MMM-Gas
@sdetweil Sam - thanks for the confirmation. I posted the question before installing it, and went ahead and installed just to see how it might look.
It gave me some warnings on install regarding deprecated dependencies, then displayed… nothing. I tried to manually pull the gas price data using the url in code in the github repository but that just comes back as a 404, and the site map doesn’t give any hint that the site serves up this data.
The odd part is I don’t see any error specific to this module in the pm2 logs [see below]. At this point I have removed the module folder and config.js code and life goes on. If there happens to be a way to get it to work, great - but let’s not spend a lot of time on it.
Partial output from pm2 logs:
PM2 | Change detected on path config/config.js for app MagicMirror - restarting PM2 | Stopping app:MagicMirror id:0 0|MagicMirror | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT PM2 | pid=28762 msg=failed to kill - retrying in 100ms PM2 | App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | pid=28762 msg=process killed PM2 | App [MagicMirror:0] starting in -fork mode- PM2 | App [MagicMirror:0] online 0|MagicMirror | > magicmirror@2.28.0 start 0|MagicMirror | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMirror | [2024-09-29 17:35:29.657] [LOG] Starting MagicMirror: v2.28.0 0|MagicMirror | [2024-09-29 17:35:29.716] [LOG] Loading config ... 0|MagicMirror | [2024-09-29 17:35:29.720] [LOG] config template file not exists, no envsubst 0|MagicMirror | [2024-09-29 17:35:29.726] [LOG] Loading module helpers ... 0|MagicMirror | [2024-09-29 17:35:29.727] [LOG] No helper found for module: alert. 0|MagicMirror | [2024-09-29 17:35:29.737] [LOG] Initializing new module helper ... 0|MagicMirror | [2024-09-29 17:35:29.739] [LOG] Module helper loaded: MMM-WeatherAlerts 0|MagicMirror | [2024-09-29 17:35:29.743] [LOG] Initializing new module helper ... 0|MagicMirror | [2024-09-29 17:35:29.743] [LOG] Module helper loaded: MMM-WeatherAlerts2 0|MagicMirror | [2024-09-29 17:35:29.752] [LOG] Initializing new module helper ... 0|MagicMirror | [2024-09-29 17:35:29.752] [LOG] Module helper loaded: updatenotification 0|MagicMirror | [2024-09-29 17:35:29.754] [LOG] No helper found for module: clock. 0|MagicMirror | [2024-09-29 17:35:29.755] [LOG] No helper found for module: MMM-Worldclock. 0|MagicMirror | [2024-09-29 17:35:29.924] [LOG] Initializing new module helper ... 0|MagicMirror | [2024-09-29 17:35:29.925] [LOG] Module helper loaded: calendar 0|MagicMirror | [2024-09-29 17:35:29.926] [LOG] Initializing new module helper ... 0|MagicMirror | [2024-09-29 17:35:29.927] [LOG] Module helper loaded: calendar 0|MagicMirror | [2024-09-29 17:35:29.996] [LOG] Initializing new module helper ... 0|MagicMirror | [2024-09-29 17:35:29.996] [LOG] Module helper loaded: MMM-Tools 0|MagicMirror | [2024-09-29 17:35:29.997] [LOG] No helper found for module: MMM-Multimonth. 0|MagicMirror | [2024-09-29 17:35:30.017] [LOG] Initializing new module helper ... 0|MagicMirror | [2024-09-29 17:35:30.017] [LOG] Module helper loaded: MMM-OpenWeatherMapForecast 0|MagicMirror | [2024-09-29 17:35:30.280] [LOG] Initializing new module helper ... 0|MagicMirror | [2024-09-29 17:35:30.281] [LOG] Module helper loaded: MMM-Pollen 0|MagicMirror | [2024-09-29 17:35:30.283] [LOG] No helper found for module: weather. 0|MagicMirror | [2024-09-29 17:35:30.391] [LOG] Initializing new module helper ... 0|MagicMirror | [2024-09-29 17:35:30.392] [LOG] Module helper loaded: newsfeed 0|MagicMirror | [2024-09-29 17:35:30.398] [LOG] Initializing new module helper ... 0|MagicMirror | [2024-09-29 17:35:30.399] [LOG] Module helper loaded: MMM-DynamicWeather 0|MagicMirror | [2024-09-29 17:35:30.401] [LOG] All module helpers loaded. 0|MagicMirror | [2024-09-29 17:35:30.415] [LOG] Starting server on port 8080 ... 0|MagicMirror | [2024-09-29 17:35:31.199] [LOG] Server started ... 0|MagicMirror | [2024-09-29 17:35:31.214] [LOG] Connecting socket for: MMM-WeatherAlerts 0|MagicMirror | [2024-09-29 17:35:31.217] [LOG] Starting module helper: MMM-WeatherAlerts 0|MagicMirror | [2024-09-29 17:35:31.219] [LOG] Connecting socket for: MMM-WeatherAlerts2 0|MagicMirror | [2024-09-29 17:35:31.220] [LOG] Starting module helper: MMM-WeatherAlerts2 0|MagicMirror | [2024-09-29 17:35:31.222] [LOG] Connecting socket for: updatenotification 0|MagicMirror | [2024-09-29 17:35:31.224] [LOG] Starting module helper: updatenotification 0|MagicMirror | [2024-09-29 17:35:31.226] [LOG] Connecting socket for: calendar 0|MagicMirror | [2024-09-29 17:35:31.228] [LOG] Starting node helper for: calendar 0|MagicMirror | [2024-09-29 17:35:31.230] [LOG] Connecting socket for: calendar 0|MagicMirror | [2024-09-29 17:35:31.231] [LOG] Starting node helper for: calendar 0|MagicMirror | [2024-09-29 17:35:31.246] [LOG] Connecting socket for: MMM-Tools 0|MagicMirror | [2024-09-29 17:35:31.250] [LOG] [Tools] MMM-Tools Version: 2.1.7 0|MagicMirror | [2024-09-29 17:35:31.252] [LOG] Connecting socket for: MMM-OpenWeatherMapForecast 0|MagicMirror | [2024-09-29 17:35:31.254] [LOG] Starting node_helper for MMM-OpenWeatherMapForecast 0|MagicMirror | [2024-09-29 17:35:31.255] [LOG] Connecting socket for: MMM-Pollen 0|MagicMirror | [2024-09-29 17:35:31.273] [LOG] MMM-Pollen helper started ... 0|MagicMirror | [2024-09-29 17:35:31.275] [LOG] Connecting socket for: newsfeed 0|MagicMirror | [2024-09-29 17:35:31.277] [LOG] Starting node helper for: newsfeed 0|MagicMirror | [2024-09-29 17:35:31.279] [LOG] Connecting socket for: MMM-DynamicWeather 0|MagicMirror | [2024-09-29 17:35:31.281] [LOG] Sockets connected & modules started ... 0|MagicMirror | [2024-09-29 17:35:32.168] [LOG] Launching application. 