    MMM-Globe
    119 Posts 39 Posters 239.7k Views 40 Watching
    • binderthB
      binderth
      so great coming home from skiing and everything is already fixed and commited! Thanks, guys!
      looks awesome!
        Burner911
        This is awesome! Any chance of a view with North America centric? @LukeCodewalker
        schlachtkreuzer6S 1 Reply Last reply
        • schlachtkreuzer6S
          schlachtkreuzer6 @Burner911
          @Burner911 if you find some image source :D
          • lolobyteL
            lolobyte
            Here are some needful sources
            http://earthdirectory.net/gsat
            http://goes.gsfc.nasa.gov/
            SvenSommerS 1 Reply Last reply
            • SvenSommerS
              SvenSommer @lolobyte
              @lolobyte
              Thank you for the links.
              For central america I found the following source the most usefull. Unfortunately it’s only available in high resulution.
              http://goes.gsfc.nasa.gov/goescolor/goeseast/overview2/color_lrg/latestfull.jpg
              alt text
              Has anybody found more usefull sources by now?
                Burner911
                @SvenSommer That is the exact image I found as well. Any chance we could make this work @LukeCodewalker?
                LukeCodewalkerL SvenSommerS 2 Replies Last reply
                • in_a_daysI
                  in_a_days
                  Hopefully we’ll have a new feed from GOES-16 soon as well!
                  http://gizmodo.com/the-most-advanced-weather-satellite-yet-just-dropped-it-1791527000
                  • LukeCodewalkerL
                    LukeCodewalker Module Developer @Burner911
                    @Burner911 sure :) should be straight forward. I you know how to do it feel free to make a pull request. If not I can have a look at the weekend if I find some time.
                    B 1 Reply Last reply
                    • SvenSommerS
                      SvenSommer @Burner911
                        Burner911 @LukeCodewalker
                        @LukeCodewalker Thank you for helping out! I’m still stumbling along with the code, but if you have time to add the new http://goes.gsfc.nasa.gov/goescolor/goeseast/overview2/color_lrg/latestfull.jpg image this weekend that would be awesome.
                        • SvenSommerS
                          SvenSommer
                          @LukeCodewalker, @Burner911
                          I just integrated the ‘centralAmericaDiscNat’ option and made a pull request.
                            Burner911 @SvenSommer
                            @SvenSommer You’re fast! Thank you!
                              Renfield
                              @LukeCodewalker
                              First, thanks for the great module!
                              I’m having an issue with the module when I specify ‘ownImagePath’. The image is retrieved and displayed properly but does not update. I’ve tried several different external image sources with the same result.
                              Is it possible that there’s a caching issue?
                              Thanks,
                              Renfield
                              LukeCodewalkerL 1 Reply Last reply
                              • LukeCodewalkerL
                                LukeCodewalker Module Developer @Renfield
                                @Renfield the module does only update the pre-defined satellite images. I did not implement that for own images. But that could be changed quickly. Do you think you can do that on your own or do you need help?
                                B D 2 Replies Last reply
                                  Renfield
                                  I’m new to javascript but that’s what I thought I saw in the code (that the user images were purely static). I tried appending
                                  ?+ new Date().getTime();
                                  to the image pull but probably due to an error on my part still couldn’t get the user-defined images to force a refresh on each update to the DOM. I’m in the early stages of learning javascript so it’s still a bit frustrating at times.
                                  If you could add the fresh image retrieval functionality for user images to a future update that would be much appreciated but there’s no hurry. Should I put a “formal” request in the Requests forum?
                                  Thanks,
                                  Renfield
                                  D 1 Reply Last reply
                                  Reply Quote -1
                                    chrisfoerg @lolobyte
                                    @lolobyte it’s in German, maybe is this better :-) https://www.heise.de/newsticker/meldung/NASA-Satellit-GOES-16-Erste-beeindruckende-Fotos-der-Erde-3607307.html?wt_mc=rss.ho.beitrag.atom&hg=1&hgi=0&hgf=false
                                    schlachtkreuzer6S binderthB 2 Replies Last reply
                                    • schlachtkreuzer6S
                                      schlachtkreuzer6 @chrisfoerg
                                      @chrisfoerg Niiiiiiiiiice!!!
                                      • binderthB
                                        binderth @chrisfoerg
                                        @chrisfoerg Looks great! but if I understand it correctly, there’s no live-feed at the moment?
                                        • schlachtkreuzer6S
                                          schlachtkreuzer6 @binderth
                                          @binderth jep, they are testing the stuff and so on
                                            BatterseaBridge @LukeCodewalker
                                            @LukeCodewalker
                                            Love this module! Thank you. I’d also like to have ‘ownimagepath’ updated regularly. I’m also a JS newbie and have no idea where to start. The image I’m using is: https://www.nnvl.noaa.gov/images/FDC-latest.png
                                            Thanks!
                                            • 3 / 6
