    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 118.7k Views 18 Watching
      Mareus
      First of all: I am a total newbie to Linux and MagicMirror. I now tried to install the MMM-PIR-Module on my Pi3 an no matter what I am doing, i am always getting the same error:
      npm WARN prefer global node-gyp@3.4.0 should be installed with -g
      epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
      node-gyp rebuild
      make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
        CXX(target) Release/obj.target/epoll/src/epoll.o
        SOLINK_MODULE(target) Release/obj.target/epoll.node
        COPY Release/epoll.node
      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
      Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
      electron-rebuild -e ../../node_modules/electron-prebuilt
      module.js:471
          throw err;
      Error: Cannot find module 'bluebird'
          at Function.Module._resolveFilename (module.js:469:15)
          at Function.Module._load (module.js:417:25)
          at Module.require (module.js:497:17)
          at require (internal/module.js:20:19)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:8:17)
          at Module._compile (module.js:570:32)
          at Object.Module._extensions..js (module.js:579:10)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
      npm ERR! Linux 4.4.38-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
      npm ERR! node v6.9.4
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
      npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
      npm ERR! not with npm itself.
      npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
      npm ERR!     npm bugs Magic-Mirror-Module-PIR-Sensor
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls Magic-Mirror-Module-PIR-Sensor
      npm ERR!     /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
      Does someone have a solution for me?
      Thank you very much!
      Best regards,
      Mareus
      • K
        kerijn
        I have the same problem. It seems to be a problem with the electron module that is renamed. Can somebody please update the module?
        Kerijn.
        • H
          H3L1o150
          @Mareus you tried run the install with “sudo” command?
            Mareus
            Yes i tried sudo, as well as npm install -g (also together with sudo).
            • K
              kerijn
              Installing with sudo worked for me. Thank you!
              • H
                H3L1o150
                @Bangee said in MMM-PIR-Sensor - White Screen:
                ok so lets go step by step:
                cd ~/MagicMirror/modules/
                now we will remove the PIR folder:
                rm -rf MMM-PIR-Sensor
                and from here, we’re going to reinstall the MMM-PIR-Sensor modul:
                git clone https://github.com/paviro/MMM-PIR-Sensor.git
                cd MMM-PIR-Sensor
                run the following cmd here:
                npm install and wait, this can take a few minutes.
                Now you’ll have to add pi to gpio
                sudo useradd -g pi gpio
                and reboot your Raspi:
                sudo reboot
                You’ll have to connect your PIR Sensor the right way with your Raspi.
                I’ve connected my PIR Sensor on the following Pins:
                GPIO
                I’ve got a Pi2 and use Pin 2 for power, Pin 6 for Ground and Pin 15 for Data.
                – correctin grn pin
                PIR Sensor
                and dont forget to add the config :-)
                Attempts to remove and install the module again as the user @Bangee said
                Worked with me
                K 1 Reply Last reply
                Reply Quote 3
                • K
                  kerijn @H3L1o150
                  • K
                    kerijn
                    @H3L1o150 @Bangee I am still having problems with the MMM-PIR-Sensor module. I added the default module to the config.js:
                    module: ‘MMM-PIR-Sensor’,
                    // See ‘Configuration options’ for more information.
                    When I then start the npm I get this error:
                    Starting MagicMirror: v2.1.0
                    Loading config …
                    Loading module helpers …
                    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 48.
                    App threw an error during load
                    at Error (native)
                    at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                    at Object.Module._extensions…node (module.js:583:18)
                    at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                    at Module.load (module.js:473:32)
                    at tryModuleLoad (module.js:432:12)
                    at Function.Module._load (module.js:424:3)
                    at Module.require (module.js:483:17)
                    at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                    Whoops! There was an uncaught exception…
                    at Error (native)
                    Launching application.
                    When I leave the module out of the config.js everything works fine again. Any help is appreciated.
                    Y 1 Reply Last reply
                    • Y
                      yawns Moderator @kerijn
                      @kerijn `
                      npm list
                      look for electron to find out your version number
                      cd modules/MMM-PIR-Sensor
                      npm rebuild --runtime=electron --target=XXX --disturl=https://atom.io/download/atom-shell --build-from-source
                      Replace XXX with the version you found in step 1
                      F 1 Reply Last reply
                      • F
                        fox @yawns
                        @yawns said in MMM-PIR-Sensor Install failing:
                        Thank you @yawns .
