    MMM-Globe
    119 Posts 39 Posters 233.9k Views 40 Watching
      Desertswing
      Hey all i got a problem with my Globe…
      error: Unable to append to .git/logs/refs/remotes/origin/develop: Permission denied
      From https://github.com/MichMich/MagicMirror
      ! a6485b6…88a01d3 develop -> origin/develop (unable to update local ref)
      error: cannot open .git/FETCH_HEAD: Permission denied
      what am i doing wrong ??
        daikaiju @LukeCodewalker
        @LukeCodewalker Can you tell us how to use our own images in your module?
        • SvenSommerS Offline
          SvenSommer
          I just found this source here and thought about this module.
          http://earth.nullschool.net/
          Looking for some building inspiration?
          Check out my large, thin and metal framed mirror on robstechlog.com.
          Modules released:
          MMM-GoogleAnalytics
          MMM-GrafanaChart
          MMM-GrafanaGauges
          • cowboysdudeC Offline
            cowboysdude Module Developer @SvenSommer
            @SvenSommer WOW I really like that!!!
            iMAGiCI 1 Reply Last reply Reply Quote 0
            • iMAGiCI Offline
              iMAGiC @cowboysdude
              @cowboysdude can it shows on pi 3, I’ve tried it in iFrame, but seems color and performance not enough. http://earth.nullschool.net/
              Choice * Judgment * Values
              • iMAGiCI Offline
                iMAGiC
                Hi all,
                sometimes picture “geoColor” will missing or not keep update, after check the link. the link sometimes block for access, and you will get link broken message.
                so now, I’ve modified the link, use high resolution to instead, so far is ok, but it need more time when it is loading.
                just for your reference.
                this.imageUrls = {
                			'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
                • V Offline
                  Vauxdvihl
                  Sorry for the question
                  But is there a view for europe available / configurable?
                  • Z Offline
                    zzaidi148 @LukeCodewalker
                    @LukeCodewalker Really nice module its just that I cant see it on my magicmirror. Config boots up and everything looks fine its just that the image doesn’t come up. I tried putting it center and middle center but didnt work. Any ideas?
                      dasb00ter
                      So if u read the read me it basically tells you how to set the region!
                      Also help!
                      This module loads and displays but the globe does NOT update for me. I’ve left the update config settings to default. If I restart the mirror the image does update. Also if somebody knows of a north American image that can be used please let me know although I would be just happy to get an updating globe.
                      Thanks for your time
                      @Vauxdvihl said in MMM-Globe:
                        Pimagical @iMAGiC
                        @iMAGiC to many requests will cause a ip block, keep it default
                        dasbooterD 1 Reply Last reply Reply Quote 0
                        • dasbooterD Offline
                          dasbooter @Pimagical
                          @Pimagical said in MMM-Globe:
                          I’ve tried default config for time and then after a few days tried an extended time in the config. Same issue. I can post my config but I’m confident it does not exceed the time limitations of the sources. I’m wondering if it is a caching issue like in the iframe reloaded module that wouldn’t refresh until I added some lines that I found in this forum
                            Pimagical @dasbooter
                            @dasbooter Your using a highres image source of 14mb maybe there are other limitations for this source, maybe you could try a lower resolution source?
                            My experience with resize above 800pixels for example 900 pixels the MMM-Globe script picks the highress source but my MagicMirror keeps black, could be to much for the raspberry pi 3 or a bug in the MMM-Globe…
                            • Andrius okA Offline
                              Andrius ok
                              How to make globe a little bit lower than center? Thanks!
                                Andrius ok @GinSeng
                                Hello @GinSeng maybe you know how to make a little bit lower than ‘middle_center’ ?
                                Thanks!
                                Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                  Mykle1 Project Sponsor Module Developer @Andrius ok
                                  @Andrius-ok said in MMM-Globe:
                                  bottom_center
                                  Or you could try some css on it I suppose
                                  • strawberry 3.141S Offline
                                    strawberry 3.141 Project Sponsor Module Developer @Andrius ok
                                    @Andrius-ok the region under middle_center is called lower_third https://forum.magicmirror.builders/topic/286/regions
                                    Andrius okA 1 Reply Last reply Reply Quote 0
                                      Thanks yes I tried smaller images. Still same problem for me. Looking at the module yes at 800 pixels or above it does call for a different image source. A hi res one . Really good thought tho. Thanks. Oh well pretty soon I’ll give it to my girlfriend for christmas. Then it will be out of site and outta mind. I’ll keep checking back. Or maybe just a clean install one day ```
                                      //your code here
                                        dasbooter @dasbooter
        module: 'MMM-Globe',
        position: 'upper_third',
        style: 'geoColor',
        imageSize: 350,
        updateInterval: 15*60*1000
                                          Andrius ok @strawberry 3.141
                                          Thanks @strawberry-3.141 I’am appreciated!
                                            Peter
                                            I have the same problem as Matt about a year ago.
                                            The globe works perfect but after some time I see only some lines.
                                            Some time later it is fine again.
                                            Any help?
                                            Peter
                                            This is Matts picture a year ago:
                                            G iMAGiCI dasbooterD P 4 Replies Last reply Reply Quote 0
                                            • 4 / 6
