    MMM-Gas
    56 Posts 13 Posters 45.0k Views 12 Watching
      sdetweil @JohnGalt
      @JohnGalt it cannot do it natively
      J 1 Reply Last reply
        JohnGalt @sdetweil
        @sdetweil Sam - thanks for the confirmation. I posted the question before installing it, and went ahead and installed just to see how it might look.
        It gave me some warnings on install regarding deprecated dependencies, then displayed… nothing. I tried to manually pull the gas price data using the url in code in the github repository but that just comes back as a 404, and the site map doesn’t give any hint that the site serves up this data.
        The odd part is I don’t see any error specific to this module in the pm2 logs [see below]. At this point I have removed the module folder and config.js code and life goes on. If there happens to be a way to get it to work, great - but let’s not spend a lot of time on it.
        Partial output from pm2 logs:
        PM2            | Change detected on path config/config.js for app MagicMirror - restarting
        PM2            | Stopping app:MagicMirror id:0
        0|MagicMirror  | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
        PM2            | pid=28762 msg=failed to kill - retrying in 100ms
        PM2            | App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2            | pid=28762 msg=process killed
        PM2            | App [MagicMirror:0] starting in -fork mode-
        PM2            | App [MagicMirror:0] online
        0|MagicMirror  | > magicmirror@2.28.0 start
        0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        0|MagicMirror  | [2024-09-29 17:35:29.657] [LOG]   Starting MagicMirror: v2.28.0
        0|MagicMirror  | [2024-09-29 17:35:29.716] [LOG]   Loading config ...
        0|MagicMirror  | [2024-09-29 17:35:29.720] [LOG]   config template file not exists, no envsubst
        0|MagicMirror  | [2024-09-29 17:35:29.726] [LOG]   Loading module helpers ...
        0|MagicMirror  | [2024-09-29 17:35:29.727] [LOG]   No helper found for module: alert.
        0|MagicMirror  | [2024-09-29 17:35:29.737] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [2024-09-29 17:35:29.739] [LOG]   Module helper loaded: MMM-WeatherAlerts
        0|MagicMirror  | [2024-09-29 17:35:29.743] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [2024-09-29 17:35:29.743] [LOG]   Module helper loaded: MMM-WeatherAlerts2
        0|MagicMirror  | [2024-09-29 17:35:29.752] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [2024-09-29 17:35:29.752] [LOG]   Module helper loaded: updatenotification
        0|MagicMirror  | [2024-09-29 17:35:29.754] [LOG]   No helper found for module: clock.
        0|MagicMirror  | [2024-09-29 17:35:29.755] [LOG]   No helper found for module: MMM-Worldclock.
        0|MagicMirror  | [2024-09-29 17:35:29.924] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [2024-09-29 17:35:29.925] [LOG]   Module helper loaded: calendar
        0|MagicMirror  | [2024-09-29 17:35:29.926] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [2024-09-29 17:35:29.927] [LOG]   Module helper loaded: calendar
        0|MagicMirror  | [2024-09-29 17:35:29.996] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [2024-09-29 17:35:29.996] [LOG]   Module helper loaded: MMM-Tools
        0|MagicMirror  | [2024-09-29 17:35:29.997] [LOG]   No helper found for module: MMM-Multimonth.
        0|MagicMirror  | [2024-09-29 17:35:30.017] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [2024-09-29 17:35:30.017] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
        0|MagicMirror  | [2024-09-29 17:35:30.280] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [2024-09-29 17:35:30.281] [LOG]   Module helper loaded: MMM-Pollen
        0|MagicMirror  | [2024-09-29 17:35:30.283] [LOG]   No helper found for module: weather.
        0|MagicMirror  | [2024-09-29 17:35:30.391] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [2024-09-29 17:35:30.392] [LOG]   Module helper loaded: newsfeed
        0|MagicMirror  | [2024-09-29 17:35:30.398] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [2024-09-29 17:35:30.399] [LOG]   Module helper loaded: MMM-DynamicWeather
        0|MagicMirror  | [2024-09-29 17:35:30.401] [LOG]   All module helpers loaded.
