    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 713.6k Views 57 Watching
      sdetweil @Egnos
      @Egnos sorry, that part I don’t know.
      I have ow keys for both 2.5 and 3.0, but its been so long, I don’t remember what I did , altho it was only website
      • E
        Egnos @sdetweil
        @sdetweil thanks.
        I’m trying to create a new user in the OpenWeatherMap site to have a new API.
        In the meantime, if anyone knows how to help me it would be appreciated!:grinning_face_with_sweat:
          sdetweil @Egnos
          @Egnos i just installed the module and used all my api keys without any problem … I did NOT edit the node_helper…
          this is the signup screen I see for v3… need credit card
          S E 2 Replies Last reply Reply Quote 0
            I signed up for the 3.0 api, they updated my default api key
            I changed the code to use 3.0 instead of 2.5
            and it worked
            • E
              Egnos @sdetweil
              @sdetweil said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
              I don’t understand what’s different about me…
              Did you do anything in particular when you installed?
              So I have to enable “One Call API 3.0 NEW” and put the credit card.
              So is it paid?
              Did you also have to enter your credit card for it to work?
              Thanks!
                sdetweil @Egnos
                @Egnos i did enter cc… as it is required for v3.
                i tried on my older api keys
                the key i created a few minutes ago, which worked under api 2.5,
                no longer works under 2.5
                the keys I had created before today continue to work under 2.5
                the default key works under both
                they sent me an email, with my apikey, which is my old default key…
                • E
                  Egnos @sdetweil
                  but do they take money or in any case a free service?
                  so I understand that if you don’t activate “One Call API 3.0 NEW” now the module doesn’t work…
                  Do you know of other weather modules with a similar layout and that don’t have these restrictions?
                  Thanks.
                    sdetweil @Egnos
                    @Egnos if u didn’t have apikeys from 2.5, then you only get keys from 3.0.
                    now that I have signed up for 3.0 all new keys will be 3.0
                    maybe pirate weather, which looks like the old darksky API is free for a while.
                    I see a pull request in the darksky module to use the pirate weather API.
                    git clone as normal
                         or go to that module folder if already installed
                    git fetch origin pull/38/head:pirate
                    git checkout pirate
                    then get a key from pirateweather
                    your old darksky module config ‘should’ work unchanged…
                    every provider is going to a charge model, maybe with some low volumes free ( for a while, til it costs too much to run)
                    • E
                      Egnos @sdetweil
                      Hi there,
                      after various tests I managed to get MMM-DarkSkyForecast to work again with pirate-weather.api.
                      I followed the @dankerthrone guide on github:
                      https://github.com/jclarke0000/MMM-DarkSkyForecast/issues/36#issuecomment-1407382499
                      I’ll just add that it seems that the “beta” of PirateWeather is no longer available, so you have to select “Free Tier” and it works the same.
                      I also tried install the following module but didn’t work (seems to have the same modify contained in the @dankerthrone guide but I don’t know why it gives an error… )
                      https://github.com/dankerthrone/MMM-PirateSkyForecast
                      Thank you @sdetweil for your valuable advice!
                        PaulB
                        Thank you very much for this great module !
                          p1lspeda
                          Love this module.
                          I have one question: how do I increase the icon size and temperature size and have it right-aligned ?
                          Currently this is what it looks like (I know the icon has not loaded yet), and I’d like it larger and right-aligned.
                          Any hints as to what I need to adjust within the custom.css ?
                          • T
                            Trashbln
                            How can I turn off weather alerts? Unfortunately I can’t find a solution for this anywhere
                              sdetweil @Trashbln
                              @Trashbln there is no feature to do that, but you could add it pretty easily
                              add a new property to the defaults section
                              showAlerts: true,
                              then later around line 350
                              you need the alerts field for the return following
                                 var alerts = [];
                                 if(this.config.showAlerts){
                                    if (this.weatherData.alerts) {
                                     // for (alert in this.weatherData.alerts) {
                                     //   alert.description.replace("\n", "<br />");
                                     alerts = this.weatherData.alerts;
                              in your config.js for this module config:{} section add
                                    showAlerts: false
                              • BKeyportB
                                @sdetweil easier fix in css:
                                /* Disable alerts */
                                .MMM-OpenWeatherForecast .weather-alert .weather-alert-description,
                                .MMM-OpenWeatherForecast .weather-alert .weather-alert-source {
                                	display: none;
                                • A atltiger81 referenced this topic on
                                • K
                                  kasperb
                                  Just updated my module to use the v3.0 API, but getting the following error:
                                  [ERROR] [MMM-OpenWeatherForecast] 30-Sep-24 20:15 ** ERROR ** ReferenceError: fetch is not defined
                                  Any idea why that is? When I copy/paste the URL into the browser, I get a response.
                                    MarcLandis Module Developer @kasperb
                                    @kasperb what version of nodejs are you using?
                                    what does the following command say:
                                    nodejs -v
                                    The module was recently changed to use a nodejs internal method to get the data, but your nodejs might be outdated.
                                      jimjones
                                      Thanks for the heads-up on MMM-OpenWeatherForecast as a replacement for MMM-DarkSkyForecast! I’m interested to see how it compares in terms of accuracy and features—has anyone tried it out yet?
                                        sdetweil @jimjones
                                        @jimjones darksky has been dead for a number of years now.
                                        • K
                                          kasperb @MarcLandis
                                          @MarcLandis Thanks… I was running a very old version of Raspian and wasn’t able to update Node. Setting up a new version now :-)
                                          • F
                                            fillilutten
                                            Today when I started up the system I got this wall of text instead of my usual weather info + icons. Any idea why and how so solve? :) alt text
                                            S karsten13K 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 13 / 13
