    MMM-Globe
    119 Posts 39 Posters 239.7k Views 40 Watching
    • SvenSommerS
      SvenSommer
      I just found this source here and thought about this module.
      http://earth.nullschool.net/
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
      Reply Quote 2
      • cowboysdudeC
        cowboysdude Module Developer @SvenSommer
        @SvenSommer WOW I really like that!!!
        iMAGiCI 1 Reply Last reply
        • iMAGiCI
          iMAGiC @cowboysdude
          @cowboysdude can it shows on pi 3, I’ve tried it in iFrame, but seems color and performance not enough. http://earth.nullschool.net/
          Choice * Judgment * Values
          • iMAGiCI
            iMAGiC
            Hi all,
            sometimes picture “geoColor” will missing or not keep update, after check the link. the link sometimes block for access, and you will get link broken message.
            so now, I’ve modified the link, use high resolution to instead, so far is ok, but it need more time when it is loading.
            just for your reference.
            this.imageUrls = {
            			'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
            PimagicalP 1 Reply Last reply
            • V
              Vauxdvihl
              Sorry for the question
              But is there a view for europe available / configurable?
              • Z
                zzaidi148 @LukeCodewalker
                @LukeCodewalker Really nice module its just that I cant see it on my magicmirror. Config boots up and everything looks fine its just that the image doesn’t come up. I tried putting it center and middle center but didnt work. Any ideas?
                  dasb00ter
                  So if u read the read me it basically tells you how to set the region!
                  Also help!
                  This module loads and displays but the globe does NOT update for me. I’ve left the update config settings to default. If I restart the mirror the image does update. Also if somebody knows of a north American image that can be used please let me know although I would be just happy to get an updating globe.
                  Thanks for your time
                  @Vauxdvihl said in MMM-Globe:
                  • PimagicalP
                    Pimagical @iMAGiC
                    @iMAGiC to many requests will cause a ip block, keep it default
                    dasbooterD 1 Reply Last reply
                    • dasbooterD
                      dasbooter @Pimagical
                      @Pimagical said in MMM-Globe:
                      I’ve tried default config for time and then after a few days tried an extended time in the config. Same issue. I can post my config but I’m confident it does not exceed the time limitations of the sources. I’m wondering if it is a caching issue like in the iframe reloaded module that wouldn’t refresh until I added some lines that I found in this forum
                      • PimagicalP
                        Pimagical @dasbooter
                        @dasbooter Your using a highres image source of 14mb maybe there are other limitations for this source, maybe you could try a lower resolution source?
                        My experience with resize above 800pixels for example 900 pixels the MMM-Globe script picks the highress source but my MagicMirror keeps black, could be to much for the raspberry pi 3 or a bug in the MMM-Globe…
                        • Andrius okA
                          Andrius ok
                          How to make globe a little bit lower than center? Thanks!
                          • Andrius okA
                            Andrius ok @GinSeng
                            Hello @GinSeng maybe you know how to make a little bit lower than ‘middle_center’ ?
                            Thanks!
                            Mykle1M strawberry 3.141S 2 Replies Last reply
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @Andrius ok
                              @Andrius-ok said in MMM-Globe:
                              bottom_center
                              Or you could try some css on it I suppose
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @Andrius ok
                                @Andrius-ok the region under middle_center is called lower_third https://forum.magicmirror.builders/topic/286/regions
                                Andrius okA 1 Reply Last reply
                                • dasbooterD
                                  Thanks yes I tried smaller images. Still same problem for me. Looking at the module yes at 800 pixels or above it does call for a different image source. A hi res one . Really good thought tho. Thanks. Oh well pretty soon I’ll give it to my girlfriend for christmas. Then it will be out of site and outta mind. I’ll keep checking back. Or maybe just a clean install one day ```
                                  //your code here
                                  • dasbooterD
                                    dasbooter @dasbooter
                                                            module: 'MMM-Globe',
                                                            position: 'upper_third',
                                                            style: 'geoColor',
                                                            imageSize: 350,
                                                            updateInterval: 15*60*1000
                                    • Andrius okA
                                      Andrius ok @strawberry 3.141
                                      Thanks @strawberry-3.141 I’am appreciated!
                                        Peter
                                        I have the same problem as Matt about a year ago.
                                        The globe works perfect but after some time I see only some lines.
                                        Some time later it is fine again.
                                        Any help?
                                        Peter
                                        This is Matts picture a year ago:
                                        G iMAGiCI dasbooterD PimagicalP 4 Replies Last reply
                                        • G
                                          gshimself @Peter
                                          @Peter I use to have that, and that is when my SD card got full. do a
                                          df -h
                                          and see if the storage is full or not
                                          • iMAGiCI
                                            iMAGiC @Peter
                                            @Peter I found this issue when I attache this module into MM, due to the link is not very stable, and it stop working sometime. you could try other link (e.g. full), it will work.
                                            • 4 / 6
