    MMM-Globe
    119 Posts 39 Posters 239.7k Views 40 Watching
    • LukeCodewalkerL
      LukeCodewalker Module Developer @Burner911
      @Burner911 sure :) should be straight forward. I you know how to do it feel free to make a pull request. If not I can have a look at the weekend if I find some time.
      B 1 Reply Last reply
      • SvenSommerS
        SvenSommer @Burner911
          Burner911 @LukeCodewalker
          @LukeCodewalker Thank you for helping out! I’m still stumbling along with the code, but if you have time to add the new http://goes.gsfc.nasa.gov/goescolor/goeseast/overview2/color_lrg/latestfull.jpg image this weekend that would be awesome.
          • SvenSommerS
            SvenSommer
            @LukeCodewalker, @Burner911
            I just integrated the ‘centralAmericaDiscNat’ option and made a pull request.
              Burner911 @SvenSommer
              @SvenSommer You’re fast! Thank you!
                Renfield
                @LukeCodewalker
                First, thanks for the great module!
                I’m having an issue with the module when I specify ‘ownImagePath’. The image is retrieved and displayed properly but does not update. I’ve tried several different external image sources with the same result.
                Is it possible that there’s a caching issue?
                Thanks,
                Renfield
                LukeCodewalkerL 1 Reply Last reply
                • LukeCodewalkerL
                  LukeCodewalker Module Developer @Renfield
                  @Renfield the module does only update the pre-defined satellite images. I did not implement that for own images. But that could be changed quickly. Do you think you can do that on your own or do you need help?
                  B D 2 Replies Last reply
                    Renfield
                    I’m new to javascript but that’s what I thought I saw in the code (that the user images were purely static). I tried appending
                    ?+ new Date().getTime();
                    to the image pull but probably due to an error on my part still couldn’t get the user-defined images to force a refresh on each update to the DOM. I’m in the early stages of learning javascript so it’s still a bit frustrating at times.
                    If you could add the fresh image retrieval functionality for user images to a future update that would be much appreciated but there’s no hurry. Should I put a “formal” request in the Requests forum?
                    Thanks,
                    Renfield
                    D 1 Reply Last reply
                    Reply Quote -1
                      chrisfoerg @lolobyte
                      @lolobyte it’s in German, maybe is this better :-) https://www.heise.de/newsticker/meldung/NASA-Satellit-GOES-16-Erste-beeindruckende-Fotos-der-Erde-3607307.html?wt_mc=rss.ho.beitrag.atom&hg=1&hgi=0&hgf=false
                      schlachtkreuzer6S binderthB 2 Replies Last reply
                      • schlachtkreuzer6S
                        schlachtkreuzer6 @chrisfoerg
                        @chrisfoerg Niiiiiiiiiice!!!
                        • binderthB
                          binderth @chrisfoerg
                          @chrisfoerg Looks great! but if I understand it correctly, there’s no live-feed at the moment?
                          schlachtkreuzer6S 1 Reply Last reply
                          • schlachtkreuzer6S
                            schlachtkreuzer6 @binderth
                            @binderth jep, they are testing the stuff and so on
                              BatterseaBridge @LukeCodewalker
                              @LukeCodewalker
                              Love this module! Thank you. I’d also like to have ‘ownimagepath’ updated regularly. I’m also a JS newbie and have no idea where to start. The image I’m using is: https://www.nnvl.noaa.gov/images/FDC-latest.png
                              Thanks!
                              • FlatPepsiF
                                FlatPepsi
                                I will pile on the request for updating custom URL images. I’ve been going crazy trying to figure out why it doesn’t update – and now I know. :)
                                The default North America image is a synthetic one, with real cloud cover overlaid on a static daylight earth. Nighttime is just as bright as daytime, for example. I wanted to use an image accurately showing the day/night divider moving across the globe. The best one I could find is here:
                                http://www.goes.noaa.gov/goesfull.html
                                On that page the “GOES East Visible” is exactly what I want, but sadly it’s in black-and-white. I’d love to have a color version of that. I may have to wait for that new satellite (Geos 16?) start publishing data.
                                  BatterseaBridge @FlatPepsi
                                  @FlatPepsi
                                  Would this North American image work for you? https://www.nnvl.noaa.gov/images/FDC-latest.png
                                    daikaiju @Renfield
                                    @Renfield Did you find out how to update the code for this? I’m looking to refresh my image as well.
                                      Desertswing
                                      Hey all i got a problem with my Globe…
                                      error: Unable to append to .git/logs/refs/remotes/origin/develop: Permission denied
                                      From https://github.com/MichMich/MagicMirror
                                      ! a6485b6…88a01d3 develop -> origin/develop (unable to update local ref)
                                      error: cannot open .git/FETCH_HEAD: Permission denied
                                      what am i doing wrong ??
                                        daikaiju @LukeCodewalker
                                        @LukeCodewalker Can you tell us how to use our own images in your module?
                                        • SvenSommerS
                                          SvenSommer
                                          I just found this source here and thought about this module.
                                          http://earth.nullschool.net/
                                          Reply Quote 2
                                          • cowboysdudeC
                                            cowboysdude Module Developer @SvenSommer
                                            @SvenSommer WOW I really like that!!!
                                            iMAGiCI 1 Reply Last reply
                                            • 3 / 6
