    4k Dashboard
    21 Posts 13 Posters 15.5k Views 17 Watching
      cyberphox @Aardal1
      @aardal1 I wish I had to patience and creativity to really dive into CSS…instead I just wait for something like this to come along and shamelessly try and copy the code!
      Great looking board!
      cowboysdudeC F 2 Replies Last reply Reply Quote 0
      • cowboysdudeC Offline
        cowboysdude Module Developer @cyberphox
        @cyberphox Eh don’t feel bad… I many of us do the same. LOL
        I’d be VERY interested in his css for this…
        BKeyportB 1 Reply Last reply Reply Quote 2
        • F Offline
          frog @cyberphox
          @cyberphox
          Have you looked at https://github.com/tchellomello/python-ring-doorbell
          C 1 Reply Last reply Reply Quote 2
            cyberphox @frog
            @frog I haven’t…although I’m unsure what it has to do with CSS
              mvrlogins @Python
              @python
              I have a Model X and also use Teslamate
              I’ve incorporated that into my mirror as below:
              alt text
              Using this module -
              https://github.com/spitzlbergerj/MMM-TeslaLogger
              And a little node script within an iframe to get the map
              N6NGN 1 Reply Last reply Reply Quote 0
                SoleLo @Aardal1
                @Aardal1 can you share your custom code for MMM-Teslamate?
                • N6NGN Offline
                  N6NG @mvrlogins
                  @mvrlogins Nice mirror… How did you keep the calendar from fading the time section…I’ve been trying and can’t find out where to turn off the fade… Thanks
                  Dennis N6NG
                    sdetweil @N6NG
                    @N6NG from the doc
                    • N6NGN Offline
                      N6NG @sdetweil
                      @sdetweil I don’t find fadePoint in the config.js file. Do I need to add it or is it in the calendar.css ?
                        sdetweil @N6NG
                        @N6NG those are config.js settings
                        if not specified, then the default value is used.
                        so you can use
                        fade: false
                        to turn off fade
                        or
                        fadepoint:4
                        (for example to start the fade at 4th entry)
