    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 257.5k Views 20 Watching
    • MichMichM
      MichMich
      Could you try it with node serveronly ?
        paviro @joerod
        @joerod also do npm install on the mm folder or install the whole thing from scratch :)
        – The Doctor
          DirkS @paviro
          @paviro as a feedback: i used the latest MMM branch and yours and it is working fine with my PIR sensor on a rpi2. I didn’t had to downgrade anything to node 5 (and i also don’t know what it is :D ) Thanks for your work. It is so great that the mirror is starting if a presence is detected!!
          P 1 Reply Last reply
            paviro @DirkS
            @DirkS glad to hear! :)
            – The Doctor
              MechMatt
              Hey Everyone!
              I am trying to use this module to turn off/on a tv and im having a bit of trouble on the physical end of things… I got the module working perfectly (tested it with PIR and hdmi on/off). Now I am trying to use a relay with the PIR sensor to have the TV screen itself turn on and off. I was planning on wiring this to the TV power button (so it is essentially the same as pressing the on/off button).
              I got the relay working… and I was about to take apart my tv when i thought…will even work for the on/off button? When it senses movement it will send the signal and then … turn off the tv I guess. As soon as the movement is undetected it stops sending the signal (or really pulse in this case)… just stopping wouldn’t turn the tv back on either. I guess it needs to send a pulse when it stops detecting movement, and then another one when it does again. Am I thinking about this wrong? Should I wire it to something else? Thanks in advance
              M 1 Reply Last reply
                MechMatt @MechMatt
                @MechMatt On second thought, im having trouble with the relay as well… could you post a wiring diagram for the pi, relay, and tv? I’m not the best at electronics
                  paviro
                  To be honest the relay thing does not work that we’ll yet, still have to figure out some stuff related to how the Pi reacts when a monitor gets turned on after the boot process and not before.
                  As to your TV on/off button thing. The module simply puts s 3.3 volts on the configured Pin if the relay should be on and sets it back to 0 volts if it should be off. You can also configure it the other way around. Since I do not now how your TV button is wired I have no idea wheather it would work with this module without modifying some parts.
                  – The Doctor
                    joerod
                    I’ve been using a python script to achieve this functionality, its worked well for me so far. I make sure the script is run at start up.
                    https://github.com/joerod/python/blob/master/raspberry_pi/motion.py
                      paviro
                      That’s exactly what this module does :)
                      – The Doctor
                      • T
                        trividar
                        Dear all,
                        I tried to implement the PIR-module. After I launch the MagicMirror i get always an error. What do I wrong?
                        That is what I have done:
                        1. Navigate into your MagicMirror’s modules folder and execute git clone https://github.com/paviro/MMM-PIR-Sensor.git. A new folder will appear navigate into it.
                        2. Execute npm install to install the node dependencies.
                        3. Add your user (pi?) to the gpio group by executing sudo useradd -g pi gpio.
                          Reboot your Pi.
                        And I wrote this in config.js:
                        		module: 'MMM-PIR-Sensor',
                        		               sensorPIN: '22',
                        			       powerSaving: true
                        After I start my mirror with npm start i get this error (from npm-debug.log):
                        1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
                        2 info using npm@3.8.6
                        3 info using node@v5.11.0
                        5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
                        6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
                        7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
                        8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
                        9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/local/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                        10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
                        11 silly lifecycle magicmirror@2.0.0~start: Args: [ '-c', 'electron js/electron.js' ]
                        12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1  signal: null
                        13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
                        14 verbose stack Error: magicmirror@2.0.0 start: `electron js/electron.js`
                        14 verbose stack Exit status 1
                        14 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:239:16)
                        14 verbose stack     at emitTwo (events.js:100:13)
                        14 verbose stack     at EventEmitter.emit (events.js:185:7)
                        14 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
                        14 verbose stack     at ChildProcess.emit (events.js:185:7)
                        14 verbose stack     at maybeClose (internal/child_process.js:850:16)
                        14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
                        15 verbose pkgid magicmirror@2.0.0
                        16 verbose cwd /home/pi/MagicMirror
                        17 error Linux 4.1.17-v7+
                        18 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
                        19 error node v5.11.0
                        20 error npm  v3.8.6
                        21 error code ELIFECYCLE
                        22 error magicmirror@2.0.0 start: `electron js/electron.js`
                        22 error Exit status 1
                        23 error Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
                        23 error Make sure you have the latest version of node.js and npm installed.