        0|MagicMirror  | [2024-09-29 17:35:30.415] [LOG]   Starting server on port 8080 ...
        0|MagicMirror  | [2024-09-29 17:35:31.199] [LOG]   Server started ...
        0|MagicMirror  | [2024-09-29 17:35:31.214] [LOG]   Connecting socket for: MMM-WeatherAlerts
        0|MagicMirror  | [2024-09-29 17:35:31.217] [LOG]   Starting module helper: MMM-WeatherAlerts
        0|MagicMirror  | [2024-09-29 17:35:31.219] [LOG]   Connecting socket for: MMM-WeatherAlerts2
        0|MagicMirror  | [2024-09-29 17:35:31.220] [LOG]   Starting module helper: MMM-WeatherAlerts2
        0|MagicMirror  | [2024-09-29 17:35:31.222] [LOG]   Connecting socket for: updatenotification
        0|MagicMirror  | [2024-09-29 17:35:31.224] [LOG]   Starting module helper: updatenotification
        0|MagicMirror  | [2024-09-29 17:35:31.226] [LOG]   Connecting socket for: calendar
        0|MagicMirror  | [2024-09-29 17:35:31.228] [LOG]   Starting node helper for: calendar
        0|MagicMirror  | [2024-09-29 17:35:31.230] [LOG]   Connecting socket for: calendar
        0|MagicMirror  | [2024-09-29 17:35:31.231] [LOG]   Starting node helper for: calendar
        0|MagicMirror  | [2024-09-29 17:35:31.246] [LOG]   Connecting socket for: MMM-Tools
        0|MagicMirror  | [2024-09-29 17:35:31.250] [LOG]   [Tools] MMM-Tools Version: 2.1.7
        0|MagicMirror  | [2024-09-29 17:35:31.252] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
        0|MagicMirror  | [2024-09-29 17:35:31.254] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
        0|MagicMirror  | [2024-09-29 17:35:31.255] [LOG]   Connecting socket for: MMM-Pollen
        0|MagicMirror  | [2024-09-29 17:35:31.273] [LOG]   MMM-Pollen helper started ...
        0|MagicMirror  | [2024-09-29 17:35:31.275] [LOG]   Connecting socket for: newsfeed
        0|MagicMirror  | [2024-09-29 17:35:31.277] [LOG]   Starting node helper for: newsfeed
        0|MagicMirror  | [2024-09-29 17:35:31.279] [LOG]   Connecting socket for: MMM-DynamicWeather
        0|MagicMirror  | [2024-09-29 17:35:31.281] [LOG]   Sockets connected & modules started ...
        0|MagicMirror  | [2024-09-29 17:35:32.168] [LOG]   Launching application.
        0|MagicMirror  | [2843:0929/173533.164645:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.166603:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.167945:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.169873:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.171528:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.172716:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.174129:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.175313:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.176763:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.178279:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.180011:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.181255:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.182716:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.183904:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.185245:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.187096:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.188547:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.190111:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.191549:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.193083:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.194679:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.196231:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.197720:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.199227:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.200454:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.201574:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.202846:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.204087:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.207329:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.208602:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.209921:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.211042:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.212311:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.213479:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.215374:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.216465:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.217793:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.219444:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.221185:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.222712:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.224067:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
        0|MagicMirror  | [2843:0929/173533.225628:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
        0|MagicMirror  | [2024-09-29 17:35:36.587] [INFO]  System information:
        0|MagicMirror  | ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; raspberry: [object Object]; virtual: false
        0|MagicMirror  | ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
        0|MagicMirror  | ### VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.1
        0|MagicMirror  | ### OTHER:    timeZone: America/Los_Angeles; ELECTRON_ENABLE_GPU: undefined
          sdetweil @JohnGalt
          @JohnGalt i dont see mmm-gas in the loaded modules list
          J 2 Replies Last reply
            JohnGalt @sdetweil
            @sdetweil – True. I’m not sure why that is. I will try reinstalling it.
