    4k Dashboard
    21 Posts 13 Posters 16.0k Views 17 Watching
      mlhote
      Hello
      great job
      that’s wonderful
      To rotate the screen you did it in css or with the classic interface.
      If it’s not too much abuse can you show us your custom css to learn…
        Python
        Very nice layout!
        I have a Model 3 on order and already have teslamate setup. I’m looking forward to making a “Tesla Dashboard” specific for my garage similar to how you’re showing your P85 and power use.
          cyberphox @Aardal1
          @aardal1 I wish I had to patience and creativity to really dive into CSS…instead I just wait for something like this to come along and shamelessly try and copy the code!
          Great looking board!
          cowboysdudeC F 2 Replies Last reply Reply Quote 0
          • cowboysdudeC Offline
            cowboysdude Module Developer @cyberphox
            @cyberphox Eh don’t feel bad… I many of us do the same. LOL
            I’d be VERY interested in his css for this…
            BKeyportB 1 Reply Last reply Reply Quote 2
            • F Offline
              frog @cyberphox
              @cyberphox
              Have you looked at https://github.com/tchellomello/python-ring-doorbell
              C 1 Reply Last reply Reply Quote 2
                cyberphox @frog
                @frog I haven’t…although I’m unsure what it has to do with CSS
                  mvrlogins @Python
                  @python
                  I have a Model X and also use Teslamate
                  I’ve incorporated that into my mirror as below:
                  alt text
                  Using this module -
                  https://github.com/spitzlbergerj/MMM-TeslaLogger
                  And a little node script within an iframe to get the map
                  N6NGN 1 Reply Last reply Reply Quote 0
                    SoleLo @Aardal1
                    @Aardal1 can you share your custom code for MMM-Teslamate?
                    • N6NGN Offline
                      N6NG @mvrlogins
                      @mvrlogins Nice mirror… How did you keep the calendar from fading the time section…I’ve been trying and can’t find out where to turn off the fade… Thanks
                      Dennis N6NG
                        sdetweil @N6NG
                        @N6NG from the doc
                        • N6NGN Offline
                          N6NG @sdetweil
                          @sdetweil I don’t find fadePoint in the config.js file. Do I need to add it or is it in the calendar.css ?
                            sdetweil @N6NG
                            @N6NG those are config.js settings
                            if not specified, then the default value is used.
                            so you can use
                            fade: false
                            to turn off fade
                            or
                            fadepoint:4
                            (for example to start the fade at 4th entry)
                            • N6NGN Offline
                              N6NG @sdetweil
                              @sdetweil I added the fadePoint ok but it only works on the event name. All the times are still faded which is what I don’t want faded.
                              • BKeyportB Offline
                                BKeyport Module Developer @cowboysdude
                                @cowboysdude As am I. This would be VERY interesting.
                                • N6NGN Offline
                                  N6NG @BKeyport
                                  @BKeyport That’s why I asked the person with the 4K mirror.
                                  He had the calendar without faded times and that’s what I want to do.
                                    mvrlogins @N6NG
                                    @N6NG
                                    Sorry for the late reply - missed your post
                                    Following is my calendar config in config.sys
                                          module: 'calendar',
                                          position: 'top_right',
                                          header: 'CALENDAR',
                                            maximumEntries: 21,
                                            maxTitleLength: 25,
                                            fade: false,
                                            displaySymbol: false,
                                            timeFormat: 'relative',
                                            nextDaysRelative: true,
                                            dateFormat: 'ddd MMM DD HH:mm',
                                            fullDayEventDateFormat: 'ddd MMM DD',
                                                symbol: 'home',
                                                url: 'webcal://p49-caldav.icloud.com/published/2/abcdefghijkl......mnopqrs',
                                                maximumEntries: 19
                                    Hope that helps
                                    • N6NGN Offline
                                      N6NG @mvrlogins
                                      @mvrlogins Thanks…
                                      Dennis
                                        rdwilbrink
                                        your mirror looks nice. Can you share your css?
                                        • G Offline
                                          greedyvegan
                                          thanks for this, it’s very inspiring.
                                            cyberphox
                                            Didd the CSS ever get shared?