0|MagicMirror | [2843:0929/173533.164645:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.166603:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.167945:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.169873:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.171528:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.172716:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.174129:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.175313:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.176763:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.178279:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.180011:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.181255:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.182716:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.183904:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.185245:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.187096:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.188547:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.190111:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.191549:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.193083:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.194679:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.196231:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.197720:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.199227:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.200454:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.201574:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.202846:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.204087:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.207329:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.208602:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.209921:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.211042:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.212311:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.213479:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.215374:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.216465:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.217793:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.219444:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.221185:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.222712:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.224067:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2) 0|MagicMirror | [2843:0929/173533.225628:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2) 0|MagicMirror | [2024-09-29 17:35:36.587] [INFO] System information: 0|MagicMirror | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.1; raspberry: [object Object]; virtual: false 0|MagicMirror | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+ 0|MagicMirror | ### VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.1 0|MagicMirror | ### OTHER: timeZone: America/Los_Angeles; ELECTRON_ENABLE_GPU: undefined -
@JohnGalt i dont see mmm-gas in the loaded modules list
@sdetweil – True. I’m not sure why that is. I will try reinstalling it.
@cowboysdude
So i reinstalled this module, and it still does not display on the Magic Mirror. [It now it does appear to load the module:
0|MagicMirror | [2024-09-30 16:19:22.987] [LOG] Connecting socket for: MMM-Gas 0|MagicMirror | [2024-09-30 16:19:22.988] [LOG] Starting module: MMM-GasAnd check the status of the module along with others:
0|MagicMirror | [2024-09-30 16:19:32.585] [INFO] Newsfeed-Fetcher: Broadcasting 38 items. 0|MagicMirror | [2024-09-30 16:19:32.936] [INFO] Checking git for module: MMM-Pollen 0|MagicMirror | [2024-09-30 16:19:33.379] [INFO] Checking git for module: MMM-Gas 0|MagicMirror | [2024-09-30 16:19:33.570] [INFO] Newsfeed-Fetcher: Broadcasting 30 items. 0|MagicMirror | [2024-09-30 16:19:33.724] [INFO] Checking git for module: MMM-DynamicWeather 0|MagicMirror | [2024-09-30 16:19:34.030] [INFO] Checking git for module: MagicMirrorBut there is still something missing.
Could it has something to do with the dependency issues?
pi@mirror1:~/MagicMirror/modules $ git clone https://github.com/cowboysdude/MMM-Gas Cloning into 'MMM-Gas'... remote: Enumerating objects: 135, done. remote: Counting objects: 100% (6/6), done. remote: Compressing objects: 100% (6/6), done. remote: Total 135 (delta 2), reused 0 (delta 0), pack-reused 129 (from 1) Receiving objects: 100% (135/135), 89.19 KiB | 553.00 KiB/s, done. Resolving deltas: 100% (67/67), done. pi@mirror1:~/MagicMirror/modules $ cd MMM-Gas pi@mirror1:~/MagicMirror/modules/MMM-Gas $ NPM INSTALL -bash: NPM: command not found pi@mirror1:~/MagicMirror/modules/MMM-Gas $ npm install npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 added 67 packages, and audited 68 packages in 12s 17 packages are looking for funding run `npm fund` for details 2 moderate severity vulnerabilities Some issues need review, and may require choosing a different dependency. Run `npm audit` for details. -
@JohnGalt
Have you made any progress figuring this out? I am having the same problem. The module loads but doesn’t show that it is getting any data. -
@DDE12 – No, still nothing displayed from this module.
@JohnGalt @sdetweil it seems that the website doesn’t provide the data anymore. This is an URL that is build in the module:
https://www.autoblog.com/14904-gas-prices/
it results in a 404:
@MarcLandis yes, that’s what I found too when I tried accessing the data directly. I was confused though that there is/was no error in the pm2 logs…
@JohnGalt most modules do not handle or report errors
@sdetweil – Huh, good to know. Thanks.
@MarcLandis
That is unfortunate. I looked around a bit to see if there is another option but did not find anything free. (: -
You can try MMM-Fuel you have to use gasbuddy instead of autoblog.
It works for me at least for now…
