    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 119.4k Views 18 Watching
    • H
      H3L1o150
      @Mareus you tried run the install with “sudo” command?
        Mareus
        Yes i tried sudo, as well as npm install -g (also together with sudo).
        • K
          kerijn
          Installing with sudo worked for me. Thank you!
          • H
            H3L1o150
            @Bangee said in MMM-PIR-Sensor - White Screen:
            ok so lets go step by step:
            cd ~/MagicMirror/modules/
            now we will remove the PIR folder:
            rm -rf MMM-PIR-Sensor
            and from here, we’re going to reinstall the MMM-PIR-Sensor modul:
            git clone https://github.com/paviro/MMM-PIR-Sensor.git
            cd MMM-PIR-Sensor
            run the following cmd here:
            npm install and wait, this can take a few minutes.
            Now you’ll have to add pi to gpio
            sudo useradd -g pi gpio
            and reboot your Raspi:
            sudo reboot
            You’ll have to connect your PIR Sensor the right way with your Raspi.
            I’ve connected my PIR Sensor on the following Pins:
            GPIO
            I’ve got a Pi2 and use Pin 2 for power, Pin 6 for Ground and Pin 15 for Data.
            – correctin grn pin
            PIR Sensor
            and dont forget to add the config :-)
            Attempts to remove and install the module again as the user @Bangee said
            Worked with me
            K 1 Reply Last reply
            Reply Quote 3
            • K
              kerijn @H3L1o150
              • K
                kerijn
                @H3L1o150 @Bangee I am still having problems with the MMM-PIR-Sensor module. I added the default module to the config.js:
                module: ‘MMM-PIR-Sensor’,
                // See ‘Configuration options’ for more information.
                When I then start the npm I get this error:
                Starting MagicMirror: v2.1.0
                Loading config …
                Loading module helpers …
                WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 48.
                App threw an error during load
                at Error (native)
                at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                at Object.Module._extensions…node (module.js:583:18)
                at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                at Module.load (module.js:473:32)
                at tryModuleLoad (module.js:432:12)
                at Function.Module._load (module.js:424:3)
                at Module.require (module.js:483:17)
                at require (internal/module.js:20:19)
                at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                Whoops! There was an uncaught exception…
                at Error (native)
                Launching application.
                When I leave the module out of the config.js everything works fine again. Any help is appreciated.
                Y 1 Reply Last reply
                • Y
                  yawns Moderator @kerijn
                  @kerijn `
                  npm list
                  look for electron to find out your version number
                  cd modules/MMM-PIR-Sensor
                  npm rebuild --runtime=electron --target=XXX --disturl=https://atom.io/download/atom-shell --build-from-source
                  Replace XXX with the version you found in step 1
                  F 1 Reply Last reply
                  • F
                    fox @yawns
                    @yawns said in MMM-PIR-Sensor Install failing:
                    Thank you @yawns .
                    I did your code lines and got:
                    npm ERR! peer dep missing: grunt@~0.4.0, required by grunt-yamllint@0.2.0
                    and
                    npm WARN prefer global node-gyp@3.5.0 should be installed with
                    Then i repeated
                    npm install
                    in pi@magicpi:~/MagicMirror/modules/MMM-PIR-Sensor $
                    and got againthis errors:
                    > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
                    > electron-rebuild -e ../../node_modules/electron-prebuilt
                    An unhandled error occurred inside electron-rebuild
                    Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                    Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                        at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                        at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                        at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                        at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                        at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/util.js:16:23)
                        at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:97:49)
                        at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:201:15
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                        at Module._compile (module.js:570:32)
                        at Object.Module._extensions..js (module.js:579:10)
                        at Module.load (module.js:487:32)
                        at tryModuleLoad (module.js:446:12)
                        at Function.Module._load (module.js:438:3)
                        at Module.runMain (module.js:604:10)
                        at run (bootstrap_node.js:394:7)
                        at startup (bootstrap_node.js:149:9)
                    npm ERR! Linux 4.4.38-v7+
                    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                    npm ERR! node v6.9.4
                    npm ERR! npm  v4.1.1
                    npm ERR! code ELIFECYCLE
                    npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
                    npm ERR! Exit status 255
                    npm ERR!
                    npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
                    npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                    npm ERR! not with npm itself.
