    4k Dashboard
    21 Posts 13 Posters 17.3k Views 17 Watching
    • F
      frog @cyberphox
      @cyberphox
      Have you looked at https://github.com/tchellomello/python-ring-doorbell
      C 1 Reply Last reply
      Reply Quote 2
        cyberphox @frog
        @frog I haven’t…although I’m unsure what it has to do with CSS
          mvrlogins @Python
          @python
          I have a Model X and also use Teslamate
          I’ve incorporated that into my mirror as below:
          alt text
          Using this module -
          https://github.com/spitzlbergerj/MMM-TeslaLogger
          And a little node script within an iframe to get the map
          N6NGN 1 Reply Last reply
            SoleLo @Aardal1
            @Aardal1 can you share your custom code for MMM-Teslamate?
            • N6NGN
              N6NG @mvrlogins
              @mvrlogins Nice mirror… How did you keep the calendar from fading the time section…I’ve been trying and can’t find out where to turn off the fade… Thanks
              Dennis N6NG
                sdetweil @N6NG
                @N6NG from the doc
                • N6NGN
                  N6NG @sdetweil
                  @sdetweil I don’t find fadePoint in the config.js file. Do I need to add it or is it in the calendar.css ?
                    sdetweil @N6NG
                    @N6NG those are config.js settings
                    if not specified, then the default value is used.
                    so you can use
                    fade: false
                    to turn off fade
                    or
                    fadepoint:4
                    (for example to start the fade at 4th entry)
                    • N6NGN
                      N6NG @sdetweil
                      @sdetweil I added the fadePoint ok but it only works on the event name. All the times are still faded which is what I don’t want faded.
                      • BKeyportB
                        BKeyport Module Developer @cowboysdude
                        @cowboysdude As am I. This would be VERY interesting.
                        • N6NGN
                          N6NG @BKeyport
                          @BKeyport That’s why I asked the person with the 4K mirror.
                          He had the calendar without faded times and that’s what I want to do.
                          M 1 Reply Last reply
                            mvrlogins @N6NG
                            @N6NG
                            Sorry for the late reply - missed your post
                            Following is my calendar config in config.sys
                                  module: 'calendar',
                                  position: 'top_right',
                                  header: 'CALENDAR',
                                    maximumEntries: 21,
                                    maxTitleLength: 25,
                                    fade: false,
                                    displaySymbol: false,
                                    timeFormat: 'relative',
                                    nextDaysRelative: true,
                                    dateFormat: 'ddd MMM DD HH:mm',
                                    fullDayEventDateFormat: 'ddd MMM DD',
                                        symbol: 'home',
                                        url: 'webcal://p49-caldav.icloud.com/published/2/abcdefghijkl......mnopqrs',
                                        maximumEntries: 19
                            Hope that helps
                            • N6NGN
                              N6NG @mvrlogins
                              @mvrlogins Thanks…
                              Dennis
                                rdwilbrink
                                your mirror looks nice. Can you share your css?
                                • G
                                  greedyvegan
                                  thanks for this, it’s very inspiring.
                                    cyberphox
                                    Didd the CSS ever get shared?