                        23 error If you do, this is most likely a problem with the magicmirror package,
                        23 error not with npm itself.
                        23 error Tell the author that this fails on your system:
                        23 error     electron js/electron.js
                        23 error You can get information on how to open an issue for this project with:
                        23 error     npm bugs magicmirror
                        23 error Or if that isn't available, you can get their info via:
                        23 error     npm owner ls magicmirror
                        23 error There is likely additional logging output above.
                        24 verbose exit [ 1, true ]
                        K 1 Reply Last reply
                        • K
                          Knox @trividar
                          @trividar from the earlier comments make sure you set your sensorPIN to an integer. (no quotes)
                          config.js:
                          		               sensorPIN: 22,
                          			       powerSaving: true
                          • T
                            trividar
                            @Knox thank you for your help. I try it, but I get the same error… I’m a noob and I realy don’t know what i do wrong…;o( Here is a foto of my error…
                            Have someone an idea what i do wrong?
                            THX a lot…
                            • MichMichM
                              MichMich
                              As you can see it says it misses the module “wiring-pi” in the error part.
                              Try running npm install wiring-pi
                              Let me know if that solves the issue.
                              • cowboysdudeC
                                Even rolling back to node js V5 still results in a white screen. I realize people are saying that it’s a config issue but I’ve tried every combination there is and no go. I read the instructions and followed every letter and still no go.
                                I was using the monitor_on.sh and monitor_off.sh files from a different one but I cannot seem to get the pir.py file to work…
                                The problem with being new to all of this is that there is so much mis-information out there that you can literally spend hours doing the wrong things…
                                I was going to use the @reboot method to run the pir.py but have no way of knowing if it’s even loading because either I have a bad sensor or it’s just not working… it does show up in the crontab but not working…
                                On another note honestly I try not getting frustrated because this is fun for me to try and figure out…
                                BUT suggestions on how to get the pir.py to run on boot up?
                                Huge Thanks for ALL the hard work from everyone!! PS I’ve attached a copy of the pir.py and all files for anyone to take a look at and/or use…
                                This is the last thing I need to do to make this all work correctly and I can hang it :)0_1465667815133_PIR.zip
                                Thanks again!!!
                                • cowboysdudeC
                                  cowboysdude Module Developer @cowboysdude
                                  @cowboysdude OHHHHHHHHHH and how the heck do you really make the screen blank stop? I’ve tried EVERY method I could find online but the screen still blanks… :(
                                  D 1 Reply Last reply
                                    desq @cowboysdude
                                    @cowboysdude
                                    I´m getting the same “blank” - white screen as soon as i try to use this module.
                                    @cowboysdude do you have a solution yet?
                                    • cowboysdudeC
                                      cowboysdude Module Developer @desq
                                      @desq No I don’t. Sorry I went in another direction… I have a pir.py and monitor_on, monitor_off.py… it works! If you’d like the setup I’d be happy to share…
                                      You just start the pir.py using crontab -e then enter @reboot [point to where your pir.py is]…
                                      That’s it… simple and it works!
                                        desq @cowboysdude
                                        @cowboysdude
                                        I got it. I installed the latest node. (6.2.1) Pull MMM-PIR from the git Repository und did all the steps Paviro explains on the module page.
                                        And suddenly no more the white screen and the “USER_PRESENCE” notification is send every 5-6 sec.
                                        @paviro
                                        could implement a parameter to set the duration for a monitor shutdown as no USER_PRESENCE is detected?
                                          Jaghova
                                          A stupid question, where “USER_PRESENCE” notification must appear? in ‘PM2 logs mm’ ??
                                          If so, It doesn’t appear in my logs, which means I don’t have the module correctly installed right?
                                          But if i check on ‘GPIO readall’ I can see how the IN is activated and also the OUT relay when it detects presence
                                          • cowboysdudeC
                                            @desq I’m not using the mmm-PIR I’m using something else… BUT I do know from reading that it wasn’t working with node V6… you had to roll back to V5.
                                            I still had trouble with v5 so I went with something else…
                                            • 5 / 7
