    ALT not doing anything
    44 Posts 6 Posters 26.4k Views 5 Watching
    • ankonaskiff17A
      ankonaskiff17
      Been a while since I’ve built an MM so maybe something has changed but when I hit the ALT key to get at Terminal, take MM out of full-screen nothing happens.
      Loaded 64 bit Pi OS on new micro SD Card then ran @sdetweil install script and MM installed just fine and looks like the typical newly installed MM but nothing happens when I tap ALT.
      I’ve formatted and installed Pi OS then used @sdetweil installation script twice and it happens each time.
      Is there some new issue or some script to resolve this behavior? I’ve built a few of these over the last few years but this is new.
      • F
        Fifteen15Studios
        It looks like nobody has posted a solution, but I posted a similar post months ago. Someone in there gave me the answer.
        In MagicMirror/js/electron.js, change the line
        electronOptionsDefaults.frame = false;
        to
        electronOptionsDefaults.frame = true;
        Then add
        electronOptionsDefaults.autoHideMenuBar = true;
        If you’re using PM2 to load your mirror, you’ll have to stop and start PM2
          sdetweil @ankonaskiff17
          @ankonaskiff17 yes, electron changed the key handling again
          alt-spacebar. works as always
          swvalentiS 1 Reply Last reply
          • swvalentiS
            swvalenti Project Sponsor @sdetweil
            Control M
            ankonaskiff17A S 2 Replies Last reply
            • ankonaskiff17A
              ankonaskiff17 @swvalenti
              @swvalenti @sdetweil Thanks. “Hey there sexy!” was getting old.
                sdetweil @swvalenti
                @swvalenti yes, but ctrl-m minimizes, where alt-spacebar brings up the menu, like alt used to do
                ankonaskiff17A 1 Reply Last reply
                • ankonaskiff17A
                  ankonaskiff17 @sdetweil
                  @sdetweil Bad news…FWIW ALT-spacebar does nothing and CTL + M kills it.
                    @ankonaskiff17 ctrl-m is minimize, ctrl-q quits
                    alt AND spacebar works for me
                    • ankonaskiff17A
                      @sdetweil Quick change of subject. How do I find a list of installed packages on Pi WITH timestamp
                      Something unannounced just installed itself on this Pi
                      Not a fan of surprise unannounced installations out of the blue on my computers
                        @ankonaskiff17 sorry no idea.
                        • ankonaskiff17A
                          ankonaskiff17
                          Regarding yesterdays change of subject question, my concern was if somehow a virus was loading itself on my Pi.
                          I kind of think I know what the problem is but it seems like an install problem because 1) it is repeatable and 2) it is like this straight from the install.
                          I don’t know the official name for the “bar” but it is missing.
                          This is from am MM I built a couple of years ago.
                          Non-existent in this most recent install. I saw it missing yesterday. That missing bar was what prompted my question.
                          I’ve installed via @sdetweil script
                            @ankonaskiff17 which os?
                            lsb_release -a
                            uname -a
                            • ankonaskiff17A
                              ~ $ lsb_release -a
                              No LSB modules are available.
                              Distributor ID: Debian
                              Description: Debian GNU/Linux 11 (bullseye)
                              Release: 11
                              Codename: bullseye
                              ~ $ uname -a
                              Linux PiPics 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
                              My installation process amounts to formating micro-sd card, firing up Raspberry Pi’s installer, install their posted software.
                              Immediately do apt update, apt full-upgrade then head to the MM link to your Github based installer. Copy your script, hit enter.
                              When asked about screensaver & pm2 I answer yes to both.
                                @ankonaskiff17 yes, it’s the 64 bit os… SOOOOO we don’t know… we don’t test there. but it’s electron that is managing the keyboard in the browser
                                alt-spacebar has been working for 30 years.
                                • ankonaskiff17A
                                  @sdetweil is the aarch64 what is telling you 64 bit?
                                  I am about 95% sure that the other MM I referenced having built a couple of years ago is 64 bit also.
                                  ALT on that MM brings up the toolbar as expected.
                                  BUT…when I do ALT+Spacebar it does not give the same result.
                                  The way I’m reading your comments ALT and ALT+Spacebar should give the same result, or did in the past.
                                  Not being a programmer many of these commands I am unaware of.
                                    @ankonaskiff17 I never tried alt by itself, ever.
                                    yes aarch64 is 64 bit, armv7l is 32 bit
                                    raspi 64 bit came out last year. was a beta before that… beta pretty unstable
                                    bugsounetB ankonaskiff17A 2 Replies Last reply
                                    • bugsounetB
                                      bugsounet Banned @sdetweil
                                      @sdetweil no,no it’s a 32Bits OS with X64 kernel
                                      It’s now the new rule for 32Bits version
                                      you can have 32bits kernel with 32bits Os by editing /boot/config.txt
                                      and adding this line at the end:
                                      arm_64bit=0
                                      result is:
                                      pi@raspberrypi:~/MagicMirror $ uname -a
                                      Linux raspberrypi 6.1.21-v7l+ #1642 SMP Mon Apr  3 17:22:30 BST 2023 armv7l GNU/Linux
                                      by default arm_64bit=1 for apply x64 kernel
                                      • ankonaskiff17A
                                        @sdetweil This is why ALT
                                        In any case neither ALT, ALT+Spacebar or CTL+m allow me to easily move back and forth between configuring and checking the Magic Mirror.
                                        This is all being done on Pi4B’s BTW.
                                        I have formatted the sd card on the original Pi4B now 4 times and installed MM 4 times right behing the Pi OS fresh install. 64 bit
                                        After you made mention of 32 bit I took a second Pi 4B, installed 32 bit Pi OS and then right behind I installed MM
                                        The existing, functioning MM is fine. I hit ALT and it does just what the attached picture says it should do.
                                        So I have two Pi 4B’s, one of which is running 32 bit Pi OS and one running 64 bit Pi OS.
                                        Neither will let me get access to the toolbar in any combination of keystrokes.
                                          @ankonaskiff17 “usage”, oh you mean the DOC… hahaha…
                                          things change way too fast
                                          • ankonaskiff17A
                                            @sdetweil Hitting ALT always worked in the past and continues to work on the older MM. I don’t pull these things out of thin air. I get your point about documentation though.
                                            You mentioned early in this conversation about that being something that is done in Electron. Electron is way beyond my knowledge level. But searching Google it seems that somewhere in Electron there is titleBarStyle and it is currently set to hidden . I haven’t a clue as to how to run that to ground but almost like someone was messing with the code trying to make a kiosk but didn’t do that locally.
                                            • ankonaskiff17A
                                              @sdetweil This is in regards to auto-starting MM.
                                              When installing NPM per the documentation, do you install at ~$ or at/MagicMirror $
                                              It isn’t real clear because half way through that sequence it has cd ~ which you could take to mean you are installing npm at the MagicMirror level then you back up to put the auto start script at root?
                                              I kinda-sorta think I understand what is going on with this ALT problem but I’m out of gas and will confirm in the morning.
