    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 119.9k Views 18 Watching
      Mareus
      Yes i tried sudo, as well as npm install -g (also together with sudo).
      • K
        kerijn
        Installing with sudo worked for me. Thank you!
        • H3L1o150H
          H3L1o150
          @Bangee said in MMM-PIR-Sensor - White Screen:
          ok so lets go step by step:
          cd ~/MagicMirror/modules/
          now we will remove the PIR folder:
          rm -rf MMM-PIR-Sensor
          and from here, we’re going to reinstall the MMM-PIR-Sensor modul:
          git clone https://github.com/paviro/MMM-PIR-Sensor.git
          cd MMM-PIR-Sensor
          run the following cmd here:
          npm install and wait, this can take a few minutes.
          Now you’ll have to add pi to gpio
          sudo useradd -g pi gpio
          and reboot your Raspi:
          sudo reboot
          You’ll have to connect your PIR Sensor the right way with your Raspi.
          I’ve connected my PIR Sensor on the following Pins:
          GPIO
          I’ve got a Pi2 and use Pin 2 for power, Pin 6 for Ground and Pin 15 for Data.
          – correctin grn pin
          PIR Sensor
          and dont forget to add the config :-)
          Attempts to remove and install the module again as the user @Bangee said
          Worked with me
          K 1 Reply Last reply
          Reply Quote 3
          • K
            kerijn @H3L1o150
            • K
              kerijn
              @H3L1o150 @Bangee I am still having problems with the MMM-PIR-Sensor module. I added the default module to the config.js:
              module: ‘MMM-PIR-Sensor’,
              // See ‘Configuration options’ for more information.
              When I then start the npm I get this error:
              Starting MagicMirror: v2.1.0
              Loading config …
              Loading module helpers …
              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 48.
              App threw an error during load
              at Error (native)
              at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
              at Object.Module._extensions…node (module.js:583:18)
              at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
              at Module.load (module.js:473:32)
              at tryModuleLoad (module.js:432:12)
              at Function.Module._load (module.js:424:3)
              at Module.require (module.js:483:17)
              at require (internal/module.js:20:19)
              at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
              Whoops! There was an uncaught exception…
              at Error (native)
              Launching application.
              When I leave the module out of the config.js everything works fine again. Any help is appreciated.
              yawnsY 1 Reply Last reply
              • yawnsY
                yawns Moderator @kerijn
                @kerijn `
                npm list
                look for electron to find out your version number
                cd modules/MMM-PIR-Sensor
                npm rebuild --runtime=electron --target=XXX --disturl=https://atom.io/download/atom-shell --build-from-source
                Replace XXX with the version you found in step 1
                foxF 1 Reply Last reply
                • foxF
                  fox @yawns
                  @yawns said in MMM-PIR-Sensor Install failing:
                  Thank you @yawns .
                  I did your code lines and got:
                  npm ERR! peer dep missing: grunt@~0.4.0, required by grunt-yamllint@0.2.0
                  and
                  npm WARN prefer global node-gyp@3.5.0 should be installed with
                  Then i repeated
                  npm install
                  in pi@magicpi:~/MagicMirror/modules/MMM-PIR-Sensor $
                  and got againthis errors:
                  > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
                  > electron-rebuild -e ../../node_modules/electron-prebuilt
                  An unhandled error occurred inside electron-rebuild
                  Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                  Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                      at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                      at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                      at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                      at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                      at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/util.js:16:23)
                      at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:97:49)
                      at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:201:15
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                      at Module._compile (module.js:570:32)
                      at Object.Module._extensions..js (module.js:579:10)
                      at Module.load (module.js:487:32)
                      at tryModuleLoad (module.js:446:12)
                      at Function.Module._load (module.js:438:3)
                      at Module.runMain (module.js:604:10)
                      at run (bootstrap_node.js:394:7)
                      at startup (bootstrap_node.js:149:9)
                  npm ERR! Linux 4.4.38-v7+
                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                  npm ERR! node v6.9.4
                  npm ERR! npm  v4.1.1
                  npm ERR! code ELIFECYCLE
                  npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
                  npm ERR! Exit status 255
                  npm ERR!
                  npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
                  npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                  npm ERR! not with npm itself.
                  npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                  npm ERR!     npm bugs Magic-Mirror-Module-PIR-Sensor
                  npm ERR! Or if that isn't available, you can get their info via:
                  npm ERR!     npm owner ls Magic-Mirror-Module-PIR-Sensor
                  npm ERR!     /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                  Issues With MMM-WatchDog known?
