    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 427.7k Views 51 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
      @ostfilinchen I would try a selector like this
      .MMM-WunderGround div.large span.wi {
          /*change the size here*/
      • O
        ostfilinchen
        @strawberry-3-141 That doesn’t work. I mean the Icon size left of the temperature Display on the top. In the Picture the sunbeams Project into the wind speed
          A Former User
          How to Change “C” to “°C” ?, - has any one done this?
            A Former User @yo-less
            @yo-less said in Weatherunderground - currently - hourly - daily - configurable:
            @RedNax I managed to parse my way through it with some crazy regex stuff a few days ago (As this is the first time I have done this, it took me an insane amount of time to add the degree symbol only where it should be added), I know I keep saying this, but I will eventually push it to my MMM-WunderGround fork and then you can decide which of my features you would like to implement.
            @yo-less please can you detail how this was accomplished?
            A 1 Reply Last reply
            • A
              anatius @Guest
              @wjdw87
              this.forecastText = this.forecastText.replace(/(.*\d+)(C)(.*)/gi, "$1°C$3");
              around line 937 in MMM-WunderGround.js should do the trick
              O 1 Reply Last reply
              • SteffS
                Steff
                two questions:
                Yesterday I updated via git pull the Weatherunderground module to its latest version, after that the icon for moonphases is not displayed (not sure if this is a new feature), it shows me a “broken” link picture. I did run after the git pull, npm install. From the readme I understood that the module is using weathericons.io. I tried to understand how the icons are used in the module, but I have to admit that I could not understand it. Are the icons “fetched” online or are they somewhere locally stored.
                The only thing I can state, after commenting in MMM-WunderGround.js the lines relating to the icon
                //var moonPhaseIcon = document.createElement(“span”);
                certainly my problem disappeared.
                Any hint what might be wrong with “my” moon icon, I would highly appreciate it.
                Second question: On the screenshots above I saw that the sunrise icon is colored. In my configuration everything is always black/white. Is there a config option I have missed up to now ?
                Stefan
                • N
                  nobita
                  This MMM-WunderGround Module,in Configuration Options in psw I don’t understand what does its mean. and How to get it
                    dialdn
                    This looks great!
                    However, we have a mix of snow and rain at this time. It seems all precipitation is being rendered as mm when it should be cm. For example, we are expecting ~10 cm on Tuesday but it is displaying as 9 mm. Haven’t looked at the API to see how the precipitation type is sent.
                    Mike
                    D 1 Reply Last reply
                      dialdn @dialdn
                      @dialdn
                      I see that you are pulling the qpf_allday but in these conditions, I would want to see snow_allday. I would think if snow_allday is >0 it should trump qpf_allday and also display using the units (cm). Not sure how the API looks when we have freezing rain in the forecast. I would assume it shows as rain.
                      	"pop":80,
                      	"qpf_allday": {
                      	"in": 0.37,
                      	"mm": 9
                      	"qpf_day": {
                      	"in": 0.22,
                      	"mm": 6
                      	"qpf_night": {
                      	"in": 0.15,
                      	"mm": 4
                      	"snow_allday": {
                      	"in": 3.7,
                      	"cm": 9.4
                      	"snow_day": {
                      	"in": 2.4,
                      	"cm": 6.1
                      	"snow_night": {
                      	"in": 1.3,
                      	"cm": 3.3
                      RedNaxR 1 Reply Last reply
                      • PointPubMediaP
                        PointPubMedia
                        Also, any way to disable the alert popup completely ?
                        • RedNaxR
                          RedNax Module Developer @dialdn
                          @dialdn This is now implemented… just pull the latest master :)
                          • RedNaxR
                            RedNax Module Developer @PointPubMedia
                            @PointPubMedia You can now disable the popup by adding show_popup: 0 to your config.
                            • PointPubMediaP
                              PointPubMedia
                              I’m stilling seeing mm instead of cm when we are having snow… normal ?
                              • RedNaxR
                                @PointPubMedia Not really… typo in the code. Fixed now… (hopefully)
                                • PointPubMediaP
                                  PointPubMedia
                                  Working now ;)
                                  • O
                                    ostfilinchen @anatius
                                    @RedNax:
                                    @anatius said in Weatherunderground - currently - hourly - daily - configurable:
                                    @wjdw87
                                    do you have change this also?
                                    • RedNaxR
                                      RedNax Module Developer @ostfilinchen
                                      @ostfilinchen Now i have, and thanks to @anatius for this!
                                      Reply Quote 2
                                        Renfield
                                        @RedNax
                                        Thanks for the great module!
                                        I’ve fairly heavily modified it to my own preferences and soI don’t want to roll to the latest versions. I’m getting alerts that there’s a new version available and would like to not have those alerts displayed as I don’t wish to update and lose my changes. Is there a way to not have the version update alerts but still get the weather-related alerts? I’m not familiar enough with the MM infrastructure to figure this one out.
                                        Thanks again for the great work!
                                        Ren
                                        • lolobyteL
                                          lolobyte
                                          Hello developer @RedNax
                                          Your module update is nice but please don’t waste so many place with the new layout.
                                          Please shrink the space between the lines.
                                          • RedNaxR
                                            RedNax Module Developer @lolobyte
                                            @lolobyte I’m sorry to hear you’re not happy with the layout. Could you be a bit more precide on the nature of your issue? Are the icons too large, too much information… A screenshot with arrows would be nice.
                                            Thanks!
                                            O lolobyteL 3 Replies Last reply
                                            • 10
                                            • 3 / 10
