Unsolved Pir sensor
@j-e-f-f Hi mate. Thinking to install EXT-Pir now. Just one question do I need EXT-Screen to make it work. If yes how can I configure both module? Thanks
@tanvir586 no need to install Ext-Screen. You can use Ext-PIR on its own.
@j-e-f-f ah ? So cool so! Give me a sample or tuto?
@tanvir586 said in Pir sensor:
@sdetweil it work like https://github.com/paviro/MMM-PIR-Sensor
mmm-pir-sensor is not working anymore that’s why I wanted to use the light one. but this one is not working looks likeBut of course the module still works.7
I have this running on my Pi 3b, Bullseye and MM 2.21.0 … -
@j-e-f-f Thanks will try soon
@MyMirror unfortunately it does not work here.
Pi3, Bullseye, MM2.22: PIR-Sensor does not work at all, PIR-Sensor-Light counts down from 15 minutes, but starts again without turning off the screen.
No idea what to do.
My MM has been working flawlessly for 5 years, but after the new fresh install with 2.22 I am having this problem.
Can anybody help?
Peter -
@Peter didn’t worked for me either. Recovered my old sd card with mm 1.19 and MMM-PIR-Sensor installed. Not updating my mm now.
So I have my PIR working through a python script, from an old install but am using xrandr, which if run in terminal works great, I don’t know scripting well and would like to know if someone could make a module, utilising a PIR and xrandr codes below
Monitor off: xrandr --display :0.0 --output HDMI-1 --off
Monitor on: xrandr --display :0.0 --output HDMI-1 --rotate left --auto -
@kaoshunter see MMM-PIR-Sensor-Lite
supports xrandr
