    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.5k Views 57 Watching
      I signed up for the 3.0 api, they updated my default api key
      I changed the code to use 3.0 instead of 2.5
      and it worked
      • E
        Egnos @sdetweil
        @sdetweil said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
        i just installed the module and used all my api keys without any problem … I did NOT edit the node_helper…
        I don’t understand what’s different about me…
        Did you do anything in particular when you installed?
        this is the signup screen I see for v3… need credit card
        So I have to enable “One Call API 3.0 NEW” and put the credit card.
        So is it paid?
        Did you also have to enter your credit card for it to work?
        Thanks!
          sdetweil @Egnos
          @Egnos i did enter cc… as it is required for v3.
          i tried on my older api keys
          the key i created a few minutes ago, which worked under api 2.5,
          no longer works under 2.5
          the keys I had created before today continue to work under 2.5
          the default key works under both
          they sent me an email, with my apikey, which is my old default key…
          E 1 Reply Last reply
          • E
            Egnos @sdetweil
            but do they take money or in any case a free service?
            so I understand that if you don’t activate “One Call API 3.0 NEW” now the module doesn’t work…
            Do you know of other weather modules with a similar layout and that don’t have these restrictions?
            Thanks.
              sdetweil @Egnos
              @Egnos if u didn’t have apikeys from 2.5, then you only get keys from 3.0.
              now that I have signed up for 3.0 all new keys will be 3.0
              maybe pirate weather, which looks like the old darksky API is free for a while.
              I see a pull request in the darksky module to use the pirate weather API.
              git clone as normal
                   or go to that module folder if already installed
              git fetch origin pull/38/head:pirate
              git checkout pirate
              then get a key from pirateweather
              your old darksky module config ‘should’ work unchanged…
              every provider is going to a charge model, maybe with some low volumes free ( for a while, til it costs too much to run)
              • E
                Egnos @sdetweil
                Hi there,
                after various tests I managed to get MMM-DarkSkyForecast to work again with pirate-weather.api.
                I followed the @dankerthrone guide on github:
                https://github.com/jclarke0000/MMM-DarkSkyForecast/issues/36#issuecomment-1407382499
                I’ll just add that it seems that the “beta” of PirateWeather is no longer available, so you have to select “Free Tier” and it works the same.
                I also tried install the following module but didn’t work (seems to have the same modify contained in the @dankerthrone guide but I don’t know why it gives an error… )
                https://github.com/dankerthrone/MMM-PirateSkyForecast
                Thank you @sdetweil for your valuable advice!
                  PaulB
                  Thank you very much for this great module !
                    p1lspeda
                    Love this module.
                    I have one question: how do I increase the icon size and temperature size and have it right-aligned ?
                    Currently this is what it looks like (I know the icon has not loaded yet), and I’d like it larger and right-aligned.
                    Any hints as to what I need to adjust within the custom.css ?
                    • T
                      Trashbln
                      How can I turn off weather alerts? Unfortunately I can’t find a solution for this anywhere
                        sdetweil @Trashbln
                        @Trashbln there is no feature to do that, but you could add it pretty easily
                        add a new property to the defaults section
                        showAlerts: true,
                        then later around line 350
                        you need the alerts field for the return following
                           var alerts = [];
                           if(this.config.showAlerts){
                              if (this.weatherData.alerts) {
                               // for (alert in this.weatherData.alerts) {
                               //   alert.description.replace("\n", "<br />");
                               alerts = this.weatherData.alerts;
                        in your config.js for this module config:{} section add
                              showAlerts: false
                        BKeyportB 1 Reply Last reply
                        • BKeyportB
                          @sdetweil easier fix in css:
                          /* Disable alerts */
                          .MMM-OpenWeatherForecast .weather-alert .weather-alert-description,
                          .MMM-OpenWeatherForecast .weather-alert .weather-alert-source {
                          	display: none;
                          • A atltiger81 referenced this topic on
                          • K
                            kasperb
                            Just updated my module to use the v3.0 API, but getting the following error:
                            [ERROR] [MMM-OpenWeatherForecast] 30-Sep-24 20:15 ** ERROR ** ReferenceError: fetch is not defined
                            Any idea why that is? When I copy/paste the URL into the browser, I get a response.
                            M 1 Reply Last reply
                              MarcLandis Module Developer @kasperb
                              @kasperb what version of nodejs are you using?
                              what does the following command say:
                              nodejs -v
                              The module was recently changed to use a nodejs internal method to get the data, but your nodejs might be outdated.
                              K 1 Reply Last reply
                                jimjones
                                Thanks for the heads-up on MMM-OpenWeatherForecast as a replacement for MMM-DarkSkyForecast! I’m interested to see how it compares in terms of accuracy and features—has anyone tried it out yet?
                                  sdetweil @jimjones
                                  @jimjones darksky has been dead for a number of years now.
                                  • K
                                    kasperb @MarcLandis
                                    @MarcLandis Thanks… I was running a very old version of Raspian and wasn’t able to update Node. Setting up a new version now :-)
                                    • F
                                      fillilutten
                                      Today when I started up the system I got this wall of text instead of my usual weather info + icons. Any idea why and how so solve? :) alt text
                                      S karsten13K 2 Replies Last reply
                                        sdetweil @fillilutten
                                        @fillilutten looks like the weather service got a really verbose description for the weather details
                                        And the module didn’t anticipate that
                                        I’d open an issue on the GitHub repo for that module.
                                        In the module folder do
                                        git remote -v
                                        That will give you the url of the repo.
                                        Someone has to fix the code
                                        • karsten13K
                                          karsten13 @fillilutten
                                          @fillilutten
                                          I agree with Sam.
                                          That looks like a weather warning to me. They are quite rare, and the scenario might never have occurred during the module’s development…
                                          • 10
                                          • 11
                                          • 12
                                          • 13
                                          • 13 / 13
