    4k Dashboard
    21 Posts 13 Posters 16.7k Views 17 Watching
      cyberphox @Aardal1
      @aardal1 I wish I had to patience and creativity to really dive into CSS…instead I just wait for something like this to come along and shamelessly try and copy the code!
      Great looking board!
      cowboysdudeC F 2 Replies Last reply Reply Quote 0
      • cowboysdudeC Offline
        cowboysdude Module Developer @cyberphox
        @cyberphox Eh don’t feel bad… I many of us do the same. LOL
        I’d be VERY interested in his css for this…
        BKeyportB 1 Reply Last reply Reply Quote 2
        • F Offline
          frog @cyberphox
          @cyberphox
          Have you looked at https://github.com/tchellomello/python-ring-doorbell
          C 1 Reply Last reply Reply Quote 2
            cyberphox @frog
            @frog I haven’t…although I’m unsure what it has to do with CSS
              mvrlogins @Python
              @python
              I have a Model X and also use Teslamate
              I’ve incorporated that into my mirror as below:
              alt text
              Using this module -
              https://github.com/spitzlbergerj/MMM-TeslaLogger
              And a little node script within an iframe to get the map
              N6NGN 1 Reply Last reply Reply Quote 0
                SoleLo @Aardal1
                @Aardal1 can you share your custom code for MMM-Teslamate?
                • N6NGN Offline
                  N6NG @mvrlogins
                  @mvrlogins Nice mirror… How did you keep the calendar from fading the time section…I’ve been trying and can’t find out where to turn off the fade… Thanks
                  Dennis N6NG
                    sdetweil @N6NG
                    @N6NG from the doc
                    • N6NGN Offline
                      N6NG @sdetweil
                      @sdetweil I don’t find fadePoint in the config.js file. Do I need to add it or is it in the calendar.css ?
                        sdetweil @N6NG
                        @N6NG those are config.js settings
                        if not specified, then the default value is used.
                        so you can use
                        fade: false
                        to turn off fade
                        or
                        fadepoint:4
                        (for example to start the fade at 4th entry)
                        • N6NGN Offline
                          N6NG @sdetweil
                          @sdetweil I added the fadePoint ok but it only works on the event name. All the times are still faded which is what I don’t want faded.
                          • BKeyportB Offline
                            BKeyport Module Developer @cowboysdude
                            @cowboysdude As am I. This would be VERY interesting.
                            • N6NGN Offline
                              N6NG @BKeyport
                              @BKeyport That’s why I asked the person with the 4K mirror.
                              He had the calendar without faded times and that’s what I want to do.
                                mvrlogins @N6NG
                                @N6NG
                                Sorry for the late reply - missed your post
                                Following is my calendar config in config.sys
                                      module: 'calendar',
                                      position: 'top_right',
                                      header: 'CALENDAR',
                                        maximumEntries: 21,
                                        maxTitleLength: 25,
                                        fade: false,
                                        displaySymbol: false,
                                        timeFormat: 'relative',
                                        nextDaysRelative: true,
                                        dateFormat: 'ddd MMM DD HH:mm',
                                        fullDayEventDateFormat: 'ddd MMM DD',
                                            symbol: 'home',
                                            url: 'webcal://p49-caldav.icloud.com/published/2/abcdefghijkl......mnopqrs',
                                            maximumEntries: 19
                                Hope that helps
                                • N6NGN Offline
                                  N6NG @mvrlogins
                                  @mvrlogins Thanks…
                                  Dennis
                                    rdwilbrink
                                    your mirror looks nice. Can you share your css?
                                    • G Offline
                                      greedyvegan
                                      thanks for this, it’s very inspiring.
                                        cyberphox
                                        Didd the CSS ever get shared?