                    npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                    npm ERR!     npm bugs Magic-Mirror-Module-PIR-Sensor
                    npm ERR! Or if that isn't available, you can get their info via:
                    npm ERR!     npm owner ls Magic-Mirror-Module-PIR-Sensor
                    npm ERR!     /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                    Issues With MMM-WatchDog known?
                    https://forum.magicmirror.builders/post/29827
                    Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                      shashank @nemesismega
                      @nemesismega i am getting this error while install the PIR module, all other modules working fine
                      0_1485096342421_upload-2c90fe4e-9f32-4034-87e5-22eb559a82f2
                      • F
                        fox @shashank
                        @shashank said in PIR-Sensor - put your mirror to sleep if not used:
                        i have nearly a similar problem: https://forum.magicmirror.builders/post/12024
                        • K
                          kerijn
                          @yawns Thank you very much for your help but infortunately this didn’t work. I now cannot start Magicmirror anymore even without the MMM-PIR-Sensor module… See error below. I also got the same warning as @fox with missing grunt@…
                          pi@MyPi:~/MagicMirror $ npm start
                          > magicmirror@2.1.0 start /home/pi/MagicMirror
                          > electron js/electron.js
                          npm ERR! Linux 4.4.43-v7+
                          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                          npm ERR! npm  v3.10.10
                          npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                          npm ERR! If you do, this is most likely a problem with the magicmirror package,
                          npm ERR!     electron js/electron.js
                          npm ERR!     npm bugs magicmirror
                          npm ERR!     npm owner ls magicmirror
                          npm ERR!     /home/pi/MagicMirror/npm-debug.log
                          J 1 Reply Last reply
                          • K
                            kerijn
                            I now did a full new installation of MagicMirror with the defauls config.js and got the same error.
                            npm ERR!
                            • F
                              fox
                              @kerijn perhaps @paviro can help us here. It seems to be a general problem.
                                Jopyth Moderator @kerijn
                                @kerijn @fox I think I fixed this issue before, it comes from the changes the Magic Mirror version 2.1.0 introduced. I am not sure, but I think the changes neccessary are almost as simple as here. Will have to test this at home though. Maybe there was something else needed.
                                F K 2 Replies Last reply
                                Reply Quote 2
                                • F
                                  fox @Jopyth
                                  @Jopyth said in MMM-PIR-Sensor Install failing:
                                  Thank you. That fixes the problem for me ! :)
                                  • K
                                    kerijn @Jopyth
                                    @Jopyth This worked for me for the installation as well. Thank you! However, the sensor does not seem to do anything. How can I check whether the sensor is working properly?
                                    M 1 Reply Last reply
                                      Makradon @kerijn
                                      @kerijn said in [MMM-PIR-Sensor] Install failing:
                                      I have the same problem
                                        Jopyth Moderator @Makradon
                                        @Makradon @kerijn I found this. I think you could save this as test.py somewhere on your Pi and see if the output changes when you move and don’t move (set the pin number in the second line) after your start it with python test.py:
                                        import RPi.GPIO as GPIO
                                        pin = 11
                                        GPIO.setwarnings(False)
                                        GPIO.setmode(GPIO.BOARD)
                                        GPIO.setup(pin, GPIO.IN)         #Read output from PIR motion sensor
                                        while True:
                                               i=GPIO.input(pin)
                                               if i==0:                 #When output from motion sensor is LOW
                                                     print "No intruders",i
                                                     time.sleep(0.1)
                                               elif i==1:               #When output from motion sensor is HIGH
                                                     print "Intruder detected",i
                                                     time.sleep(0.1)
                                        T 1 Reply Last reply
                                        • T
                                          thoimi @Jopyth
                                          @Jopyth I had the same problem.
                                          Your work-around (installation) worked for me but the sensor does not seem to do anything…
                                          the test.py script shows me always “1” - also when nothing is moving in the room…
                                            Jopyth Moderator @thoimi
                                            @thoimi Check for the correct wiring (PIN-Numbers can be confusing, there is the BCM numbering and the other one), also make sure GND and 5V are conncted correctly, adjust sensitivity to maximum and time to minimum (so it hopefully switch back and forth quickly), try covering up the sensor under a bowl or something and then put your hand in to test.
                                            When I set up the sensor, I also searched for the error for hours, and at the end my problem was the sensor was plugged into pin 4 (BCM) and not 7 as I thought. Also I think you need to remove the , pull_up_down=GPIO.PUD_DOWN part (PIR example).
                                            • 1 / 4