                  https://forum.magicmirror.builders/post/29827
                  Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                    shashank @nemesismega
                    @nemesismega i am getting this error while install the PIR module, all other modules working fine
                    0_1485096342421_upload-2c90fe4e-9f32-4034-87e5-22eb559a82f2
                    • foxF
                      fox @shashank
                      @shashank said in PIR-Sensor - put your mirror to sleep if not used:
                      i have nearly a similar problem: https://forum.magicmirror.builders/post/12024
                      • K
                        kerijn
                        @yawns Thank you very much for your help but infortunately this didn’t work. I now cannot start Magicmirror anymore even without the MMM-PIR-Sensor module… See error below. I also got the same warning as @fox with missing grunt@…
                        pi@MyPi:~/MagicMirror $ npm start
                        > magicmirror@2.1.0 start /home/pi/MagicMirror
                        > electron js/electron.js
                        npm ERR! Linux 4.4.43-v7+
                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                        npm ERR! npm  v3.10.10
                        npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                        npm ERR! If you do, this is most likely a problem with the magicmirror package,
                        npm ERR!     electron js/electron.js
                        npm ERR!     npm bugs magicmirror
                        npm ERR!     npm owner ls magicmirror
                        npm ERR!     /home/pi/MagicMirror/npm-debug.log
                        J 1 Reply Last reply
                        • K
                          kerijn
                          I now did a full new installation of MagicMirror with the defauls config.js and got the same error.
                          npm ERR!
                          • foxF
                            fox
                            @kerijn perhaps @paviro can help us here. It seems to be a general problem.
                              Jopyth Moderator @kerijn
                              @kerijn @fox I think I fixed this issue before, it comes from the changes the Magic Mirror version 2.1.0 introduced. I am not sure, but I think the changes neccessary are almost as simple as here. Will have to test this at home though. Maybe there was something else needed.
                              foxF K 2 Replies Last reply
                              Reply Quote 2
                              • foxF
                                fox @Jopyth
                                @Jopyth said in MMM-PIR-Sensor Install failing:
                                Thank you. That fixes the problem for me ! :)
                                • K
                                  kerijn @Jopyth
                                  @Jopyth This worked for me for the installation as well. Thank you! However, the sensor does not seem to do anything. How can I check whether the sensor is working properly?
                                  M 1 Reply Last reply
                                    Makradon @kerijn
                                    @kerijn said in [MMM-PIR-Sensor] Install failing:
                                    I have the same problem
                                      Jopyth Moderator @Makradon
                                      @Makradon @kerijn I found this. I think you could save this as test.py somewhere on your Pi and see if the output changes when you move and don’t move (set the pin number in the second line) after your start it with python test.py:
                                      import RPi.GPIO as GPIO
                                      pin = 11
                                      GPIO.setwarnings(False)
                                      GPIO.setmode(GPIO.BOARD)
                                      GPIO.setup(pin, GPIO.IN)         #Read output from PIR motion sensor
                                      while True:
                                             i=GPIO.input(pin)
                                             if i==0:                 #When output from motion sensor is LOW
                                                   print "No intruders",i
                                                   time.sleep(0.1)
                                             elif i==1:               #When output from motion sensor is HIGH
                                                   print "Intruder detected",i
                                                   time.sleep(0.1)
                                      T 1 Reply Last reply
                                      • T
                                        thoimi @Jopyth
                                        @Jopyth I had the same problem.
                                        Your work-around (installation) worked for me but the sensor does not seem to do anything…
                                        the test.py script shows me always “1” - also when nothing is moving in the room…
                                          Jopyth Moderator @thoimi
                                          @thoimi Check for the correct wiring (PIN-Numbers can be confusing, there is the BCM numbering and the other one), also make sure GND and 5V are conncted correctly, adjust sensitivity to maximum and time to minimum (so it hopefully switch back and forth quickly), try covering up the sensor under a bowl or something and then put your hand in to test.
                                          When I set up the sensor, I also searched for the error for hours, and at the end my problem was the sensor was plugged into pin 4 (BCM) and not 7 as I thought. Also I think you need to remove the , pull_up_down=GPIO.PUD_DOWN part (PIR example).
                                          • T
                                            thoimi @Jopyth
                                            @Jopyth Thank you for your quick reply! :)
                                            I tried for hours now… I think it’s connected correctly, because when I’m switching the pin-number in the script the script shows me always “0” - with the correct pin-number it shows me “1”…
                                            I also put the sensor in a box - always shows me “1”… completely strange… :/
                                            • 1 / 4