                        I did your code lines and got:
                        npm ERR! peer dep missing: grunt@~0.4.0, required by grunt-yamllint@0.2.0
                        and
                        npm WARN prefer global node-gyp@3.5.0 should be installed with
                        Then i repeated
                        npm install
                        in pi@magicpi:~/MagicMirror/modules/MMM-PIR-Sensor $
                        and got againthis errors:
                        An unhandled error occurred inside electron-rebuild
                        Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                        Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                            at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                            at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                            at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                            at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                            at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/util.js:16:23)
                            at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:97:49)
                            at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:201:15
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                            at Module.runMain (module.js:604:10)
                            at run (bootstrap_node.js:394:7)
                            at startup (bootstrap_node.js:149:9)
                        npm ERR! npm  v4.1.1
                        npm ERR! Exit status 255
                        npm ERR!
                        Issues With MMM-WatchDog known?
                        https://forum.magicmirror.builders/post/29827
                        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                          shashank @nemesismega
                          @nemesismega i am getting this error while install the PIR module, all other modules working fine
                          0_1485096342421_upload-2c90fe4e-9f32-4034-87e5-22eb559a82f2
                          • F
                            fox @shashank
                            @shashank said in PIR-Sensor - put your mirror to sleep if not used:
                            i have nearly a similar problem: https://forum.magicmirror.builders/post/12024
                            • K
                              kerijn
                              @yawns Thank you very much for your help but infortunately this didn’t work. I now cannot start Magicmirror anymore even without the MMM-PIR-Sensor module… See error below. I also got the same warning as @fox with missing grunt@…
                              pi@MyPi:~/MagicMirror $ npm start
                              > magicmirror@2.1.0 start /home/pi/MagicMirror
                              > electron js/electron.js
                              npm ERR! Linux 4.4.43-v7+
                              npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                              npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
                              npm ERR! If you do, this is most likely a problem with the magicmirror package,
                              npm ERR!     electron js/electron.js
                              npm ERR!     npm bugs magicmirror
                              npm ERR!     npm owner ls magicmirror
                              npm ERR!     /home/pi/MagicMirror/npm-debug.log
                              J 1 Reply Last reply
                              • K
                                kerijn
                                I now did a full new installation of MagicMirror with the defauls config.js and got the same error.
                                npm ERR!
                                • F
                                  fox
                                  @kerijn perhaps @paviro can help us here. It seems to be a general problem.
                                    Jopyth Moderator @kerijn
                                    @kerijn @fox I think I fixed this issue before, it comes from the changes the Magic Mirror version 2.1.0 introduced. I am not sure, but I think the changes neccessary are almost as simple as here. Will have to test this at home though. Maybe there was something else needed.
                                    F K 2 Replies Last reply
                                    Reply Quote 2
                                    • F
                                      fox @Jopyth
                                      @Jopyth said in MMM-PIR-Sensor Install failing:
                                      Thank you. That fixes the problem for me ! :)
                                      • K
                                        kerijn @Jopyth
                                        @Jopyth This worked for me for the installation as well. Thank you! However, the sensor does not seem to do anything. How can I check whether the sensor is working properly?
                                        M 1 Reply Last reply
                                          Makradon @kerijn
                                          @kerijn said in [MMM-PIR-Sensor] Install failing:
                                            Jopyth Moderator @Makradon
                                            @Makradon @kerijn I found this. I think you could save this as test.py somewhere on your Pi and see if the output changes when you move and don’t move (set the pin number in the second line) after your start it with python test.py:
                                            import RPi.GPIO as GPIO
                                            pin = 11
                                            GPIO.setwarnings(False)
                                            GPIO.setmode(GPIO.BOARD)
                                            GPIO.setup(pin, GPIO.IN)         #Read output from PIR motion sensor
                                            while True:
                                                   i=GPIO.input(pin)
                                                   if i==0:                 #When output from motion sensor is LOW
                                                         print "No intruders",i
                                                         time.sleep(0.1)
                                                   elif i==1:               #When output from motion sensor is HIGH
                                                         print "Intruder detected",i
                                                         time.sleep(0.1)
                                            T 1 Reply Last reply
                                            • 1 / 4
