    MMM-Globe
    119 Posts 39 Posters 238.1k Views 40 Watching
      Renfield
      @LukeCodewalker
      First, thanks for the great module!
      I’m having an issue with the module when I specify ‘ownImagePath’. The image is retrieved and displayed properly but does not update. I’ve tried several different external image sources with the same result.
      Is it possible that there’s a caching issue?
      Thanks,
      Renfield
      L 1 Reply Last reply
      • L
        LukeCodewalker Module Developer @Renfield
        @Renfield the module does only update the pre-defined satellite images. I did not implement that for own images. But that could be changed quickly. Do you think you can do that on your own or do you need help?
        B D 2 Replies Last reply
          Renfield
          I’m new to javascript but that’s what I thought I saw in the code (that the user images were purely static). I tried appending
          ?+ new Date().getTime();
          to the image pull but probably due to an error on my part still couldn’t get the user-defined images to force a refresh on each update to the DOM. I’m in the early stages of learning javascript so it’s still a bit frustrating at times.
          If you could add the fresh image retrieval functionality for user images to a future update that would be much appreciated but there’s no hurry. Should I put a “formal” request in the Requests forum?
          Thanks,
          Renfield
          D 1 Reply Last reply
          Reply Quote -1
            chrisfoerg @lolobyte
            @lolobyte it’s in German, maybe is this better :-) https://www.heise.de/newsticker/meldung/NASA-Satellit-GOES-16-Erste-beeindruckende-Fotos-der-Erde-3607307.html?wt_mc=rss.ho.beitrag.atom&hg=1&hgi=0&hgf=false
            S B 2 Replies Last reply
              schlachtkreuzer6 @chrisfoerg
              @chrisfoerg Niiiiiiiiiice!!!
                binderth @chrisfoerg
                @chrisfoerg Looks great! but if I understand it correctly, there’s no live-feed at the moment?
                  schlachtkreuzer6 @binderth
                  @binderth jep, they are testing the stuff and so on
                    BatterseaBridge @LukeCodewalker
                    @LukeCodewalker
                    Love this module! Thank you. I’d also like to have ‘ownimagepath’ updated regularly. I’m also a JS newbie and have no idea where to start. The image I’m using is: https://www.nnvl.noaa.gov/images/FDC-latest.png
                    Thanks!
                    • FlatPepsiF
                      FlatPepsi
                      I will pile on the request for updating custom URL images. I’ve been going crazy trying to figure out why it doesn’t update – and now I know. :)
                      The default North America image is a synthetic one, with real cloud cover overlaid on a static daylight earth. Nighttime is just as bright as daytime, for example. I wanted to use an image accurately showing the day/night divider moving across the globe. The best one I could find is here:
                      http://www.goes.noaa.gov/goesfull.html
                      On that page the “GOES East Visible” is exactly what I want, but sadly it’s in black-and-white. I’d love to have a color version of that. I may have to wait for that new satellite (Geos 16?) start publishing data.
                      B 1 Reply Last reply
                        BatterseaBridge @FlatPepsi
                        @FlatPepsi
                        Would this North American image work for you? https://www.nnvl.noaa.gov/images/FDC-latest.png
                          daikaiju @Renfield
                          @Renfield Did you find out how to update the code for this? I’m looking to refresh my image as well.
                            Desertswing
                            Hey all i got a problem with my Globe…
                            error: Unable to append to .git/logs/refs/remotes/origin/develop: Permission denied
                            From https://github.com/MichMich/MagicMirror
                            ! a6485b6…88a01d3 develop -> origin/develop (unable to update local ref)
                            error: cannot open .git/FETCH_HEAD: Permission denied
                            what am i doing wrong ??
                              daikaiju @LukeCodewalker
                              @LukeCodewalker Can you tell us how to use our own images in your module?
                              • SvenSommerS
                                SvenSommer
                                I just found this source here and thought about this module.
                                http://earth.nullschool.net/
                                Looking for some building inspiration?
                                Check out my large, thin and metal framed mirror on robstechlog.com.
                                Modules released:
                                MMM-GoogleAnalytics
                                MMM-GrafanaChart
                                MMM-GrafanaGauges
                                Reply Quote 2
                                • cowboysdudeC
                                  cowboysdude Module Developer @SvenSommer
                                  @SvenSommer WOW I really like that!!!
                                  iMAGiCI 1 Reply Last reply
                                  • iMAGiCI
                                    iMAGiC @cowboysdude
                                    @cowboysdude can it shows on pi 3, I’ve tried it in iFrame, but seems color and performance not enough. http://earth.nullschool.net/
                                    Choice * Judgment * Values
                                    • iMAGiCI
                                      iMAGiC
                                      Hi all,
                                      sometimes picture “geoColor” will missing or not keep update, after check the link. the link sometimes block for access, and you will get link broken message.
                                      so now, I’ve modified the link, use high resolution to instead, so far is ok, but it need more time when it is loading.
                                      just for your reference.
                                      this.imageUrls = {
                                      			'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
                                      P 1 Reply Last reply
                                      • V
                                        Vauxdvihl
                                        Sorry for the question
                                        But is there a view for europe available / configurable?
                                        • Z
                                          zzaidi148 @LukeCodewalker
                                          @LukeCodewalker Really nice module its just that I cant see it on my magicmirror. Config boots up and everything looks fine its just that the image doesn’t come up. I tried putting it center and middle center but didnt work. Any ideas?
                                            dasb00ter
                                            So if u read the read me it basically tells you how to set the region!
                                            Also help!
                                            This module loads and displays but the globe does NOT update for me. I’ve left the update config settings to default. If I restart the mirror the image does update. Also if somebody knows of a north American image that can be used please let me know although I would be just happy to get an updating globe.
                                            Thanks for your time
                                            @Vauxdvihl said in MMM-Globe:
                                            • 3 / 6
