    MMM-Temperature
    9 Posts 4 Posters 3.8k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @wishmaster270
      @wishmaster270
      Nice! I don’t have/use sensors but cool just the same!
      • H Offline
        Hadr1en Project Sponsor
        Hello !
        Nice script but can you tell us what information you need to execute scripts ? Maybe I should open a troubleshooting thread but I tried with the examples with AdafruitDHT.py script and have this config :
            module: 'MMM-Temperature',
            position: 'top_right',
        sensors: [
        script: "/home/pi/Adafruit_Python_DHT/examples/AdafruitDHT.py",
        args: "11 2"
        And get an error (but if I use the script alone, i get the temperature and humidity)
        Thanks !
        • wishmaster270W Offline
          wishmaster270 Module Developer @Hadr1en
          @Hadr1en Hi, the module expects an json string as output of the script it executes. There is a section in the readme which shows an example:
             "humidity": 32.61236572265625,
             "temperature_c": 25.50150878906249, //Temperature in °C
             "temperature_f": 77.9027158203125, //Temperature in °F
             "error": false
          What kind of error do you get?
            snakestang @wishmaster270
            @wishmaster270
            I know this is an old thread but maybe someone can help. I have everything installed but for the life of me can’t get it to change to fahrenheit. No matter where I put the change line in config it always reads celsius.
            I am using a DS18b20 if it matters.
            Tha ks in advance.
            wishmaster270W 2 Replies Last reply Reply Quote 0
              wishmaster270 Module Developer @snakestang
              @snakestang Hi, I currently do not use the module (and only used the Fahrenheit option during development) in my setup but I will try to setup a simple development environment to check your problem.
                @wishmaster270
                No worries. Thanks for your time. Not the end of the world by any means.
                  @snakestang
                  i tried the following configuration
                        module: "MMM-Temperature",
                        position: "bottom_right",
                          useCelsius: false,
                          sensors: [
                                script: "ds18b20",
                                args: "123456"
                  and everything works as expected.
                  The unit is changed to “°F” and the “temperature_f” value is chosen.
                    @wishmaster270
                    I will try again! Thanks for checking!
