    MMM-Globe
    119 Posts 39 Posters 233.9k Views 40 Watching
      daikaiju @Renfield
      @Renfield Did you find out how to update the code for this? I’m looking to refresh my image as well.
        Desertswing
        Hey all i got a problem with my Globe…
        error: Unable to append to .git/logs/refs/remotes/origin/develop: Permission denied
        From https://github.com/MichMich/MagicMirror
        ! a6485b6…88a01d3 develop -> origin/develop (unable to update local ref)
        error: cannot open .git/FETCH_HEAD: Permission denied
        what am i doing wrong ??
          daikaiju @LukeCodewalker
          @LukeCodewalker Can you tell us how to use our own images in your module?
          • SvenSommerS Offline
            SvenSommer
            I just found this source here and thought about this module.
            http://earth.nullschool.net/
            Looking for some building inspiration?
            Check out my large, thin and metal framed mirror on robstechlog.com.
            Modules released:
            MMM-GoogleAnalytics
            MMM-GrafanaChart
            MMM-GrafanaGauges
            • cowboysdudeC Offline
              cowboysdude Module Developer @SvenSommer
              @SvenSommer WOW I really like that!!!
              iMAGiCI 1 Reply Last reply Reply Quote 0
              • iMAGiCI Offline
                iMAGiC @cowboysdude
                @cowboysdude can it shows on pi 3, I’ve tried it in iFrame, but seems color and performance not enough. http://earth.nullschool.net/
                Choice * Judgment * Values
                • iMAGiCI Offline
                  iMAGiC
                  Hi all,
                  sometimes picture “geoColor” will missing or not keep update, after check the link. the link sometimes block for access, and you will get link broken message.
                  so now, I’ve modified the link, use high resolution to instead, so far is ok, but it need more time when it is loading.
                  just for your reference.
                  this.imageUrls = {
                  			'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
                  • V Offline
                    Vauxdvihl
                    Sorry for the question
                    But is there a view for europe available / configurable?
                    • Z Offline
                      zzaidi148 @LukeCodewalker
                      @LukeCodewalker Really nice module its just that I cant see it on my magicmirror. Config boots up and everything looks fine its just that the image doesn’t come up. I tried putting it center and middle center but didnt work. Any ideas?
                        dasb00ter
                        So if u read the read me it basically tells you how to set the region!
                        Also help!
                        This module loads and displays but the globe does NOT update for me. I’ve left the update config settings to default. If I restart the mirror the image does update. Also if somebody knows of a north American image that can be used please let me know although I would be just happy to get an updating globe.
                        Thanks for your time
                        @Vauxdvihl said in MMM-Globe:
                          Pimagical @iMAGiC
                          @iMAGiC to many requests will cause a ip block, keep it default
                          dasbooterD 1 Reply Last reply Reply Quote 0
                          • dasbooterD Offline
                            dasbooter @Pimagical
                            @Pimagical said in MMM-Globe:
                            I’ve tried default config for time and then after a few days tried an extended time in the config. Same issue. I can post my config but I’m confident it does not exceed the time limitations of the sources. I’m wondering if it is a caching issue like in the iframe reloaded module that wouldn’t refresh until I added some lines that I found in this forum
                              Pimagical @dasbooter
                              @dasbooter Your using a highres image source of 14mb maybe there are other limitations for this source, maybe you could try a lower resolution source?
                              My experience with resize above 800pixels for example 900 pixels the MMM-Globe script picks the highress source but my MagicMirror keeps black, could be to much for the raspberry pi 3 or a bug in the MMM-Globe…
                              • Andrius okA Offline
                                Andrius ok
                                How to make globe a little bit lower than center? Thanks!
                                  Andrius ok @GinSeng
                                  Hello @GinSeng maybe you know how to make a little bit lower than ‘middle_center’ ?
                                  Thanks!
                                  Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                    Mykle1 Project Sponsor Module Developer @Andrius ok
                                    @Andrius-ok said in MMM-Globe:
                                    bottom_center
                                    Or you could try some css on it I suppose
                                    • strawberry 3.141S Offline
                                      strawberry 3.141 Project Sponsor Module Developer @Andrius ok
                                      @Andrius-ok the region under middle_center is called lower_third https://forum.magicmirror.builders/topic/286/regions
                                      Andrius okA 1 Reply Last reply Reply Quote 0
                                        Thanks yes I tried smaller images. Still same problem for me. Looking at the module yes at 800 pixels or above it does call for a different image source. A hi res one . Really good thought tho. Thanks. Oh well pretty soon I’ll give it to my girlfriend for christmas. Then it will be out of site and outta mind. I’ll keep checking back. Or maybe just a clean install one day ```
                                        //your code here
                                          dasbooter @dasbooter
        module: 'MMM-Globe',
        position: 'upper_third',
        style: 'geoColor',
        imageSize: 350,
        updateInterval: 15*60*1000
                                            Andrius ok @strawberry 3.141
                                            Thanks @strawberry-3.141 I’am appreciated!
                                            • 4 / 6
