    MMM-Globe
    119 Posts 39 Posters 239.7k Views 40 Watching
    • PimagicalP
      Pimagical @iMAGiC
      @iMAGiC to many requests will cause a ip block, keep it default
      dasbooterD 1 Reply Last reply
      • dasbooterD
        dasbooter @Pimagical
        @Pimagical said in MMM-Globe:
        I’ve tried default config for time and then after a few days tried an extended time in the config. Same issue. I can post my config but I’m confident it does not exceed the time limitations of the sources. I’m wondering if it is a caching issue like in the iframe reloaded module that wouldn’t refresh until I added some lines that I found in this forum
        PimagicalP 1 Reply Last reply
        • PimagicalP
          Pimagical @dasbooter
          @dasbooter Your using a highres image source of 14mb maybe there are other limitations for this source, maybe you could try a lower resolution source?
          My experience with resize above 800pixels for example 900 pixels the MMM-Globe script picks the highress source but my MagicMirror keeps black, could be to much for the raspberry pi 3 or a bug in the MMM-Globe…
          • Andrius okA
            Andrius ok
            How to make globe a little bit lower than center? Thanks!
            • Andrius okA
              Andrius ok @GinSeng
              Hello @GinSeng maybe you know how to make a little bit lower than ‘middle_center’ ?
              Thanks!
              Mykle1M strawberry 3.141S 2 Replies Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @Andrius ok
                @Andrius-ok said in MMM-Globe:
                bottom_center
                Or you could try some css on it I suppose
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Andrius ok
                  @Andrius-ok the region under middle_center is called lower_third https://forum.magicmirror.builders/topic/286/regions
                  Andrius okA 1 Reply Last reply
                  • dasbooterD
                    Thanks yes I tried smaller images. Still same problem for me. Looking at the module yes at 800 pixels or above it does call for a different image source. A hi res one . Really good thought tho. Thanks. Oh well pretty soon I’ll give it to my girlfriend for christmas. Then it will be out of site and outta mind. I’ll keep checking back. Or maybe just a clean install one day ```
                    //your code here
                    • dasbooterD
                      dasbooter @dasbooter
                                              module: 'MMM-Globe',
                                              position: 'upper_third',
                                              style: 'geoColor',
                                              imageSize: 350,
                                              updateInterval: 15*60*1000
                      • Andrius okA
                        Andrius ok @strawberry 3.141
                        Thanks @strawberry-3.141 I’am appreciated!
                          Peter
                          I have the same problem as Matt about a year ago.
                          The globe works perfect but after some time I see only some lines.
                          Some time later it is fine again.
                          Any help?
                          Peter
                          This is Matts picture a year ago:
                          G iMAGiCI dasbooterD PimagicalP 4 Replies Last reply
                          • G
                            gshimself @Peter
                            @Peter I use to have that, and that is when my SD card got full. do a
                            df -h
                            and see if the storage is full or not
                            • iMAGiCI
                              iMAGiC @Peter
                              @Peter I found this issue when I attache this module into MM, due to the link is not very stable, and it stop working sometime. you could try other link (e.g. full), it will work.
                              Choice * Judgment * Values
                                Peter @gshimself
                                @gshimself , there is still 8.5 G left on the 16G card.
                                Peter
                                  Peter @iMAGiC
                                  @iMAGiC , what do you mean with " full"?
                                  Is there a good link to the side of the earth with Europe?
                                  Peter
                                  iMAGiCI 1 Reply Last reply
                                  • iMAGiCI
                                    iMAGiC @Peter
                                    @Peter
                                    sorry, I meaning use hi-res url instead of it.
                                    for example:
                                    this.imageUrls = {
                                    			'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
                                    @Peter said in MMM-Globe:
                                    Peter
                                    • dasbooterD
                                      dasbooter @Peter
                                      @Peter I agree with the post about changing the link. I had the same problem then I changed sources and have had no issue.
                                        Peter @iMAGiC
                                        @iMAGiC , I used your link: MM starts, I see half of the globe and MM stops, starts again with half of the globe and stops again; like a loop.
                                        Maybe because I use a RPI 2?
                                        Peter
                                          Peter @dasbooter
                                          @dasbooter , what link do you use?
                                          peter
                                          • PimagicalP
                                            Pimagical @Peter
                                            @Peter I fixed this problem with improving my wifi signal/range!
                                            Check your wifi signal quality if around 37/70 this will cause problems for sure, it should be at least above 45/70 or higher check your signal with:
                                            sudo iwconfig wlan0
                                            My bad wifi signal caused problems like not loading the globe images and freezing agenda items and not loading the newsfeed items.
                                            Solutions are
                                            1. Change the accespoint location or
                                            2. Buy a WIFI USB adapter to improve the wifi range because the Pi 3 default wifi/bluetooth is very bad: Pi 3 Wifi problems or
                                            3. DIY Modification option External antenna modifications for the Raspberry :Pi 3
                                            Good Luck!
                                            • 4 / 6
