    MM digital display hung like a picture
    24 Posts 9 Posters 17.3k Views 9 Watching
      rmonkey @UncleRoger
      @UncleRoger said in MM digital display hung like a picture:
      I may try to do the same thing at some point, if I can get my wife to let me cut into the wall. 8^)
      If you don’t already know how to patch drywall wall, learn how. There are tons of great tutorials on YouTube and it’s inexpensive.
      That will take the trepidation out of cutting a hole in your wall! I’ve been reparing my own drywall for years and even I’ve never permanantly screwed things up.
      Oh, I have the amazon links for the box and receptacle if you decide to take the plunge:
      https://www.amazon.com/gp/product/B002W6ZOR4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
      https://www.amazon.com/gp/product/B07ZJC751K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
      • F
        fulviolcabrera @rmonkey
        @rmonkey nice mm display, would you mind sharing what modules you used?
          rmonkey
          MMM-ModuleScheduler
          MMM-BackgroundSlideshow
          clock
          MMM-OneTracker
          calendar
          MMM-DarkSkyForecast
          MMM-NFL
          MMM-WiFiPassword
          MMM-OnSpotify
          • MZ-BERM
            MZ-BER
            Nice, really like the clean and slim design. :thumbs_up: Are you planning to install a PIR sensor? Or is your display running 24/7?
              rmonkey
              I’m thinking about a PIR down the road.
              I like the idea of only having the background slideshow on and then info modules appear when you walk up to it.
              Right now it kills all modules around midnight and comes back on early morning.
              J 1 Reply Last reply
                jbat66 @rmonkey
                @rmonkey
                I wrote a bash script that will take lat and lon, do an API call to Openweather, and get the sunset and sunrise times. then it will schedule a sunrise program and a sunset program to run via ‘at’. You can have +/- offsets for sunrise/sunset and you can just have a settime. So what I’m doing is doing api calls to MM at 10pm to turn off my background images, and then dim the screen via the remote api. then at 15 min after sunrise it puts it back to normal.
                I have never published to github, but probably will at some point. Do you think this would be something folks would want? it is not a module. it does require jq and at to be installed on the linux system.
                R 1 Reply Last reply
                Reply Quote 2
                  rmonkey @jbat66
                  Wow, @jbat66 , that sounds amazing and waaayyy more sophisticated than what I’m doing (kill all modules at a set time and reboot in the morning).
                  Whether there are other people interested in that, I couldn’t say. My take is that I could see 5 people using it, 20 people learning from what you publish and maybe, maybe one person says thanks?
                  But, if it’s no big deal, share your stuff. I know I learned a lot from people here, although I’m at a much lower level than you!
                    jbat66 @rmonkey
                    @rmonkey Thanks. I will get it published, don’t know when, but will get it published
                    Reply Quote 2
                      jonfe @jbat66
                      @jbat66 very nice Mirror, I hadn’t seen the wifi QR code module before.
                        physics90 @rmonkey
                        @rmonkey nice option with the French cleat.
                        • R rrslssr referenced this topic on
                          rmonkey
                          One other thing – it looks like @rrslssr is running a similar approach specifically for travel photos – and I want to share a tip.
                          My mirror runs a combination of some of my own travel photos and places I’ve been from Unsplash.
                          To make the modules more legible and pop better, I made a photoshop template. The top layer is a very light transparent to black (from the center) radial gradient. My backgrounds are the lower layer.
                          This applies a very light vignetting that is consistent among all the background images. I experimented until I found the gradient settings for the top layer that were perfect to my eyes.
                          I’m sure there are easier or smarter ways to add vignetting, but this works for me.
                          R J 2 Replies Last reply
                            rrslssr @rmonkey
                            @rmonkey I have started searching for a picture frame to use for the display.
                            Would you please tell me the size of the picture frame you used?
                              jbat66 @rmonkey
                              @rmonkey If you use MMM-BackgroundSlideShow, it has a radial option that is basically a vignette.
                                rmonkey
                                @rrslssr , I took the monitor to Michaels and asked for a custom frame and matte. I told them I wanted a 2.5" mat out to the frame (make sure to specify the display only, not display plus bezels).
                                Then I picked a frame that I liked that met the minimum depth requirements for the Pi Zero 2.
                                I also made sure I got gallery glass, which has an antireflective coating.
                                They kept messing up the matte and I ended up going to Hobby Lobby. They recut the matte correctly and even cut the foam core used to hold everything in place.
                                Reply Quote 2
                                  rmonkey
                                  @jbat66, that’s fantastic. I’ll experiment with that when I do a refresh of the whole deal. Thank you!
