    MMM-Gas
    56 Posts 13 Posters 43.8k Views 12 Watching
      sdetweil @JohnGalt
      @JohnGalt i dont see mmm-gas in the loaded modules list
        JohnGalt @sdetweil
        @sdetweil – True. I’m not sure why that is. I will try reinstalling it.
          JohnGalt @sdetweil
          @cowboysdude
          So i reinstalled this module, and it still does not display on the Magic Mirror. [
          It now it does appear to load the module:
          0|MagicMirror  | [2024-09-30 16:19:22.987] [LOG]   Connecting socket for: MMM-Gas
          0|MagicMirror  | [2024-09-30 16:19:22.988] [LOG]   Starting module: MMM-Gas
          And check the status of the module along with others:
          0|MagicMirror  | [2024-09-30 16:19:32.585] [INFO]  Newsfeed-Fetcher: Broadcasting 38 items.
          0|MagicMirror  | [2024-09-30 16:19:32.936] [INFO]  Checking git for module: MMM-Pollen
          0|MagicMirror  | [2024-09-30 16:19:33.379] [INFO]  Checking git for module: MMM-Gas
          0|MagicMirror  | [2024-09-30 16:19:33.570] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
          0|MagicMirror  | [2024-09-30 16:19:33.724] [INFO]  Checking git for module: MMM-DynamicWeather
          0|MagicMirror  | [2024-09-30 16:19:34.030] [INFO]  Checking git for module: MagicMirror
          But there is still something missing.
          Could it has something to do with the dependency issues?
          pi@mirror1:~/MagicMirror/modules $ git clone https://github.com/cowboysdude/MMM-Gas
          Cloning into 'MMM-Gas'...
          remote: Enumerating objects: 135, done.
          remote: Counting objects: 100% (6/6), done.
          remote: Compressing objects: 100% (6/6), done.
          remote: Total 135 (delta 2), reused 0 (delta 0), pack-reused 129 (from 1)
          Receiving objects: 100% (135/135), 89.19 KiB | 553.00 KiB/s, done.
          Resolving deltas: 100% (67/67), done.
          pi@mirror1:~/MagicMirror/modules $ cd MMM-Gas
          pi@mirror1:~/MagicMirror/modules/MMM-Gas $ NPM INSTALL
          -bash: NPM: command not found
          pi@mirror1:~/MagicMirror/modules/MMM-Gas $ npm install
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          added 67 packages, and audited 68 packages in 12s
          17 packages are looking for funding
            run `npm fund` for details
          2 moderate severity vulnerabilities
          Some issues need review, and may require choosing
          a different dependency.
          Run `npm audit` for details.
            DDE12 @JohnGalt
            @JohnGalt
            Have you made any progress figuring this out? I am having the same problem. The module loads but doesn’t show that it is getting any data.
              JohnGalt @DDE12
              @DDE12 – No, still nothing displayed from this module.
                MarcLandis Module Developer @JohnGalt
                @JohnGalt @sdetweil it seems that the website doesn’t provide the data anymore. This is an URL that is build in the module:
                https://www.autoblog.com/14904-gas-prices/
                it results in a 404:
                J D 2 Replies Last reply Reply Quote 0
                  JohnGalt @MarcLandis
                  @MarcLandis yes, that’s what I found too when I tried accessing the data directly. I was confused though that there is/was no error in the pm2 logs…
                    sdetweil @JohnGalt
                    @JohnGalt most modules do not handle or report errors
                      JohnGalt @sdetweil
                      @sdetweil – Huh, good to know. Thanks.
                        DDE12 @MarcLandis
                        @MarcLandis
                        That is unfortunate. I looked around a bit to see if there is another option but did not find anything free. (:
                        • plainbrokeP Offline
                          plainbroke @DDE12
                          @DDE12
                          You can try MMM-Fuel you have to use gasbuddy instead of autoblog.
                          It works for me at least for now…
                          • 3 / 3
