    MM digital display hung like a picture
    24 Posts 9 Posters 17.3k Views 9 Watching
    • ankonaskiff17A
      ankonaskiff17 @rmonkey
      @rmonkey That is really really nice.
      R 1 Reply Last reply
        rmonkey @ankonaskiff17
        @ankonaskiff17 said in MM digital display hung like a picture:
        Thank you! I’m very proud of the results.
        Installing the recessed outlet – the task I was most worried about – turned out to be the easiest part.
        And I really can’t stress enough how helpful this forum was during the process.
        F 1 Reply Last reply
          jbat66 @rmonkey
          @rmonkey I really like how thin it is.
          • UncleRogerU
            UncleRoger
            Looks great!
            I would love to see a picture of the recessed outlet and hear more about how you did that.
            Also, is the monitor one of the portable monitors you can find on Amazon?
              rmonkey @UncleRoger
              @UncleRoger said in MM digital display hung like a picture:
              Yes, the monitor was a $75 Vilva 15" portable monitor from Amazon.
              As for the outlet, this was very simple because there is an outlet directly below the spot. Because drywall is (usually) empty, I was able to simply tap the existing outlet. I cut the hole for the recessed old-work box and fished romex straight up to it. Pulled the romex into the box and installed the box. Then installed a recepticle with both USB-A and USB-C.
              The biggest hiccup is it didn’t work. Then I remembered I forgot to flip the circuit breaker back on. :face_with_rolling_eyes:
              Here’s a pic:
              Lastly, I hung the frame with picture wire which wasn’t optimal – it hung away from the wall and you could see the wires behind it. An inexpensive french cleat solved that.
              UncleRogerU P 2 Replies Last reply
              Reply Quote 2
              • UncleRogerU
                UncleRoger @rmonkey
                @rmonkey
                That’s awesome. Thanks for the additional info. I may try to do the same thing at some point, if I can get my wife to let me cut into the wall. 8^)
                I’m planning on using a french cleat for my board that I’m working on in the kitchen; it seems the best way to go all around.
                Great work and thanks!
                  rmonkey @UncleRoger
                  If you don’t already know how to patch drywall wall, learn how. There are tons of great tutorials on YouTube and it’s inexpensive.
                  That will take the trepidation out of cutting a hole in your wall! I’ve been reparing my own drywall for years and even I’ve never permanantly screwed things up.
                  Oh, I have the amazon links for the box and receptacle if you decide to take the plunge:
                  https://www.amazon.com/gp/product/B002W6ZOR4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
                  https://www.amazon.com/gp/product/B07ZJC751K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
                  • F
                    fulviolcabrera @rmonkey
                    @rmonkey nice mm display, would you mind sharing what modules you used?
                      rmonkey
                      MMM-ModuleScheduler
                      MMM-BackgroundSlideshow
                      clock
                      MMM-OneTracker
                      calendar
                      MMM-DarkSkyForecast
                      MMM-NFL
                      MMM-WiFiPassword
                      MMM-OnSpotify
                      • MZ-BERM
                        MZ-BER
                        Nice, really like the clean and slim design. :thumbs_up: Are you planning to install a PIR sensor? Or is your display running 24/7?
                          rmonkey
                          I’m thinking about a PIR down the road.
                          I like the idea of only having the background slideshow on and then info modules appear when you walk up to it.
                          Right now it kills all modules around midnight and comes back on early morning.
                          J 1 Reply Last reply
                            jbat66 @rmonkey
                            @rmonkey
                            I wrote a bash script that will take lat and lon, do an API call to Openweather, and get the sunset and sunrise times. then it will schedule a sunrise program and a sunset program to run via ‘at’. You can have +/- offsets for sunrise/sunset and you can just have a settime. So what I’m doing is doing api calls to MM at 10pm to turn off my background images, and then dim the screen via the remote api. then at 15 min after sunrise it puts it back to normal.
                            I have never published to github, but probably will at some point. Do you think this would be something folks would want? it is not a module. it does require jq and at to be installed on the linux system.
                            Reply Quote 2
                              rmonkey @jbat66
                              Wow, @jbat66 , that sounds amazing and waaayyy more sophisticated than what I’m doing (kill all modules at a set time and reboot in the morning).
                              Whether there are other people interested in that, I couldn’t say. My take is that I could see 5 people using it, 20 people learning from what you publish and maybe, maybe one person says thanks?
                              But, if it’s no big deal, share your stuff. I know I learned a lot from people here, although I’m at a much lower level than you!
                                jbat66 @rmonkey
                                @rmonkey Thanks. I will get it published, don’t know when, but will get it published
                                Reply Quote 2
                                  jonfe @jbat66
                                  @jbat66 very nice Mirror, I hadn’t seen the wifi QR code module before.
                                    physics90 @rmonkey
                                    @rmonkey nice option with the French cleat.
                                    • R rrslssr referenced this topic on
                                      rmonkey
                                      One other thing – it looks like @rrslssr is running a similar approach specifically for travel photos – and I want to share a tip.
                                      My mirror runs a combination of some of my own travel photos and places I’ve been from Unsplash.
                                      To make the modules more legible and pop better, I made a photoshop template. The top layer is a very light transparent to black (from the center) radial gradient. My backgrounds are the lower layer.
                                      This applies a very light vignetting that is consistent among all the background images. I experimented until I found the gradient settings for the top layer that were perfect to my eyes.
                                      I’m sure there are easier or smarter ways to add vignetting, but this works for me.
                                      R J 2 Replies Last reply
                                        rrslssr @rmonkey
                                        @rmonkey I have started searching for a picture frame to use for the display.
                                        Would you please tell me the size of the picture frame you used?
                                          jbat66 @rmonkey
                                          @rmonkey If you use MMM-BackgroundSlideShow, it has a radial option that is basically a vignette.
                                            rmonkey
                                            @rrslssr , I took the monitor to Michaels and asked for a custom frame and matte. I told them I wanted a 2.5" mat out to the frame (make sure to specify the display only, not display plus bezels).
                                            Then I picked a frame that I liked that met the minimum depth requirements for the Pi Zero 2.
                                            I also made sure I got gallery glass, which has an antireflective coating.
                                            They kept messing up the matte and I ended up going to Hobby Lobby. They recut the matte correctly and even cut the foam core used to hold everything in place.
                                            Reply Quote 2
