?, - has any one done this?
              A Former User @yo-less
              @yo-less said in Weatherunderground - currently - hourly - daily - configurable:
              @RedNax I managed to parse my way through it with some crazy regex stuff a few days ago (As this is the first time I have done this, it took me an insane amount of time to add the degree symbol only where it should be added), I know I keep saying this, but I will eventually push it to my MMM-WunderGround fork and then you can decide which of my features you would like to implement.
              @yo-less please can you detail how this was accomplished?
              A 1 Reply Last reply
              • A
                anatius @Guest
                @wjdw87
                this.forecastText = this.forecastText.replace(/(.*\d+)(C)(.*)/gi, "$1°C$3");
                around line 937 in MMM-WunderGround.js should do the trick
                O 1 Reply Last reply
                • SteffS
                  Steff
                  two questions:
                  Yesterday I updated via git pull the Weatherunderground module to its latest version, after that the icon for moonphases is not displayed (not sure if this is a new feature), it shows me a “broken” link picture. I did run after the git pull, npm install. From the readme I understood that the module is using weathericons.io. I tried to understand how the icons are used in the module, but I have to admit that I could not understand it. Are the icons “fetched” online or are they somewhere locally stored.
                  The only thing I can state, after commenting in MMM-WunderGround.js the lines relating to the icon
                  //var moonPhaseIcon = document.createElement(“span”);
                  certainly my problem disappeared.
                  Any hint what might be wrong with “my” moon icon, I would highly appreciate it.
                  Second question: On the screenshots above I saw that the sunrise icon is colored. In my configuration everything is always black/white. Is there a config option I have missed up to now ?
                  Stefan
                  • N
                    nobita
                    This MMM-WunderGround Module,in Configuration Options in psw I don’t understand what does its mean. and How to get it
                      dialdn
                      This looks great!
                      However, we have a mix of snow and rain at this time. It seems all precipitation is being rendered as mm when it should be cm. For example, we are expecting ~10 cm on Tuesday but it is displaying as 9 mm. Haven’t looked at the API to see how the precipitation type is sent.
                      Mike
                      D 1 Reply Last reply
                        dialdn @dialdn
                        @dialdn
                        I see that you are pulling the qpf_allday but in these conditions, I would want to see snow_allday. I would think if snow_allday is >0 it should trump qpf_allday and also display using the units (cm). Not sure how the API looks when we have freezing rain in the forecast. I would assume it shows as rain.
                        	"pop":80,
                        	"qpf_allday": {
                        	"in": 0.37,
                        	"mm": 9
                        	"qpf_day": {
                        	"in": 0.22,
                        	"mm": 6
                        	"qpf_night": {
                        	"in": 0.15,
                        	"mm": 4
                        	"snow_allday": {
                        	"in": 3.7,
                        	"cm": 9.4
                        	"snow_day": {
                        	"in": 2.4,
                        	"cm": 6.1
                        	"snow_night": {
                        	"in": 1.3,
                        	"cm": 3.3
                        RedNaxR 1 Reply Last reply
                        • PointPubMediaP
                          PointPubMedia
                          Also, any way to disable the alert popup completely ?
                          • RedNaxR
                            RedNax Module Developer @dialdn
                            @dialdn This is now implemented… just pull the latest master :)
                            • RedNaxR
                              RedNax Module Developer @PointPubMedia
                              @PointPubMedia You can now disable the popup by adding show_popup: 0 to your config.
                              • PointPubMediaP
                                PointPubMedia
                                I’m stilling seeing mm instead of cm when we are having snow… normal ?
                                • RedNaxR
                                  @PointPubMedia Not really… typo in the code. Fixed now… (hopefully)
                                  • PointPubMediaP
                                    PointPubMedia
                                    Working now ;)
                                    • O
                                      ostfilinchen @anatius
                                      @RedNax:
                                      @anatius said in Weatherunderground - currently - hourly - daily - configurable:
                                      @wjdw87
                                      do you have change this also?
                                      • RedNaxR
                                        RedNax Module Developer @ostfilinchen
                                        @ostfilinchen Now i have, and thanks to @anatius for this!
                                        Reply Quote 2
                                          Renfield
                                          @RedNax
                                          Thanks for the great module!
                                          I’ve fairly heavily modified it to my own preferences and soI don’t want to roll to the latest versions. I’m getting alerts that there’s a new version available and would like to not have those alerts displayed as I don’t wish to update and lose my changes. Is there a way to not have the version update alerts but still get the weather-related alerts? I’m not familiar enough with the MM infrastructure to figure this one out.
                                          Thanks again for the great work!
                                          Ren
                                          • lolobyteL
                                            lolobyte
                                            Hello developer @RedNax
                                            Your module update is nice but please don’t waste so many place with the new layout.
                                            Please shrink the space between the lines.
                                            • 10
                                            • 3 / 10
