    4k Dashboard
    21 Posts 13 Posters 17.1k Views 17 Watching
      sdetweil @N6NG
      @N6NG from the doc
      N6NGN 1 Reply Last reply Reply Quote 0
      • N6NGN
        N6NG @sdetweil
        @sdetweil I don’t find fadePoint in the config.js file. Do I need to add it or is it in the calendar.css ?
          sdetweil @N6NG
          @N6NG those are config.js settings
          if not specified, then the default value is used.
          so you can use
          fade: false
          to turn off fade
          or
          fadepoint:4
          (for example to start the fade at 4th entry)
          • N6NGN
            N6NG @sdetweil
            @sdetweil I added the fadePoint ok but it only works on the event name. All the times are still faded which is what I don’t want faded.
            • BKeyportB
              BKeyport Module Developer @cowboysdude
              @cowboysdude As am I. This would be VERY interesting.
              • N6NGN
                N6NG @BKeyport
                @BKeyport That’s why I asked the person with the 4K mirror.
                He had the calendar without faded times and that’s what I want to do.
                  mvrlogins @N6NG
                  @N6NG
                  Sorry for the late reply - missed your post
                  Following is my calendar config in config.sys
                        module: 'calendar',
                        position: 'top_right',
                        header: 'CALENDAR',
                          maximumEntries: 21,
                          maxTitleLength: 25,
                          fade: false,
                          displaySymbol: false,
                          timeFormat: 'relative',
                          nextDaysRelative: true,
                          dateFormat: 'ddd MMM DD HH:mm',
                          fullDayEventDateFormat: 'ddd MMM DD',
                              symbol: 'home',
                              url: 'webcal://p49-caldav.icloud.com/published/2/abcdefghijkl......mnopqrs',
                              maximumEntries: 19
                  Hope that helps
                  • N6NGN
                    N6NG @mvrlogins
                    @mvrlogins Thanks…
                    Dennis
                      rdwilbrink
                      your mirror looks nice. Can you share your css?
                      • G
                        greedyvegan
                        thanks for this, it’s very inspiring.
                          cyberphox
                          Didd the CSS ever get shared?
