    MMM-Temperature
    9 Posts 4 Posters 3.7k Views 4 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @Hadr1en
      @Hadr1en Hi, the module expects an json string as output of the script it executes. There is a section in the readme which shows an example:
         "humidity": 32.61236572265625,
         "temperature_c": 25.50150878906249, //Temperature in °C
         "temperature_f": 77.9027158203125, //Temperature in °F
         "error": false
      What kind of error do you get?
        snakestang @wishmaster270
        @wishmaster270
        I know this is an old thread but maybe someone can help. I have everything installed but for the life of me can’t get it to change to fahrenheit. No matter where I put the change line in config it always reads celsius.
        I am using a DS18b20 if it matters.
        Tha ks in advance.
        wishmaster270W 2 Replies Last reply Reply Quote 0
          wishmaster270 Module Developer @snakestang
          @snakestang Hi, I currently do not use the module (and only used the Fahrenheit option during development) in my setup but I will try to setup a simple development environment to check your problem.
            @wishmaster270
            No worries. Thanks for your time. Not the end of the world by any means.
              @snakestang
              i tried the following configuration
                    module: "MMM-Temperature",
                    position: "bottom_right",
                      useCelsius: false,
                      sensors: [
                            script: "ds18b20",
                            args: "123456"
              and everything works as expected.
              The unit is changed to “°F” and the “temperature_f” value is chosen.
                @wishmaster270
                I will try again! Thanks for checking!
