    4k Dashboard
    21 Posts 13 Posters 17.1k Views 17 Watching
      cyberphox @frog
      @frog I haven’t…although I’m unsure what it has to do with CSS
        mvrlogins @Python
        @python
        I have a Model X and also use Teslamate
        I’ve incorporated that into my mirror as below:
        alt text
        Using this module -
        https://github.com/spitzlbergerj/MMM-TeslaLogger
        And a little node script within an iframe to get the map
        N6NGN 1 Reply Last reply Reply Quote 0
          SoleLo @Aardal1
          @Aardal1 can you share your custom code for MMM-Teslamate?
          • N6NGN
            N6NG @mvrlogins
            @mvrlogins Nice mirror… How did you keep the calendar from fading the time section…I’ve been trying and can’t find out where to turn off the fade… Thanks
            Dennis N6NG
              sdetweil @N6NG
              @N6NG from the doc
              • N6NGN
                N6NG @sdetweil
                @sdetweil I don’t find fadePoint in the config.js file. Do I need to add it or is it in the calendar.css ?
                  sdetweil @N6NG
                  @N6NG those are config.js settings
                  if not specified, then the default value is used.
                  so you can use
                  fade: false
                  to turn off fade
                  or
                  fadepoint:4
                  (for example to start the fade at 4th entry)
                  • N6NGN
                    N6NG @sdetweil
                    @sdetweil I added the fadePoint ok but it only works on the event name. All the times are still faded which is what I don’t want faded.
                    • BKeyportB
                      BKeyport Module Developer @cowboysdude
                      @cowboysdude As am I. This would be VERY interesting.
                      • N6NGN
                        N6NG @BKeyport
                        @BKeyport That’s why I asked the person with the 4K mirror.
                        He had the calendar without faded times and that’s what I want to do.
                          mvrlogins @N6NG
                          @N6NG
                          Sorry for the late reply - missed your post
                          Following is my calendar config in config.sys
                                module: 'calendar',
                                position: 'top_right',
                                header: 'CALENDAR',
                                  maximumEntries: 21,
                                  maxTitleLength: 25,
                                  fade: false,
                                  displaySymbol: false,
                                  timeFormat: 'relative',
                                  nextDaysRelative: true,
                                  dateFormat: 'ddd MMM DD HH:mm',
                                  fullDayEventDateFormat: 'ddd MMM DD',
                                      symbol: 'home',
                                      url: 'webcal://p49-caldav.icloud.com/published/2/abcdefghijkl......mnopqrs',
                                      maximumEntries: 19
                          Hope that helps
                          • N6NGN
                            N6NG @mvrlogins
                            @mvrlogins Thanks…
                            Dennis
                              rdwilbrink
                              your mirror looks nice. Can you share your css?
                              • G
                                greedyvegan
                                thanks for this, it’s very inspiring.
                                  cyberphox
                                  Didd the CSS ever get shared?