              JohnGalt @sdetweil
              @cowboysdude
              So i reinstalled this module, and it still does not display on the Magic Mirror. [
              It now it does appear to load the module:
              0|MagicMirror  | [2024-09-30 16:19:22.987] [LOG]   Connecting socket for: MMM-Gas
              0|MagicMirror  | [2024-09-30 16:19:22.988] [LOG]   Starting module: MMM-Gas
              And check the status of the module along with others:
              0|MagicMirror  | [2024-09-30 16:19:32.585] [INFO]  Newsfeed-Fetcher: Broadcasting 38 items.
              0|MagicMirror  | [2024-09-30 16:19:32.936] [INFO]  Checking git for module: MMM-Pollen
              0|MagicMirror  | [2024-09-30 16:19:33.379] [INFO]  Checking git for module: MMM-Gas
              0|MagicMirror  | [2024-09-30 16:19:33.570] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
              0|MagicMirror  | [2024-09-30 16:19:33.724] [INFO]  Checking git for module: MMM-DynamicWeather
              0|MagicMirror  | [2024-09-30 16:19:34.030] [INFO]  Checking git for module: MagicMirror
              But there is still something missing.
              Could it has something to do with the dependency issues?
              pi@mirror1:~/MagicMirror/modules $ git clone https://github.com/cowboysdude/MMM-Gas
              Cloning into 'MMM-Gas'...
              remote: Enumerating objects: 135, done.
              remote: Counting objects: 100% (6/6), done.
              remote: Compressing objects: 100% (6/6), done.
              remote: Total 135 (delta 2), reused 0 (delta 0), pack-reused 129 (from 1)
              Receiving objects: 100% (135/135), 89.19 KiB | 553.00 KiB/s, done.
              Resolving deltas: 100% (67/67), done.
              pi@mirror1:~/MagicMirror/modules $ cd MMM-Gas
              pi@mirror1:~/MagicMirror/modules/MMM-Gas $ NPM INSTALL
              -bash: NPM: command not found
              pi@mirror1:~/MagicMirror/modules/MMM-Gas $ npm install
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              added 67 packages, and audited 68 packages in 12s
              17 packages are looking for funding
                run `npm fund` for details
              2 moderate severity vulnerabilities
              Some issues need review, and may require choosing
              a different dependency.
              Run `npm audit` for details.
              D 1 Reply Last reply
                DDE12 @JohnGalt
                @JohnGalt
                Have you made any progress figuring this out? I am having the same problem. The module loads but doesn’t show that it is getting any data.
                  JohnGalt @DDE12
                  @DDE12 – No, still nothing displayed from this module.
                  M 1 Reply Last reply
                    MarcLandis Module Developer @JohnGalt
                    @JohnGalt @sdetweil it seems that the website doesn’t provide the data anymore. This is an URL that is build in the module:
                    https://www.autoblog.com/14904-gas-prices/
                    it results in a 404:
                    J D 2 Replies Last reply
                      JohnGalt @MarcLandis
                      @MarcLandis yes, that’s what I found too when I tried accessing the data directly. I was confused though that there is/was no error in the pm2 logs…
                        sdetweil @JohnGalt
                        @JohnGalt most modules do not handle or report errors
                          JohnGalt @sdetweil
                          @sdetweil – Huh, good to know. Thanks.
                            DDE12 @MarcLandis
                            @MarcLandis
                            That is unfortunate. I looked around a bit to see if there is another option but did not find anything free. (:
                            plainbrokeP 1 Reply Last reply
                            • plainbrokeP
                              plainbroke @DDE12
                              @DDE12
                              You can try MMM-Fuel you have to use gasbuddy instead of autoblog.
                              It works for me at least for now…
                              • 3 / 3
